Drive Shaft Vibrations Solved Step-by-Step
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TscotR214, Oct 18, 2012.
  1. Apr 5, 2023 at 9:16 PM
    #1101
    Desert Dog
    Desert Dog Well-Known Member
    Los Gatos
    2007 DCSB
    Work in progress
    Glad that worked. A CAD model is way to go since anytime you change the pinion angle, it lifts or drops the front of the rear differential and that changes the angle of the rear driveshaft so angle change at pinion u-joint is not the same as the shim angle. Plus it changes the angle at the center bearing when angle of rear shaft changes and you may need to try a few different shims sizes to get a good solution. You can do same calculation using trigonometry if you sketch it out and collect a lot more measurements than shaft angles.
  2. Apr 8, 2023 at 7:03 PM
    #1102
    Pacificclam
    Pacificclam Well-Known Member
    Carl
    Hawaii
    2010 Tacoma 4x4 Access cab
    6” pro comp lift Kings Coils and Shocks 700lbs Element UCA Atlas Leaf spring kit 17x9 stealth custom series ray 10s -38 33x12.5 toyo open country mt Tom woods driveshaft CSF high performance radiator 4.88 GEARS
    Tom woods is the only way to go. Especially if you have a lift. Truck feels so much better and responsive to the gas pedal imo
    mchabot1987[QUOTED] likes this.
  3. Apr 8, 2023 at 7:04 PM
    #1103
    Pacificclam
    Carl
    Hawaii
    if you have the money, get a custom Tom woods driveshaft… you won’t regret it at all and you will never deal with the Carrier bearing ever again lol
  4. May 22, 2023 at 11:48 AM
    #1104
    Dlongwfu1
    Dlongwfu1 Member
    Apparently not making rear DS for tacomas anymore
  5. May 22, 2023 at 6:02 PM
    #1105
    Draden
    Draden P911RSR
    Socal
    2015 Tacoma DCSB "Off Road" 4.0L
    just as a quick mention since nobody else is mentioning it.... consider new U joints whenever a change has been made. when i lifted mine, it seems the old u joints were maybe worn to the angles they were use to before the lift. i tried a lot of things too. but then by merely replacing the u joints on both ends of the last shaft, everything is like new and not a single hint of vibration. just sayin you never know.
    Blisterinthesun likes this.
  6. May 25, 2023 at 5:57 PM
    #1106
    mchabot1987
    mchabot1987 Well-Known Member
    Elizabeth City, NC
    2017 Super White TRD Sport DCLB
    Yes
    Complete bullshit for real. I was about to buy one this year.
  7. May 25, 2023 at 6:31 PM
    #1107
    Dlongwfu1
    Dlongwfu1 Member
    I just purchased one from Panhandle Driveline in Panama City. Same thing. 3.5 in Double Cardan single piece DS. Should be installing this weekend.
  8. May 26, 2023 at 5:16 AM
    #1108
    mchabot1987
    Elizabeth City, NC
    Yes
    Do they have a website? All I could find was a FB account. Did you just give them all the dimensions and whatnot?
  9. May 26, 2023 at 1:13 PM
    #1109
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    From Tom Wood's website:
    *Discontinued*
    Due to this product's inability to fix Tacoma drive shaft vibrations 100% of the time, and because of the extra costs incurred by us and our customers when handling returns when they don't work as expected, this drive shaft has been discontinued. Sorry, I know some of you were looking forward to getting one of these shafts. No, we cannot make exceptions and just make you one anyway, even if you really really want us to.
    This really is a bummer. I'm sad they went through issues and resorted to doing away with this. I have their DS and it rid me of vibes completely.
  10. May 26, 2023 at 2:11 PM
    #1110
    Dlongwfu1
    Dlongwfu1 Member
    Just got the new DS from Panhandle Driveline. Thought I’d share some pics. I wish it were Coated/painted but I guess a lot of DS arent?
