Drive Shaft Vibrations Solved Step-by-Step
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TscotR214, Oct 18, 2012.
  1. Jul 26, 2023 at 5:42 PM
    #1141
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Good to know.
    I've only been up to 50 with it and has smoothed out what I was feeling.
    Perhaps it'll show at higher speeds.
  2. Jul 30, 2023 at 6:38 AM
    #1142
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    So I downloaded an inclinometer app and used this video for reference.
    1.5" rear lift without cb spacer. With that wedge that's been under the leaf pack. My numbers come out pretty flippin good. The addition of a cb spacer was no bueno.
    https://youtu.be/f1m-Fh5kiRU
    1st underline number s/b within 0.5- 0.8deg
    2nd and 3rd underlined s/b equal.
    (working angles) and between 1-3deg.
    birry[QUOTED] likes this.
  3. Jul 31, 2023 at 7:49 AM
    #1143
    WGS84
    WGS84 Member
    Jay
    Iowa
    2013 DCSB TRD-OR, black
    OME 885/5100, SPC UCAs, 5100/Dakar HD
    How are folks getting accurate measurements on the two flanges? The video above shows a phone up against the edge. I've tried that, as well as a small digital angle finder/level, but I can't seem to get it flush against the edge, to where I can get an accurate/repeatable number. Does the driveshaft have to be in any particular orientation (ie: do the yokes need to be centered/pointing straight down to the ground)?
  4. Jul 31, 2023 at 8:06 AM
    #1144
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I happened to be using a flat carpenters pencil to write so I was able to slide that against it and hold the phone against the pencil.
    If that aluminum block was my phone/level.....
  5. Jul 31, 2023 at 9:19 AM
    #1145
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    I'm half-joking, half-serious here: I can tell that this is the correct way to approach this problem just from the clarity & orderliness of your penmanship. Will be using this method to track down a very quiet slow-periodic (peaking every 2 seconds or so) driveline vibe I can only hear on completely smooth pavement, coasting in 2nd/3rd gear, under 30 mph. This vibe began after lifting ~1.5" front w/ FOX 2.5's, and 2.5" to 3" rear w/ FOX 2.5's and Deaver stage III's.
  6. Jul 31, 2023 at 9:30 AM
    #1146
    WGS84
    WGS84 Member
    Jay
    Iowa
    Thanks for the pictures, @bkhlrTaco's - much appreciated.
    bkhlrTaco's likes this.
  7. Jul 31, 2023 at 10:15 AM
    #1147
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    His truck probably still vibes a little too. lol. It's a truck and there's probably always going to be a little if you feel hard enough for it.
    As long as Front ujoint is around .5deg and center to rear are equal, and between 1-3deg, you're O.K.
    I drive mine to work. lol
  8. Jul 31, 2023 at 10:22 AM
    #1148
    GilbertOz
    GilbertOz Driver
    CA
    Not on my watch! There were no noticeable vibrations for the 12K miles I owned & drove the truck on stock suspension & ride height.
  9. Jul 31, 2023 at 10:27 AM
    #1149
    ardrummer292
    ardrummer292 500k or bust
    Austin
    ESVA
    2015 DCLB V6 A/T 4x4, 2011 Camry LE
    Overbuilt daily driver
    Some guys in this thread have had mixed results using my method, so don't take my word as gospel. I taught myself all of this stuff just like (almost) everyone else here.
    Mine has zero detectable vibes*, regardless of speed or how hard I mash the skinny pedal. I'm paranoid about any feedback from my vehicle, so I'm sure I would notice if something was off.
    *I'm gonna go knock on wood, like right now.
    bkhlrTaco's[QUOTED] likes this.
  10. Jul 31, 2023 at 10:34 AM
    #1150
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Mine had zero detectable vibes too until I started using T.W. heh
    Now I notice every little noise.
    henryp likes this.
  11. Jul 31, 2023 at 1:22 PM
    #1151
    Potamus
    Potamus Well-Known Member
    Keith
    Oregon
    2022 Limited Blue Crush Metalic
    2.75 lift on 33s
    I used a 90 degree T angle. The magnetic edge of the angle finder sticks to it, then you can put the other end of the t flush against the flange.
