Drive train locked up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thebenge, Jul 20, 2025.
  1. Jul 20, 2025 at 4:35 PM
    thebenge
    thebenge [OP] Member
    2006, 6-speed manual transmission. I jumped in today to drive, put it in reverse, heard a loud pop come from underneath somewhere, and when I gave it gas to reverse, the vehicle wouldn't move. It wasn't that the gear wasn't engaged, because I clearly felt resistance when giving it gas. Put it in first to move forward, and same result; felt resistance to move while giving it gas. It felt like i had a chock block under my tires (but obviously didn't).So I put it in neutral, jumped out and rocked it gently back and forth until I heard another pop, and then it moved freely as designed. Drove off with no issues. No strange feeling in the gears, no popping noises. Nothing. Anyone have any idea what it could have been? Something I need to worry about?
  2. Jul 20, 2025 at 4:40 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Possibly rear drums were sticking.
  3. Jul 20, 2025 at 4:46 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Did you set the ebrake right after driving or with the brakes wet. Every now again sometime the rear shoes will bake themselves to the rear drums.
    thebenge[OP] likes this.
  4. Jul 20, 2025 at 6:06 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    was this after washing the truck and letting it sit overnight?
  5. Jul 20, 2025 at 10:35 PM
    thebenge
    Last time I drove it was in the rain in the evening. Got home, set the e-brake. Temp got over 100 the next day. Maybe it was the brakes
  6. Jul 20, 2025 at 10:36 PM
    thebenge
    Drove home in the rain, and then it sat. Basically the same thing
  7. Jul 21, 2025 at 12:35 AM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Mine will do that occasionally. Takes a little pop to unlock it. Has done that rarely for several years with no ill effect. I set the parking brake every time I drive it and figure it just hangs up at times.
  8. Jul 21, 2025 at 12:51 AM
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    mine does that, or similar to what you explained. I think it's the parking brake.
  9. Jul 21, 2025 at 7:33 AM
    OffroadToy
    Happened to my 07 after washing/sitting overnight. This was probably around 2008 or 09... hasn't happened since.
    thebenge[QUOTED][OP] likes this.
  10. Jul 21, 2025 at 10:51 AM
    gotoman1969
    Yep. That can do it.
  11. Jul 21, 2025 at 11:11 AM
    Richard009
    Richard009 Active Member
    09 Access Cab manual V6
    Can't wait to start!
    I had that happen to me in the last few months, once released it was fine. Then last week after re-adjusting the drum brakes one would always grab going forward and I discovered one of my parking brake cables is seized in the engaged position. I just ordered the parts so can't tell if that is the problem, but might be worth checking yours.
  12. Jul 21, 2025 at 11:17 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Parking brake cables are notorious for getting sticky on these trucks, I had to replace the driver's side on mine
    It was probably the brakes. If something was broken in the transmission or drivetrain it would likely be making noise as you drive
  13. Jul 21, 2025 at 11:18 AM
    Clearwater Bill
    Billy
    Largo Florida
    Yep. Far different than 'drive train locked up'.
    Some folks use 4wd to help pop them loose if it's really bad.
    But on a 19 yo model, I'd be examining the ebrake system and all the drum internals to make sure all is in clean, lubed and adjusted properly. Especially if it's lived in salt land.
    Really, just routine maintenance.
  14. Jul 21, 2025 at 8:34 PM
    thebenge
    Yeah, my E-brake has seemed off as of late. I'll take your recommendation and have the brakes looked at. Thank you for the input
