Driveline Clunk When Stopping/Starting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gergg, May 23, 2013.
  1. May 23, 2013 at 6:39 PM
    gergg
    gergg [OP] Member
    Georgia
    06 Dbl Cab 4wd
    Small Lift, 265x70x17 tires, Pro Comp 17" Wheels
    Hello All,
    This is my second post here, been lurking for a while, now have a question. Purchased a 2006 Tacoma DCSB TRD OffRoad 4wd 115,000 miles.....I did a bit of research so knew about the different potential problems, well mine has the driveline clunk when coming to a stop and then starting again, I found a TSB which seems to relate to this issue, but have no idea if there is any potential help/remedy from Toyota for this problem. Any thoughts/help would be appreciated. Oh yeah, LOVE the truck
    2006 Toyota Tacoma Power Train Service Bulletin 344147
    NHTSA: Action Number: 10050665 Service Bulletin Number: 344147
  2. May 23, 2013 at 6:45 PM
    Nick54
    Nick54 Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    Not sure what your specific issue is but sometimes the driveshaft splines get dry and will pop when the stored up energy releases. You will need to remove the shaft, clean and re-grease the splines. This will temporarily relieve the problem until the joint dry's out again.
    On the other hand, could be universals I guess.
  3. May 23, 2013 at 6:51 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Try retorquing the rear u-bolts to 80 ft lbs too.
  4. May 23, 2013 at 7:07 PM
    Nick54
    Nick
    Mentor Ohio
    X2^^^ Had this issue after installing Dakars, had to go back after a day or two and re-torque.
  5. May 23, 2013 at 7:16 PM
    lowcountrytj
    lowcountrytj Third Member
    Phillip
    Probably at Work
    2012 DCLB TRD SPORT "BLACKOUT"
    My 06 Pre-runner ( 3 leaf rear ) had the same issue. Axle wrap when coming to a stop and once you released the brakes the rear snaps back causing the clunk. I learned to ease off the brakes and unload the rear end before complete stop and take off. Hope I'm not confusing you lol. It was aggravating.
  6. Jul 22, 2013 at 7:41 PM
    superdave
    superdave Active Member
    Dave
    St. Louis, Mo
    TRD Sport
    Camper Shell
    Driving me crazy, can't find out what it is. I've re-torqued the leaf spring u-bolts, wheels, unloaded everything from the storage compartments under the seats & in the bed, and everything in the bed. STILL Clunks. Sounds like something in the rear end. I'll lube the drive shaft splines & try that. Pisses me off; 65,000 miles & can't find a noise. I love my Taco.
  7. Jul 22, 2013 at 7:43 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Could be a u-joint on the driveline too. I have found the clunking happening with a worn out u-joint.
  8. Jul 22, 2013 at 8:08 PM
    LocoTaco
    LocoTaco Well-Known Member
    Don
    Central Washington
    09 SR5 TRD Sport
    My opinion is a U joint or joints are bad and needs to be replaced.
  9. Jul 22, 2013 at 8:13 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Make sure it’s not the gas in the tank sloshing back and forth. It’ll sound an feel like somebody bumped you in the rear end.
  10. Jul 23, 2013 at 6:31 AM
    fritzthecat
    fritzthecat Well-Known Member
    Virginia Beach
    07 PreRunner Auto AccCab Indigo
    Adjust the rear brakes. if they don't grab enough the driveline stays loaded up and under tension.
    Fritz
  11. Jul 24, 2013 at 9:17 AM
    superdave
    Dave
    St. Louis, Mo
    TRD Sport
    Camper Shell
    I just checked all the brakes about a week ago (goin to Colorado in Sept.). I have 2/3 pad & shoe thickness left after 65,000 miles (love it). The rears are properly adjusted. I lubed the u-joints yesterday, didn't help. I have a double cab so it has a carrier bearing in the shaft. It has some play, but went to dealer & crawled under a new one on showroom floor, didn't seem a whole lot different. Mine has a sealed boot over the spline after the carrier bearing & I'd rather not mess with it except as a last resort. The dealer said if they mess with it, I'd pay labor time from the time the mechanic clocks in on it, cause I'm past the 36,000 regular warranty. I guess I'll crawl under & look for tranny mounting problems, etc. Thanks to everyone for the ideas.:confused:
  12. Jul 29, 2013 at 6:20 PM
    CKeysr
    CKeysr Member
    Yorktown, VA
    2010 SR5
    I have a 2010 double cab and have the same friggin problem. It almost seems like a quirk Toyota has because if I ease in and ease out it seems to be less notable. I checked everything as well. Wish I had a definite fix...aggregating. But love my truck!!
  13. Aug 31, 2019 at 2:34 PM
    Oscar Schmidt
    Oscar Schmidt Member
    Having same issue on my 05'... anybody find a fix on this yet?
  14. Sep 1, 2019 at 1:01 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    There are a ton of posts on this so do a real search and spend some time reading thru the endlessness.
    Run your VIN and see all the TSBs or call and the dealer to see if anything open on yours.
    A few quick points:
    1. That seat of the pants bump or clunk to some at a stop is usually the AC kicking on as the idle solenoid steps up.
    2. Toyota did a trans software flash on most models
    3. The rear springs are too soft and can wrap and change the driveline angle (if altered dealer always blames that).
    4. Toyota has had endless complaints on the 2 piece with center carrier since 2005 and has replaced many.
    5. Trans mount can be bad.
    6. Possible rear diff is going bad.
    7. Etc
  15. Sep 1, 2019 at 10:33 AM
    IcyHott
    IcyHott Active Member
    Western MA
    2012 Toyota Tacoma 4x4
    Had this issue on my 2012 and lubing the splines fixed it. Used this stuff as lube.
    http://www.lowrangeoffroad.com/ptfe...-ford-motorcraft-xg-8-ml1167-31508-42027.html
    First time I did it, it lasted about a year before the clunk came back, so I did it again it it hasn’t come back again, but probably a good idea to do this every year. When you remove the clamps on the rubber boot, I just removed the front one that way I didn’t break both clamps. They’re oetiker clamps and can’t really be reused.