  12. Sep 9, 2023 at 5:27 PM
    #1152
    otherphone
    otherphone Well-Known Member
    MA
    09 tacoma sport
    OME2.5lift w/medium leafs
    My Ujoints squeak in reverse (but they already did b4 the 2.5” lift). After the lift it had a tiny vibration but I think going from 30.5” tires to 32s totally fixed the vibration. Still need to replace the ujoints because they squeak though. I did put in the 8mm spaced that came with the kit just because it said to
  13. Sep 10, 2023 at 2:36 PM
    #1153
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Got a question for y’all.
    I’ve been trying to chase down some high speed vibrations, at about 65-85mph.
    I took measurements of my driveline based on this post:
    Truck: 2012 DCLB prerunner, 2wd
    Pretty new carrier bearing with less than 10000 miles on it. Fresh rebuild driveline with a slip yolk added in the rear section by a competent driveline shop in Southern California at that time too.
    • The difference in degrees from the output flange on my 2wd prerunner DCLB to the rear axle third member is -0.90°.
    So my axle input is pointed upwards at a steeper angle by almost a degree relative to the trans output.
    • The difference in angle between the front and rear driveshaft is exactly 0.0°. They are dead even.
    I am still a Little confused on where everything should sit.. do these numbers seem ok? Or would the -0.90° difference cause pretty harsh vibes at freeways speeds?
    If so, not sure how I would go about correcting a negative 1 degree. Install an axle shim backwards ?! That does not seem like a good idea lol.
    TY in advance tacomaworld.
  14. Sep 10, 2023 at 3:12 PM
    #1154
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    My post above #1142 is what I went by. Shouldn't be at 0 anywhere, from my understanding.
  15. Sep 12, 2023 at 3:21 PM
    #1155
    M37r1c
    M37r1c Well-Known Member
    Rob
    2008 Toyota Tacoma RC 4x4
    So I'm currently dealing with a vibration at around 60-65 mph and a grinding noise when I coast between 70-60 mph. Many have said that carrier bearings and the such need to be adjusted but I don't have that as I got a single cab. Really am wanting to fix this this coming week as its been like this for a while and I have some down time. I took pictures of my angles, not sure if they are correct but I can always crawl back down there and redo it if I need to.
    I ended up zeroing out the angle app at the Transfer Case on a flat surface then got the angles on the image below. I got a shot of my driveline and my suspension also in case that adds some context. Truck has a 3 leaf wheelers add a leaf kit and Bilstein 5100s in the rear. All the U joints were replaced with Spicer units and are greased every oil change.
    Are shims needed to get within spec for the vibrations to go away or is something else needed such as removing the overload leaf? Thanks for all your help guys!
  16. Sep 14, 2023 at 6:34 AM
    #1156
    M37r1c
    Rob
    Doing some searching it seems that a 3 degree shim should be used. I'm wondering though if to correct that I could remove the overload leaf. Are there many that are running that overload leaf and that causing minor vibrations to go away?
  17. Sep 14, 2023 at 8:52 AM
    #1157
    Potamus
    Keith
    Oregon
    2.75 lift on 33s
    You will still have the vibrations, even with the overload leaf removed.
    If you measure after taking it out, you will might end up needing 2.5 degree shims.
  18. Sep 14, 2023 at 10:46 AM
    #1158
    M37r1c
    Rob
    So I'm guessing that the idea would be to zero out at the TC and the diff?
  19. Sep 16, 2023 at 2:16 PM
    #1159
    M37r1c
    Rob
    Any answers? Most the comments here I find are for 2 piece shafts....truck is going in the shop here soon and I'd like to get the right shims. Sorry if being a bit demanding...
  20. Sep 17, 2023 at 9:54 AM
    #1160
    Sterling_vH111
    Sterling
    socal
    i really don’t know enough to give good advise, but if you’ve taken measurements and see that the working angle of the x-fer case is 9°, and that the working angle of the rear diff is 6° (9°-3°) — sounds like a 3° shim should work.
    only thing I’m a little gray on and have trouble picturing if I’m not literally looking at my own truck with an angle finder,is that I would ensure a 3° shim would actually get you angles to match, and not put it further out of spec. Ie. 9° & 9° Not 9° & 3°.
