Driveline angles - sanity check
Discussion in '1st Gen. Tacomas (1995-2004)' started by Andy01DblCabTacoma, May 5, 2022.
  1. May 8, 2022 at 8:48 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma [OP] Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I crossed this off the list by replacing the entire drive shaft.
  2. May 8, 2022 at 8:50 PM
    saint277
    saint277 Vigilo Confido
    hows the fight going?
  3. May 8, 2022 at 9:21 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Not to suggest overly simple things as you’ve clearly been chasing this for a while: what about tires, worn suspension components, anything else front end original wear items?
    Where do you feel the vibration? Seat or steering wheel?
  4. May 9, 2022 at 9:22 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I feel the vibration through the cab. Not the steering wheel.
    Things have recently (within in the last year) been updated:
    New wheels and tires (pro comp 7069 + 265/75/16 Goodyear workhorse), road force balanced.
    Front suspension - new upper (ES) and lower (Whiteline) control arm bushings, upper and lower ball joints (OEM), outer tie rods(OEM), rebuilt king c/os + replaced the coil springs, new wheel bearings & seals(OEM), calipers, rotors, brake pads, and SS brake lines.
    Rear suspension - new leaf packs, new u bolts (x2), new shackles (x3) bushings and bolts, replaced wheel bearings & seals (OEM), new wheel cylinders (OEM), shoes (OEM), had the drums turned, new SS brake line.
    New Drive shaft pro drive shaft, new transmission mount.
    I was able to put some miles on it over the weekend after I swapped in the 4 degree shim. The pinion angle matched the drive shaft exactly. It's better but not perfect. Once things settled with the new shackles, it was lower than reported on Thursday. But now I need to lower the front a touch to things to where I like them.
    The really strange thing with this vibration now, is that I noticed it really only occurs on concrete sections of the freeway, while it feels perfect on the paved sections.
  5. May 9, 2022 at 10:34 AM
    MalinoisDad
    Michael
    If it feels perfect on pavement and not on concrete, that sounds like tire characteristics to me. If so, I would be happy with that. Different tires may make it disappear entirely.
  6. May 9, 2022 at 11:09 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I can swap the old set on and test- but don't think the new tires are the problem. I had bought them from a local place but they were way understaffed and did a real shit job balancing them so I took them to Discount Tire for a road force balance and specifically asked if there were any additional issues with the tires or wheels which might cause vibrations- and they said they were easily able to balance them.
    At this point, I think I am going to put a go pro under the truck and go for a drive...
  7. May 9, 2022 at 11:45 AM
    saint277
    so you ended up at option 1?
  8. Jan 27, 2023 at 4:11 PM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    Revival
    How has the good fight gone? Ever come to any solutions?
    I am having similar problems with my lifted single cab 96. and I’ve chased down, seemingly, everything at this point (at one point I even discovered that my mounting plate for my driveshaft at the transmission had become loose and I had to re set that).
    I am now leaning towards something being bent that I haven’t discovered. I’m going to swap my wheels from my 01 onto my 96 (problem child) and see if it is something more simple than I’ve thought. I’ve always had the same wheels on it and maybe with the new suspension I am feeling a bent rim more.
    I’m also thinking back to something another user mentioned when I discovered the transmission plate issue, is that maybe my transmission got toasted before I discovered that.
    either way I feel your pain, I’m just glad I have my 01 which has been treating me well. Now I’m driving my 96 more and want to get it ready for wheeling and I just want to not feel like I’m going to rattle apart on the highway.
  9. Jan 27, 2023 at 4:31 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I ended up with 2 degree shims. After all that, the rear brakes were essentially out of round. With the tires off the ground, while turning the wheels, I could feel the shoes drag on the drum in three specific locations on one side, and two on the other. I replaced the shoes and drums with Napa parts, and it's smooth ever since. Going back- when I rebuilt the axle, I got new Toyota shoes, and turned my original drums. I am not sure if the shop did a crappy job turning them or what.
    96BlueTacos likes this.
  10. Jan 27, 2023 at 5:47 PM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    I have never checked my rear drums…
  11. Feb 17, 2023 at 10:16 AM
    Potamus
    Potamus Well-Known Member
    Keith
    Oregon
    2022 Limited Blue Crush Metalic
    2.75 lift on 33s
    what’s funny is that well after this post Toyota released a TSB for vibrating at 10-30mph. Part of the diagnosis is to remove the DS and see if the vibration goes away.
    It’s like saying that it’s the drive shaft without actually saying it’s the drive shaft. The fix is a new spring pack that “fixes” the DS angle, and a damper in the steering column. Essentially, they are fixing the symptoms.
  12. Feb 17, 2023 at 10:23 AM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Tom woods one piece ?
  13. Feb 17, 2023 at 1:30 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    96BlueTacos and GilbertOz like this.
  14. Feb 17, 2023 at 3:15 PM
    Sebz13
    Shane
    Maui Hawaii
  15. Feb 17, 2023 at 3:25 PM
    #35
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I don't think we need to beat a :deadhorse: here.. The post thread has all the info. The drums were OEM, and I had them turned when I rebuilt the rear end. New shoes. Not sure what happened but between that work, the ended up dragging on the shoes in three different places per rotation. Replaced the drums and shoes, and it fixed everything. Been smooth sailing since then.
