Drive Shaft Vibrations Solved Step-by-Step
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TscotR214, Oct 18, 2012.
  1. Feb 7, 2019 at 6:09 PM
    #801
    MGDTX
    MGDTX Member
    2013 Tacoma 4×4
    None to date
    2013 Tacoma 4×4 HELP!!! Guys, I lived with driveline vibration on my 2013 TRD 4X4 for 5 years until I changed the 2-pc driveshaft to 1-pc drive shaft. The 1-pc virtually eliminated my vibration. I put a 3" lift kit in it 2 weeks ago which resulted in terrible vibration. As a result, I measure the transmission flange angle at 7.3 degrees and the pinion flange at 10.7 degrees. Common sense told me a 3 degree shim would fix my problem..... After measuring the pinion angle after shim install, it is now 19.3 degrees!!! How is this possible?!? I had the shims installed with thin side forward between lift block and spring pack which is what I learned from this website. WTF do I do now? I'm just about ready to drive it off a cliff with me in it. I can't stand this damn vibration any longer. If not solved soon, I'm selling the SOB and I'm done with Toyota forever. thanks for any advice.
  2. Feb 7, 2019 at 6:43 PM
    #802
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Breathe...
  3. Feb 7, 2019 at 6:56 PM
    #803
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Which direction is the angle? Swap the shim around the other direction and see what the angles look like
  4. Feb 7, 2019 at 7:01 PM
    #804
    rmepilot
    Rob
    Huntsville, AL
    Most likely trolling. 2 posts (both the same), but learned how to fix his truck on TW... :rolleyes:
  5. Feb 8, 2019 at 12:46 PM
    #805
    MGDTX
    MGDTX Member
    2013 Tacoma 4×4
    None to date
    The pinion was pitched down after 3" lift installed, thus the 3 deg shim with skinny side forward as defined in numerous threads. Now it pitched up to 19.3 deg. To swap the shims around and find out that's not going to fix it....I just keep throwing money at the situation and not fixing the issue.
  6. Feb 8, 2019 at 1:24 PM
    #806
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    You simply can’t get 19.3+ degree change from a 3 degree shim. Idk what you did wrong but it’s not right.
  7. Feb 8, 2019 at 2:26 PM
    #807
    rollin904
    TJ
    Greenville, SC
    '14 DCSB 4x4
    With a one piece driveshaft, really not sure what to recommend. Doesnt sound right to have that kind of angle, especially after shimming
  8. Feb 8, 2019 at 3:02 PM
    #808
    rmepilot
    Rob
    Huntsville, AL
    2 possibilities:
    He's trolling this thread with now a total of 3 posts or, his "block" lift is installed incorrectly/poor design. "Skinny" part forward in the shims cannot pitch the pinion down.
    I still find it hard to believe he's been a member for 17 months and only has 3 total posts. in 2 days on this subject...
    I hope the latter. Troll posts are funny at times, but they need to be a stand alone, not tagged to a helpful tread.
  9. Feb 9, 2019 at 11:04 AM
    #809
    MGDTX
    MGDTX Member
    2013 Tacoma 4×4
    None to date
    Dont think its possible to install the list block incorrectly. It was rough country lift with 2" blocks in rear between axle shelf and springs. I think its impossible to install incorrectly and impossible to install shims incorrectly as they sit on top of blocks just under leaf pack
  10. Feb 9, 2019 at 11:10 AM
    #810
    rmepilot
    Rob
    Huntsville, AL
    I don’t disagree with that, but the angles don’t make sense.
    Pics of everything, including the measurements would help.
  11. Feb 9, 2019 at 11:45 AM
    #811
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    So I’ve followed this thread a long time. Carrier bearing replaced. Drivers side needle bearing replaced. Drive shaft balanced. Angles checked and re-checked.
    My vibration started about 15000 -20000 miles ago; I’m at about 80k now. Been lifted for probably 60k miles. 2013 TRD OR 4wd. I had a vibe at 1300-1500 rpm generally when lugging along. Also had a thump between 45-60 mph when accelerating moderately.
    Just replaced my valve body with a Wholesale Automatic Transmission model. Flushed the trans. Vibe is gone. I now believe mine was all related to torque converter lockup.
    rmepilot likes this.
  12. Feb 9, 2019 at 11:50 AM
    #812
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    The timing of your vibe is way different than mine. Mine is only at take off from a stop, up to ~15mph.
  13. Feb 9, 2019 at 11:52 AM
    #813
    ThomasMore66
    I had that some too from new. I haven’t felt that now either. Pondering a regear to 4.56’s so we’ll see what happens when I do that. Other projects are now taking my money.
    MolonLabeTaco[QUOTED] likes this.
  14. Feb 9, 2019 at 3:07 PM
    #814
    MGDTX
    MGDTX Member
    2013 Tacoma 4×4
    None to date
    So u guys dont think im smoking crack...here are measurements front and rear post lift, then post lift after 3 deg shim install. 7.5 front flange measurement, 10.7 deg rear after lift, 19.3 rear after shim install!!!20190209_153157.jpg 20190126_141046.jpg 20190209_154028.jpg 20190209_153935.jpg 20190126_140421.jpg
  15. Feb 9, 2019 at 3:53 PM
    #815
    rmepilot
    Rob
    Huntsville, AL
    The reason I thought you were trolling us, was stated previously...
    With that said, you have to zero your angle finder on there front flange and start from there.
    I recommend using this app and follow the instructions:
    http://www.tremec.com/menu.php?m=154
  16. Feb 9, 2019 at 7:57 PM
    #816
    MGDTX
    MGDTX Member
    2013 Tacoma 4×4
    None to date
    I dont disagree about zeroing my angle finder but it doesn't matter...the difference between front and back is the same regardless of whether u zero or not...just dont understand how i can go from 3 deg difference front to back and install 3 deg shims and now im 11+ deg out. I dont believe the shims are in backwards but seems based on measurement im wondering if they are.
  17. Feb 10, 2019 at 4:57 AM
    #817
    rmepilot
    Rob
    Huntsville, AL
    Try pulling the shaft and measure without using the file. True, it doesn’t matter if you zero or not, it just reduces the simple math and gives you the difference.
    Shim geometry: small end forward tilts the pinion up; thick end forward tilts the pinion down.
    Keep in mind, that almost none of us use a block lift and that may contribute to your problems. :notsure:
    Edit: try keeping the angle finder oriented in the same direction at all times.
  18. Feb 10, 2019 at 1:43 PM
    #818
    slomoe
    slomoe Well-Known Member
    Stuart,Fl
    2011 Tacoma DCLB TRD Sport 4x4
    Wet Okole, Maxxis Razor (285x70x17), Bilstein 6112, RXT's Fn 5star
    Alright I am kinda in between 1 and 1.5 degrees for my rear pinion flange to match the TC flange. Would like to get steel shims, but have not found any steel ones that small. Any advice where to look? I prefer non slotted type.
  19. Feb 10, 2019 at 3:27 PM
    #819
    rmepilot
    Rob
    Huntsville, AL
    What is the D/S angle?
  20. Feb 10, 2019 at 6:02 PM
    #820
    slomoe
    Stuart,Fl
    Pinion is up 1.5*, rear shaft is 6* and front is 5*. Gotta get the pinion right first before really worrying about the rest though. Whatcha think? Also wheres everyone purchasing their 1.5* steel shims?
    Alexely999 likes this.
