Driveline slip yoke greasing
Discussion in 'Technical Chat' started by Warren Thompson, Aug 15, 2009.
  1. Aug 15, 2009 at 4:00 PM
    Warren Thompson
    Warren Thompson [OP] GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    I completed greasing the 5 zerks, changing out diff oil and transfer case oil. Good timing, since the U-joints were bone dry... I have read here that I should grease the slip yoke that is covered by a rubber sleeve. Are there any posts on getting the sleeve rings off and proper method? I did read one that was not very detailed. I just do not want to screw something up!!
  2. Aug 16, 2009 at 6:23 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I don't think you can grease the slip yoke at all on the 2nd gen trucks. I haven't seen anyone 'find' a grease zerk for it.
    I had a 96 tacoma and the slip yoke grease zerk was located at the end of the shaft inbetween the 'ears'.
    Don't remove that boot..... the grease zerk wouldn't be located under it anyway.
  3. Aug 16, 2009 at 7:53 AM
    Warren Thompson
    Warren
    Elko, Nevada
    I am so confused. I have read so many conflicting posts on this.
  4. Aug 16, 2009 at 6:48 PM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    Ya, me too. The one thing that sucks is on the 06s like mine. It does not have grease zerts. :(
