Drive Shaft Vibrations Solved Step-by-Step
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TscotR214, Oct 18, 2012.
  1. Feb 10, 2019 at 6:56 PM
    #821
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    How much lift and are you wanting to tilt the pinion up or down?
    My pinion is .4* down, but plan on shimming it up 3* to shallow out my u-joint angles. I’m not a believer in matching the pinion and flange on a lifted truck. My lift is 3”.
    After replacing my DS, all of my vibes are gone, except for the 15-25 startup vibe from u-joint angles >3*.
    Not sure where to find 1.5* steel shims, but it maybe earlier in this thread.
  2. Feb 10, 2019 at 7:03 PM
    #822
    slomoe
    slomoe Well-Known Member
    Stuart,Fl
    2011 Tacoma DCLB TRD Sport 4x4
    Wet Okole, Maxxis Razor (285x70x17), Bilstein 6112, RXT's Fn 5star
    I am at 2'' lift in rear with RXT leaf pack @option 2. I need the pinion to drop 1.5* to equal the TC flange. Or I could do a 2* shim and that would give me .5* +/- down from TC flange. Have the harbor freight angle finder so not the most accurate but figured it would get me pretty close
  3. Feb 10, 2019 at 7:10 PM
    #823
    rmepilot
    Rob
    Huntsville, AL
    Does the TC flange and pinion have to be equal?
    I’m entirely not of the school of thought, compared to getting the u-joint angles <3*.
    Try this app on your smartphone:
    http://www.tremec.com/menu/tremec-toolbox-app/
  4. Feb 10, 2019 at 7:15 PM
    #824
    beachingtaco
    beachingtaco "We have assumed control"
    Long Island, new york
    2012 DCLB trd sport
    westin nerf bars, ARE in-channel visors, Wet Okole's, mobtown tailgate skin, Tail Gate theft mod
    sub'd for future issues!
  5. Feb 10, 2019 at 7:16 PM
    #825
    slomoe
    Stuart,Fl
    Seems to be several different trains of thought on this. I am by no means an expert, just soaking up what has worked and hasn't. I will check out the app
  6. Feb 10, 2019 at 7:30 PM
    #826
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    I've been wondering the same thing, as mine is a couple degrees up but someone pointed out if I make it parallel with the TC then my angle will be even sharper on that second shaft (rearmost)
  7. Feb 10, 2019 at 7:36 PM
    #827
    slomoe
    Stuart,Fl
    I cant see any amount up being good, especially how the third member/pinion will move upward under any sort of load. Gotta get the pinion right, then mess with the cb to dial in the first and second shaft. Atleast thats how I see it.
  8. Feb 10, 2019 at 8:05 PM
    #828
    rmepilot
    Rob
    Huntsville, AL
    Rear pinion is a constant angle from the flange. When you lift the rear, the delta essentially remains the same, unless you have improperly manufactured and installed springs. However, you increase the operating angle of the u-joints. By shimming up, you attempt to maintain the original angle. I’ve had 2 different driveshaft companies tell me the same thing. Of course, all bets are off with a modded truck. Axle wrap on acceleration, shouldn’t be that much of an issue, unless your u-bolts are not at the proper torque.
    No amount of correction with overcome worn components, as with my original shaft had excessive play in the slip joint.
    I’m going to shim up, to prevent damage again, due to the 3” lift. I honestly can’t see where angling down the pinion on a lifted truck will do anything other than exceed u-joint operating angles. The geometry doesn’t add up.
    This is my opinion only, but YMMV.
  9. Feb 10, 2019 at 8:23 PM
    #829
    slomoe
    Stuart,Fl
    I agree with most of what your saying, especially about improper installation and or worn parts. Axle wrap may not exist all the time under any and all loads, but it does exist and I think will vary per leaf packs and there stiffness, oem, aftermarket etc..... Also just by lifting the rear of the truck/ lowering the rear axle, the pinion will automatically go up unless there were provisions built in the the leaf packs etc..... So would you not want to lower the pinion a little to bring it back into spec.
    I guess there are many variables based on different lift options and manufacturers of those products.
  10. Feb 10, 2019 at 8:33 PM
    #830
    rmepilot
    Rob
    Huntsville, AL
    I don't know what my original angle was, but after installing the 3 leave AAL, mine ended up at -.4*.
    Picture the aft shaft on a hinge, when you lower the axle (lift the truck) the pinion should naturally pivot up, but we're not allowing that to happen due to axle shelf/spring design. Thus the need for shims.
  11. Feb 10, 2019 at 8:45 PM
    #831
    slomoe
    Stuart,Fl
    I agree. It is still strange to me though that you ended up -4* (down). Mine is + 1.5* (up) requiring me to shim the pinion flange down. Having a hard time even finding a 1.5* shim let alone a steel one.
    Just getting started on the whole driveline vibes/ solution. Will post results when get some shims and throw them in.
  12. Feb 10, 2019 at 8:48 PM
    #832
    rmepilot
    Rob
    Huntsville, AL
    -0.4*
    Measurements taken with the DS removed.
    slomoe[QUOTED] likes this.
