Driveline pulsating?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beach triple, Nov 10, 2008.
  1. Nov 10, 2008 at 9:03 AM
    beach triple
    beach triple [OP] Member
    I recently picked up a '06 Accesscab 4cyl, 4x4 and started noticing a pulsating between 45-55 mph in 5th gear. Everything else runs great, don't notice it in any other gear, even 4th at 50 mph, but if I'm in 5th gear anywhere betweeen those speeds I get a pulsating that I can feel in the steering wheel and hear a bit, not like an unbalanced tire though, like it's coming from the driveline. It goes away if I put it in neutral and I only tried once but it wouldn't do it in 4H. I've read about people's problems w/ vibration, but this is more of a rhythmic pulsing, not sure if it's the same thing. I'm def. taking it back to the dealer to look at but I wanted to see if anyone might have experienced this before.
  2. Nov 10, 2008 at 9:20 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im gonna go ahead and say its probably the center support bearing, cause some of them on the newer tacomas arent too smooth when the drive shaft is turning, and some have been having a problem with the whole drive shaft being the problem. the best way to remedy that,since the dealership likes to say its normal(i had an 06 myself.....vibrating isnt normal....i dont care what they sday)is to buy and install a tom woods drive shaft.......this has taken care of alot of peoples problems.
  3. Nov 10, 2008 at 3:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to Tacoma World!!!
    To add to what Will said, it could also be the rear Tranny mount. Some have been defective, so Ask the dealer. :)
  4. Nov 10, 2008 at 3:58 PM
    hoosiertaco
    hoosiertaco Well-Known Member
  5. Nov 10, 2008 at 4:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thanks, Ben. I heard it thru the grape vine, but had no experiance with it.
