Drive Shaft Vibrations Solved Step-by-Step
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TscotR214, Oct 18, 2012.
  1. Jun 5, 2018 at 8:36 PM
    #701
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    With CB & no rear shims my measurements were:
    a. Zero your angle gauge against the back of the transfer case, up to the right (under the truck facing forward) against that nice flat place with the two holes. (photo #2 and photo #3)
    b. Measure your first driveshaft angle by placing the gauge underneath the first driveshaft, keeping clear of any mud, stickers, etc. My gauge is magnetic so I flipped it over and hung it upside down. I messed with it a bit to get it perfectly in line with the driveshaft and perfectly underneath (by perfectly I mean I randomly wiggled it around until it came up with the most consistent number). This is your first measurement of three, write it down somewhere, and represents the angle of the first shaft as it comes out of your transfer case. (photo #4)5.5°
    c. Take your next measurement underneath the rear (second half) of your driveshaft, after the carrier bearing. I took mine next to the rear differential, again keeping clear of stickers, weights, etc, and wiggling it until I had a consistent reading. This is your second of three measurements, write it down, and represents the angle of your rear half driveshaft as it relates again to the transfer case. (photo #5)5.5°
    d. For the third and final measurement, you’ll need to re-calibrate your angle gauge. On mine, I left the gauge where it was, hanging by its magnets under the rear driveshaft, and pressed and released the Calibrate button a few times until the gauge, when hanging under the rear driveshaft, read zero. (photo #6) Then locate the nice flat area up against your rear axle housing, next to the rear differential case. Make sure it’s fairly free of mud etc. (photo #7) Then place your gauge (after zero-ing it out on the rear driveshaft) up against this flat part of your rear axle. I found a nice spot just above the molded line (in red) and next to the diff housing bolts (tip of arrow). This is your third and final measurement, write it down also, and represents the angle at which your rear driveshaft comes out of your rear differential. (photo #8)
    I'll check my measurements w/no CB & 3° shim ASAP.
    lpfe42 likes this.
  2. Jun 7, 2018 at 10:37 PM
    #702
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    Current measurements with 3* degree shim and no CB drop:
    Front DS 4.7*
    Rear DS 4.4*
    Rear pinion .3*
    I should be vibe free according to these numbers, correct?
  3. Jun 8, 2018 at 4:21 AM
    #703
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    With these #'s I would hope so. Are the shafts in line, have you run a string line on them?
  4. Jun 8, 2018 at 6:47 AM
    #704
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I have not ran a line but I will. If I do, & it's true, what's my next step? Can these shafts be mounted out of phase? On my LC, they had to be mounted out of phase but IDK enough about the d-shafts yet. I'm @ a loss as I should've been vibe free. I've greased the u-joints & shaft splines hoping they were just dry but that didn't help (I haven't had the truck long).
  5. Jun 8, 2018 at 7:54 AM
    #705
    Carrot Top
    Carrot Top Well-Known Member
    Mark
    Las Vegas, NV
    2016 Inferno Tacoma TRD 4x4
    I agree you should be vibe free. Your angles are good. I can only think of a worn/defective item. Like a bad u joint, CB, transmission mount, rear axle bearings. You might need professional help by going to a driveline shop. They are generally good at figuring this out. Keep us posted.
    MolonLabeTaco likes this.
  6. Jun 8, 2018 at 10:08 AM
    #706
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    If one of these were bad, wouldn't I notice vibes @ other times besides ONLY ~5 to ~14mph?
  7. Jun 8, 2018 at 1:03 PM
    #707
    Carrot Top
    Mark
    Las Vegas, NV
    Diagnosing vibes can be very difficult. It sounds like you bought the truck with the vibrations. That makes it even harder since you don't have a baseline from before the lift.
  8. Jun 8, 2018 at 1:10 PM
    #708
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    It was bone stock when I bought it in Feb. 2018. I've done everything to it. It had a vibe before the lift but I'm not sure if it was the bad tires on it or not. It vibrated a whole lot more before I put new tires on it, which happened to be the same time I put the lift on it.
    I hate to do it but I guess I'll wait until one of the u-joints shits the bed then replace all 3 rear u-joints & CB. Or save up for a DC one piece shaft.