  13. Feb 11, 2019 at 1:34 PM
    #833
    chrispchicken9
    chrispchicken9 Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    I had a slight vibration at 20-25mph when I did my Add A Leaf. Added an extension to the drive shaft and it went away
    Pre runner, rwd though. Not sure how that correlates to your truck.
  14. Feb 11, 2019 at 1:47 PM
    #834
    rmepilot
    Rob
    Huntsville, AL
    Extension?
  15. Feb 14, 2019 at 8:43 PM
    #835
    3X4X4
    3X4X4 Well-Known Member
    JR
    KS
    2006 Indigo Ink Blue TRD O/R
    Snug Top, Toytec Ultimate Lift, SPC control arms, N-Fab light bar with Hella DL, Yakima rack, factory locker, Cooper AT3 265X75X16, TRD exhaust and front skid
    God knows this thread may never die.
    I lifted my truck, coil overs netting nearly 3 inches up front and the OEM SB pack with a ADL, about 1.5 inches up in the rear, I guess two years ago at 85,000 miles and now, today at 115,000 miles, under warranty, Toyota replaced the three U-joints in my drive shaft due to vibration and a squeaking noise.
    In the meantime, last summer we pulled our heavy 20 foot Boston Whaler 2,000 miles and the truck was LOADED. The OEM springs collapsed and the truck has been riding on the extended snubbers since. I had noted a small buzz way before the lift but it went away with the lift. But the last three months it got pretty bad.
    When I did the lift, I installed the front diff drop (yeah--yeah) and a CB drop. I did not install degree shims because I am of the school of thought that with a non double cardon drive shaft the TC and the rear diff pinion should be parallel more or less. I do have 2 and 3 degree shims in my glove compartment.
    Just last week, I had a local company build a new custom rear spring pack with additional lift (nearly 3 inches now over stock) and more overload capacity. Immediately I felt the truck was smoother but of course by now the drive shaft was a goner. So today, I pick the Tacoma up from the dealer, nothing has changed but for the warranty SB for replacement of the U joints, and it is back to being smooth as silk. My worn Cooper tires grind a little and I can feel the tread at slow speeds but I do not think that is the DS but just the aging tires. I am not sure I can feel a shudder as I start rolling or not, it may be the tires.
    I think my drive shaft U-joints were simply worn out, years of towing boats and coupled with the collapsed rear leaf finished them off. I am of a mind to carry on as is and not do anything further to the drive shaft arrangement and then get new tires for my new TRD Pro SEMA wheels.
    Or shim the pinion up, install a custom DC drive shaft or?
    My lifted Rubicon Jeep, custom Tom Woods DC shaft, I pointed the pinion at the transfer case (slightly below). So, this is not my first rodeo with lifted vehicles.
  16. Feb 14, 2019 at 8:48 PM
    #836
    rmepilot
    Rob
    Huntsville, AL
    I still plan on tilting the pinion up a few degrees, but mine is pointing down .4 now. My goal is to reduce the angle on the u-joint, as I think that wore out my old shaft.
    I have a light vibration below 25 mph.
  17. Feb 15, 2019 at 7:14 PM
    #837
    ThomasMore66
    Dallas/Fort Worth & Durango
    I’m just sayin that the torque converter lockup could be people’s issue. It was mine. After balancing driveshafts, replacing carrier bearings, checking angles, the new valve body is awesome. Like a new truck.
    rmepilot likes this.
  18. Feb 15, 2019 at 7:51 PM
    #838
    rmepilot
    Rob
    Huntsville, AL
    If tilting up doesn’t solve my issue, I’ll look there next.
  19. Feb 19, 2019 at 4:50 PM
    #839
    Nockturno
    Nockturno Well-Known Member
    2017 MGM Tacoma TRD Sport, DCSB, 6MT
    Looking for some smarter folks here. Installed OME HD dakar leafs 4 weeks ago (should have netted 2.75" lift, i have actually haven't measured since I did not measure prior to installing the lift), and noticed some vibration. Knew it was the drive-line, but didn't pay much attention since it was minor. Now 4 weeks later, and all the old suspension parts out of the bed and extras (150 lbs or so) and vibration at 15 - 25 mph slowling down is pretty bad. Bought a digital angle finder, and following OP I have the following angles:
    TC: 0.0
    First DS: 4.3
    Second DS: 10.8
    RD: 5.8
    First and second DS are way out of whack and need to work on correcting the problem. The OME CB drop is already installed, and I will shim it. Seeing the result of the shim, I will then work on adjusting the CB.
    I am thinking a 4 degree shim may do the trick, but maybe jumping down to a 3 degree shim and messing with CB might be my best solution. Thoughts?
  20. Feb 19, 2019 at 5:28 PM
    #840
    rmepilot
    Rob
    Huntsville, AL
    Use this app and be very meticulous when taking the readings:
    Did your truck had OEM shims with the original springs?
    If so, did you use them and/or are the installed in the correct direction.
    10.8 in the aft shaft seems very high, especially if you used the OME drop kit.
