Driveline Clunk Possibilitys?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bgarner1542, Sep 23, 2019.
  1. Sep 23, 2019 at 10:43 PM
    bgarner1542
    bgarner1542 [OP] Member
    Brayden
    1999 Burgundy Prerunner SR5
    Hi all, I have a 99 sr5 prerunner. I have trying to figure out where this clunk in coming from. 8 times out of 10 when i come to a stop and let off the brake i will feel a light thump in my driveline. And another way i can feel it is when i’m going 65 or so down the highway and i can let off the gas. and feel no thump. when i do that. but if i tap the gas quickly i will also feel the thump.
    i don’t think it would be axle wrap because i just replaced my whole rear end suspension with 5100s and deaver j59s.
    I have replaced my center driveshaft support bearing. it made my highway vibs go away but didn’t help the thump.
    what i think it could possibly be is my transmission rubber mount thing. i can go under and push around on my driveline and it has the most play. the center bolt is like halfway out. which seems to be the case on everyone else’s truck.
    i have also greased all the fittings. i wasn’t sure how much to put in the slip yoke because i put a solid 10 pump and it didn’t bleed out. so i stopped. the greasing didnt change anything.
    so all in all, i’m pretty stumped on what it could be. my guess would be that trans mount.
    if it matters i have the a340e trans. and i have a regear from ECGS.
  2. Sep 24, 2019 at 6:11 AM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    My vote is the rear Trans mount.
  3. Sep 24, 2019 at 6:19 AM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    Bad u-joints can cause that, but so can the trans mount. If you think that mount is bad, replace it and see what happens
  4. Sep 24, 2019 at 7:45 AM
    04taccoo
    04taccoo Well-Known Member
    Cyrus
    San Diego
    2004 Tacoma prerunner 4x4 double cab
    4x4 conversion
    Same thing happens to me
  5. Sep 24, 2019 at 10:08 AM
    bgarner1542
    Brayden
    I will order a trans mount. how much grease goes in the slip yoke?
  6. Sep 24, 2019 at 10:17 AM
    Stitz
    Stitz Well-Known Member
    South Jersey
    2024 TRD OR Supersonic
    I've got the clunk (sounds like an STD, hah) from standstill takeoff only. Haven't had time to address it yet but everything I've read points to slip yoke. You have to take apart the driveshaft and lube it with PTFE grease, not zerk-able. This guy has a good video demo on process
    https://www.youtube.com/watch?v=AvKwgjpsbdg
    Black DOG Lila likes this.
  7. Sep 24, 2019 at 10:32 AM
    bgarner1542
    Brayden
    that seems like the case. but my driveshaft looks nothing like that. the guy has a second gen so it’s different when it comes to that rubber boot. mine has the zerk for the yoke and i know it was pumping inside it. i just didn’t know how much to put in there
  8. Sep 24, 2019 at 1:15 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    3 or 4 pumps max is general concensus on TW. Too much can cause shaft to bottom out in the yolk resulting in a thump sound. Once you get the thump you have to disassemble/clean and grease with Ford PTFE by hand.
  9. Sep 25, 2019 at 6:56 AM
    1997tacomav6
    Denver
    There a good chance it’s in the Cardan joint. This joint has a zerk that gets missed when the un joints
    are greases because it’s hidden and the joint gets worn out. Have you greased this joint?
  10. Sep 25, 2019 at 8:06 AM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    agree on this. And it can be hard to get a grease gun on there too. A “Lock N Lube” grease gun tip makes it A LOT easier to grease. Pic of the cardan zerk for reference.
    LockNLube Grease Coupler locks onto Zerk fittings. Grease goes in, not on the machine. World's best-selling original locking grease coupler. Rated 10,000 PSI. Long-lasting rebuildable tool. https://www.amazon.com/dp/B00H7LPKKU/ref=cm_sw_r_cp_api_i_0h4IDbT2SADNW
  11. Sep 25, 2019 at 11:41 AM
    Tacowaco
    Tacowaco Well-Known Member
    Tallahassee, FL
    02 Tacoma Double Cab 4x4
    I had a clunk also, my research showed it could be a rear tranny mount or worn carrier bearing. I replaced the bearing (Rockauto spicer $59) and the clunk is gone, it was as OP described, at stop when releasing the brake.
    DLtaco02 likes this.
  12. Sep 25, 2019 at 2:37 PM
    DLtaco02
    DLtaco02 Active Member
    Dan-yoh
    San Diego
    1999 XcabLB V6 prerunner
    Front - Fox 2.0 coil overs Rear - RC N3 shocks Tires - 265 75 16 BFG KM2
    I've also heard that it could be old leaf springs. I have the same problem. 270k and the leafs look flatter than a skinny chick's chest in spandex lol
    04taccoo likes this.
  13. Sep 25, 2019 at 2:53 PM
    itsmerandy
    itsmerandy Well-Known Member
    Kentucky
  14. Sep 25, 2019 at 3:04 PM
    eon_blue
    Azusa, CA
    Yes the slip yoke must be taken apart to be properly greased. Clunking and that loud "TING" sound when moving forward or reverse is usually associated with a slip yoke that needs to be properly greased.
    What the OP is describing though sounds like axle wrap to me. 1st gen Tacomas are notorious for it. The leaf springs bind up and then release when you come to a stop and it creates a feeling like you've been tapped from behind by another car. Beefier leaf springs should help
  15. Sep 25, 2019 at 5:56 PM
    bgarner1542
    Brayden
    I will look into that camden joint. i have replaced to beefier leafs. it did help but not a lot. carrier bearing fixed highway vibs. i will take the rear drive shaft out and manually grease it one day. so maybe the trans mount plus the slip yoke grease will fix this issue. thanks for the replies. any more would help as well
