Driveline spider replaced with zerkless
Discussion in '2nd Gen. Tacomas (2005-2015)' started by knayrb, Dec 19, 2023.
  1. Dec 19, 2023 at 4:06 PM
    knayrb
    knayrb [OP] Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    About 2000 miles ago I paid the dealer to fix a bunch of items. One of those was a clunk when starting to move that I just couldn’t figure out. To my surprise the mechanic said it was a worn spider joint just behind the carrier bearing. It was replaced and now no more clunk. Every 5k miles I change the oil and also shoot a couple a pumps of grease into the drive line. Today with 190k miles I changed the oil and noticed 2 things. First, the front and back zerks are 180 degrees from each other. Second, the replaced spider in the middle does not have a zerk grease fitting. The truck has zero vibration from 0-90 mph.
    Is it phased correctly or should I make them check the phase? With no vibration should I just be happy?
  2. Dec 19, 2023 at 5:57 PM
    10YSON
    10YSON Well-Known Member
    GREG
    TACOMA & 4RUNNER
    TOTAL CHAOS / KING / DEAVER / PRP / DIRTKING
    Dont fix it if it aint broke.
  3. Dec 19, 2023 at 6:42 PM
    TacoTuesday1
    SD CA
    dealers sell a non serviceable propshaft.
    driveshaft shops rebuild and balance used propshaft with new CB and spider greasable Ujoints under $300, to be greased as maintenance.
  4. Dec 19, 2023 at 7:15 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    This…..
    Leave it alone.
    wi_taco likes this.
  5. Dec 19, 2023 at 7:19 PM
    Bishop84
    Bishop84 Well-Known Member
    Zerkless is better. Fight me.
  6. Dec 19, 2023 at 7:26 PM
    TnShooter
    Deogee
    STOCK
    It’s a valid argument.
    They should be stronger.
    They are definitely better for people that don’t grease their zerks. :rofl:
    I guess the argument for the zerks are for having the ability to “freshen up” the grease and push water out if it gets in there. But there again. If water is getting is, it won’t be long for this world anyways.
    I’m just old school, I can’t convince myself zerkless is better. When in fact, they are probably just as good.
    wi_taco likes this.
  7. Dec 19, 2023 at 7:32 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    zerkless u joint is fine... i prefer greaseable ones with zerks... we dont need the extra strength from the zerkless ones in our application.
    Now TYPICALLY from what I have seen on factory drive shafts they line the zerks up to make for easier greasing.... and as you mentioned if thats the case they replaced the driveshaft 180deg out. Which isnt going to mess with u joint phasing (which occurs at 90*s) but will effect balancing of the ENTIRE unit. But its probably so minimal that its not that big of a deal from a balancing perspective.
    This all stated, if your center joint was shot, your rearmost is likely following close behind.
    knayrb[QUOTED][OP] likes this.
