drive train vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cushman, Apr 3, 2012.
  1. Apr 3, 2012 at 1:31 PM
    Cushman
    Cushman [OP] New Member
    Mojave Desert
    2012 Tacoma TRD OFFROAD
    I am experiencing subtle vibration in drive train when I accelerate hard from slow speed. Anyone experience similar or have thoughts?
    many thanks!!
  2. Apr 3, 2012 at 1:32 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Is your truck stock or have you added mods?
  3. Apr 3, 2012 at 3:22 PM
    lonecountryboy
    lonecountryboy Well-Known Member
  4. Apr 4, 2012 at 5:54 PM
    Cushman
    Mojave Desert
    Thanks you guys!
    Truck is stock, 1500 miles so far.
    The background information was very helpful and appropriate. Before I get my creeper, I think I may give the OEM an opportunity to address the issue.
    Wish me luck...
  5. Apr 4, 2012 at 8:17 PM
    seric007
    seric007 Well-Known Member
    I dub this, the official 10 stages of Stock Driveline Vibration
    good luck (my advice, jump to step 10) :D
    1. first your going to go in and the dealership will tell you its normal
    2. then your going go back and say its not, they will look at it.. test drive it and tell you they cant feel the vibration
    :argue:
    3. you will drive for several more days as the vibration gnaws at the core of your very soul.
    :frusty:
    4. you will go back, again and now their "master tech" will say, "o yeah its a problem but, we call it a characteristic of the vehicle".. again you will leave
    :censored:
    5. a couple days and 4000k shudders later you will escalate it to Toyota customer service in a rage-frustration fit....
    :rant:
    6. then you will go back toyota and the dealership will "drop your axel and put you in 4hi" to confirm its the rear driveshaft, then they will promptly replace your rear driveshaft
    :wink:
    7. you will leave happy...
    :yay:
    thinking problem gone
    but its not.....
    :facepalm:
    9. you will go back and toyota will send out a 50 man team of "engineers" out that will do nothing more then spend days with your truck scratching their head....
    :pray:
    10. you will inevitably get frustrated and give up after spending the equivalent of 10 days of your time and skipping out early on work several times to "drop the truck off", learning to deal with the vibration/shudder.
    :proposetoast:
    OR (Secret step 11) Design you own Custom solid 1 piece drive shaft with a CV joint (sorry prerunners) from a 1999 4runner and call it a day. ;)
  6. Apr 14, 2012 at 2:09 PM
    MotorsportsAustin
    MotorsportsAustin Well-Known Member
    Austin
    Belmont, CA
    2012 Off Road 6spd
    I'm on #6, and they're saying they won't replace the driveshaft - they want me to drive it for 5000 miles... then they'll probably tell me it's the tires. Spoke to Toyota yesterday - they'll either fix it now or buy it back from me. More news in the other thread hopefully next week.
    Too bad too, I like this truck aside from the incessant faulty drive shaft prob.
    If I end up getting refunded by Toyota, this will be my first and last. And, AEV will get my money (and a little more money) http://www.aev-conversions.com/vehicles/aev-brute-double-cab
  7. Apr 14, 2012 at 2:36 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    i honestly think the rubber that surrounds the carrier bearing is way too soft for this application. it flexes too much even when new
  8. Apr 14, 2012 at 6:41 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I put a clamp on both leaf springs to help with axle wrap and now I get a vibration at 25-30 mph. It goes away above and below that though. I'm keeping them because they certainly help with axle wrap on hard acceleration and braking.
  9. Apr 15, 2012 at 8:11 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Did you just clamp the front of both leaf packs? That will change your pinion angle cause this. Why not clamp front and rear and see what hapens?