  9. Jun 8, 2018 at 1:23 PM
    #709
    Carrot Top
    Mark
    Las Vegas, NV
    Thanks for the clarification. I have read that others had to get their tires rebalance more than once to fix vibrations. Check with your tire shop. Too bad the vibration didn't get fixed by dealer before mods went on.
  10. Jun 8, 2018 at 5:30 PM
    #710
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I'm sure it's not the tires as this is the 2nd set I've had since replacing the bad ones that were on it when I bought it. Long story about the tires lol.
  11. Jun 8, 2018 at 5:48 PM
    #711
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    I’ve got the same issue, but at 1500 rpm. Took mine to Pablo at Tandem in Ft Worth and he ran all the calcs. I’m still thinking double cardan.
    MolonLabeTaco[QUOTED] likes this.
  12. Jun 9, 2018 at 1:20 PM
    #712
    ThomasMore66
    @MolonLabeTaco, went back by Tandem today. Since Pablo adjusted the shackles on my OME leafs, the vibe was better and then got bad again. Next step is to replace the bushings in the shackles or go with a different shackle. My vibe didn’t start until about 10k miles ago. Goes along with the theory that something got worn. I’m at about 50k on the lift.
  13. Jun 9, 2018 at 1:35 PM
    #713
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    do yourself a favor, put a camera under the truck, you especially supercharged are likely going to be appalled at how much axle wrap you have and subsequent HUUUUGE angle changes at the pinion
    Unfortunatly there is not much you can do to combat this other than a traction bar or something like a double cardan at the center which helps with the fact you wont have to properly phase angles between the two rear most joints.
    Biscuits and DoorDing like this.
  14. Jun 9, 2018 at 2:02 PM
    #714
    ThomasMore66
    Running OME springs with all the overloads. You think it still wraps? If it does it’s about to get worse. New headers, high flow cats, snout cutter, and a smaller pulley are sitting in the garage.
  15. Jun 9, 2018 at 2:17 PM
    #715
    ThomasMore66
  16. Jun 9, 2018 at 4:11 PM
    #716
    ThomasMore66
    Checked back this pm with my shop/mechanic. He expressed additional negativity about the product and quality.
  17. Jun 10, 2018 at 10:35 AM
    #717
    nd4spdbh
    SoCal
    Guaranteed to still have wrap, mount a camera real quick and take her for a spin.
    Dont even bother with weld on or bolt on.... I have the weld on budbuilt one and its absolute TRASH. Had to modify and clock the rear bracket and mount the upper axle mount outside of the bracket just to clear the stock exhaust on my 2013, had to replace the rear standard poly joints with proper hard heims to eliminate flex, had to modify for clearance the front shackle mount to clear the body and mount properly to the cross member.
    If you want a traction bar like that one can be built so much better.
    Oh and to top it off i still have vibes, and by nature of how suspension cycles and what the traction bar does, if the truck is loaded down i get high speed vibes.
    At this point im pretty much at a double cardan joint at the center is the only answer, or REALLY REALLY stiff rear springs to get rid of axle wrap.... but id like my ride to be nice.
    DoorDing likes this.
  18. Jun 11, 2018 at 7:52 AM
    #718
    nd4spdbh
    SoCal
    yeah there is NO way id ever buy the bolt on traction bar. Those studs that hold the 3rd member in are NOT meant for those kind of forces.
    Airbags could help with load, but wont help with axle wrap.
  19. Jul 5, 2018 at 4:01 PM
    #719
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Finally got to measure with the new angle finder...my numbers don't look too bad, zeroed on the transfer case I got 3.8 first shaft, 4.6 second shaft, zeroed again and got 0.4 at diff. Currently have two washers at Carrier bearing and 2.5 degree shims. Any suggestions which to adjust?
  20. Jul 5, 2018 at 6:34 PM
    #720
    Taco'09
    Taco'09 Well-Known Member
    If that 0.4 at the diff is correct it is way off from the ideal shown in Fig. 10 of the infamous Spicer diagram. You might want to take a peek a my comments in another recent thread on the matter starting with Post #4 here: https://www.tacomaworld.com/threads/drive-line-angles-peer-review-requested.555083/
