drive shaft?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TXFLDVR, Jan 20, 2023.
  1. Jan 20, 2023 at 11:55 AM
    TXFLDVR
    TXFLDVR [OP] New Member
    12pre4cyl
    The carrier bearing (center) has worn out and needs replace.145k. I have pro comp add a leaf. could this be the reason it wore out? I have seen on the internet that guys are replacing the drive line with a 1 peice shaft. Is this good bad why? Thanks
    Robnik likes this.
  2. Jan 20, 2023 at 12:00 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    145k...imagine how many revolutions that drive shaft has made
    Robnik and Squirt like this.
  3. Jan 20, 2023 at 12:03 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    naw CB'd are known to go out. If you are a 2WD 6 lug truck you are limited to the standard doughnut style CB. Replace it and all rear U joints with spicer units and call it good.
    TnShooter and Robnik like this.
  4. Jan 20, 2023 at 12:19 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Those dual shafts are not good. Carrier bearing always goes out.
    That's why I insist on keeping my regular cab. One piece driveshaft.
    I'd suggest a one piece shaft with Zerk fittings. Good luck in your endeavour. :)
    HondaGM likes this.
  5. Jan 20, 2023 at 1:17 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I believe most guys that replace their shafts with a one piece shaft are trying to rid themselves of driveshaft vibrations, mainly due to lifting their trucks, not necessarily to bypass the carrier bearing alone. If your carrier bearing wore out, just replace it and move on. It happens.
    AllTacosFloat and TnShooter like this.
