Drive shaft zerks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mickeyman, Oct 3, 2016.
  1. Oct 6, 2016 at 12:18 PM
    #41
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
  2. Oct 6, 2016 at 12:21 PM
    #42
    Mush Mouse
    mush
    2013 SR5
    this is why I do my own oil change/maintainence, unfortunately not everyone has the options of doing it themselves and have to rely on service centers to do it
    #42
  3. Oct 6, 2016 at 12:25 PM
    #43
    Mush Mouse
    mush
    2013 SR5
    it used to be pretty common to get an grease job with an oil change for some unknown reason all these service providers stopped this? why?
  4. Oct 6, 2016 at 2:08 PM
    #44
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    well thats a Honda. I was referring to real trucks
  5. Apr 1, 2018 at 8:52 AM
    #45
    MarcoTaco
    MarcoTaco Active Member
    Mark
    South Maryland
    2017 TRD Sport Taco 4x4 Acc Cab A/T V6
    Hellwig rear leaf, BFG 265/70 KO2 tires, Method rims, Bilstein 5100 frt struts, OVT
    I dont wanna bust in uninvited but after 7k miles on my 17 TRD Sport, i crawled under to assess the situation. Im not impressed.
    The front shaft has a sngle Zerk on the joints at each end. The front fitting was not too hard to service - however - it was obvious that nether Zerk had ever been greased - from assembly until now. They were Sahara dry.
    The rearward Zerk on the front shaft was almost impossible to access or see. I use a Amsoil blue grease, injected via a hand gun setup with a long flex hose.
    The trucks cross-member, shields, and “work by feeling only” hurtles made a mess - and took me a while to service & clean up....but I managed to get it done. Strange that they put fittings only on the front shaft joints.
    The rear drive shaft has no Zerks on it- AT ALL. Personally - Even considering the pitch offered by those saying that the non- servicable joints last for extended miles - I want zerks.
    Illusion or not, I like to be confident that I am rolling in top shape (as much as is possible). Rolling resistence is never good - and worn out joints are never convenient to have to stop and deal with.
    So Im adding this minor hit to my list of things that Toyota cut corners on with respect to my truck anyway ,IMHO.
  6. Apr 1, 2018 at 9:35 AM
    #46
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    https://www.danaaftermarket.com/search?cat1=115&from=0&y=2017&mk=Toyota&md=Tacoma
  7. Apr 1, 2018 at 2:53 PM
    #47
    Worrom1
    Worrom1 Well-Known Member
    16 taco 4 door lwb
    3inch pro comp with all 265/75/16 BFG AT
    Made 1-16 5 zerks
    bobrown14 likes this.
  8. Apr 1, 2018 at 3:26 PM
    #48
    I am Root
    I am Root UID 0
    Root
    I am root
  9. Apr 1, 2018 at 8:51 PM
    #49
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  10. Apr 1, 2018 at 11:05 PM
    #50
    strktly_bodysurf
    strktly_bodysurf Well-Known Member
    The hell is going on here?! I didn't even know these things required grease. You guys are awesome. Thanks for the fun reading and quality info :cheers:
  11. May 9, 2018 at 10:50 AM
    #51
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Hey bro - that shield comes off with a 12mm socket - don't even need a needle nose grease fitting... its a slight PITA to get the shield back on but a lot easier and less messy that trying how you did it.
    2016Tacoman likes this.
  12. May 29, 2018 at 1:09 PM
    #52
    MarcoTaco
    Mark
    South Maryland
    Thanks for your reply.
    I do appreciate it.
    MSJ