  11. May 26, 2023 at 2:15 PM
    #1111
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Is it industry norm to spot weld a washer to the DS in order to balance it? I guess it isn't much different from the square weights I'm used to seeing.... just wondering.
  12. May 26, 2023 at 2:34 PM
    #1112
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    yup tacked round weights are normal, it’s not a washer it is a drilled slug
    grab a can of por15 spray paint or similar and spray it before you install it
    SUMOTNK[QUOTED] likes this.
  13. May 26, 2023 at 2:41 PM
    #1113
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    average idiots ruining it for everyone else, i’ve seen a ton of threads over the years and without fail folks miss two key points:
    1. rear pinion angle for a one piece dc needs to be right up the shaft
    2. with 4:56 gears you hit mph limitations
    anyone returning one saying they still have vibes is an idiot it’s impossible when properly installed
    Dlongwfu1 and SUMOTNK like this.
  14. May 26, 2023 at 2:44 PM
    #1114
    Dlongwfu1
    Dlongwfu1 Member
    Should anything be done here to protect from elements? This was previously covered by the old DS but now is exposed.
  15. May 30, 2023 at 7:38 PM
    #1115
    Pacificclam
    Carl
    Hawaii
    Wow what a bummer.... Im sure other companies will step up and start though. Just a matter of time.
  16. Jun 1, 2023 at 5:22 PM
    #1116
    Potamus
    Potamus Well-Known Member
    Keith
    Oregon
    2022 Limited Blue Crush Metalic
    2.75 lift on 33s
    IMG_8418.jpg So this is the measurements I’m getting. I tried with zeroing from the rear flange on my third attempt and the anngles are pretty consistent.
    I’m thinking 2.5 degree shims should fix the vibes.
    I took it to 4WP to get an opinion and the tech said that it’s probably not a shim and just needs a carrier bearing drop. I’ve read a few that were successful going with a drop, but it seems like more sense to fix the rear pinion angle, even though the CB drop would be so much easier.
    looking for some solid advice, if anyone is knowledgeable. Thanks.
  17. Jun 10, 2023 at 2:24 PM
    #1117
    The605taco
    The605taco Well-Known Member
    Sawyer
    2014 4X4 short bed
    6112(notch 3) 5160 icon AAL Baja fogs and Ditch lights Headwaters seat covers Off roam phone mount Diamond back cover
    I just wanted to pipe in on my experience with vibrations. I installed an icon RTX pack with vibrations around that 18 mph mark and in the 60’s. After some off road and flexing I re torqued the u bolts. I then did install a CB drop due to binding I was feeling at low speeds and I’m sure was happening at higher speeds.
    After much research on this topic and my own experiences with the issue. It comes down to having the u bolts torques correct and not have any stretching of the drive shafts.
    Vibrations could also be caused by the axle wrap caused by acceleration. This phenomenon occurs most likely when one has a ubolt flip kit installed.
  18. Jun 12, 2023 at 9:00 AM
    #1118
    rolot2
    rolot2 Well-Known Member
    Rolando
    Denver, CO
    2015 TRD OR DCSB
    Front: Extended Travel 2.5” King coilovers with/adjusters (Set at 3” lift) Rear: 2.0” King shocks with adjusters Icon RXT (Option 2) Pack Toyota TRD Cat-back exhaust AnytimeBackup Camera Anytime Front/Rear Camera RCI Sliders KB Voodoo Bed Rack Center Console Ram Mount
    I have the same icon pack. My only vibration is at take off. All u bolts are correctly torqued. I’m think these springs are just not as good at preventing axle wrap as others. Any thoughts?
  19. Jun 12, 2023 at 12:31 PM
    #1119
    The605taco
    Sawyer
    2014 4X4 short bed
    When did you tuque the u bolts? I found that after the initial install I had to re-tuque them three times before they stoped moving and vibrations quit.
  20. Jun 12, 2023 at 1:04 PM
    #1120
    rolot2
    Rolando
    Denver, CO
    2015 TRD OR DCSB
    Just retorqued them the other day. Vibration did not change at all
