Driveline Vibe Diagnosis Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by aninzer, Dec 2, 2021.
  1. Jan 2, 2022 at 4:47 PM
    #41
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I would remove the carrier bearing drop and see if you can get the front and rear to be within 1 degree of each other and the middle joint to be under 1 degree. I think my front was about 3 with the middle being .6 or .8 and the rear being just over a degree bigger than the front was like 4.2 or 4.4 under acceleration the rear angle decreases. No vibes on accel or decel
  2. Jan 2, 2022 at 4:49 PM
    #42
    tacoma909sport
    tacoma909sport Well-Known Member
    So Cal
    14 DoubleCab Sport
    interesting, you don't think the carrier bearing drop kit isn't helping me?
  3. Jan 2, 2022 at 5:07 PM
    #43
    tacoma909sport
    So Cal
    14 DoubleCab Sport
    so i just removed my carrier bearing drop kit. .. my new numbers are... trans shaft 4.4, 1st shaft 5.8, 2nd shaft 7.8, rear end still 8.2.
    so i'll run the numbers on spicer.. BRB..
  4. Jan 2, 2022 at 5:11 PM
    #44
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I would start adding small washers to adjust the carrier bearing down. You will probably want some movement there. You can also unbolt and flip the carrier bearing and it will change the drop height. If you can get the center bearing to 1 degree or less you will probably be really close. I would also drive the truck after each change. It’s worth it to note the changes and where it feels better and worse.
  5. Jan 2, 2022 at 5:13 PM
    #45
    tacoma909sport
    So Cal
    14 DoubleCab Sport
    can you advise direction on flipping the CB, i'll search for it, but im guessing its straight forward as it sounds..
  6. Jan 2, 2022 at 5:15 PM
    #46
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Unbolt, spin 180 degrees and bolt back up. The carrier bearing mounting tabs aren’t on center so it can also provide extra drop or lift depending upon which way it currently is.
  7. Jan 2, 2022 at 5:16 PM
    #47
    tacoma909sport
    So Cal
    14 DoubleCab Sport
    interesting.. now i'll go try that.. i'll be back with some new numbers again.. lol
    a2lowvw likes this.
  8. Jan 2, 2022 at 5:18 PM
    #48
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I think on my truck it was about a degree change.
  9. Jan 2, 2022 at 5:33 PM
    #49
    tacoma909sport
    So Cal
    14 DoubleCab Sport
    i reset my angle meter, so thats why the output shaft, and rear end numbers changed.. either way the operating angles are changing.. but in the right or wrong directions?
  10. Jan 2, 2022 at 5:37 PM
    #50
    ForceOfG
    ForceOfG Well-Known Member
    Portland, OR
    16' DCLB 4x4 Off-Road
    5.29 Yukons Stage 2 Icons 265/70/17 OVTuned
  11. Jan 2, 2022 at 5:39 PM
    #51
    tacoma909sport
    So Cal
    14 DoubleCab Sport
    food for thought.
  12. Jan 2, 2022 at 5:46 PM
    #52
    o0_henry
    o0_henry Well-Known Member
    South Texas
    2018 Tacoma TRD-offroad
    Would honestly try a 2 degree shim with carrier bearing drop in. I went with wfoconcept shims with new center pins. Solved my low speed vibrations after my deaver expedition leafs. I didn’t notice any significant change when I rotated the carrier bearing
  13. Jan 2, 2022 at 5:50 PM
    #53
    tacoma909sport
    So Cal
    14 DoubleCab Sport
    so you think this is what i should be installing? knock down that 8.2 something closer to the 4.2 output shaft?
  14. Jan 2, 2022 at 5:53 PM
    #54
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Are these your most current numbers?
  15. Jan 2, 2022 at 5:54 PM
    #55
    tacoma909sport
    So Cal
    14 DoubleCab Sport
    yes..
  16. Jan 2, 2022 at 6:05 PM
    #56
    o0_henry
    South Texas
    It would help to see the driveline, but the easiest route to go is get the center angle at the carrier bearing close to 1degree, they are not designed to be zero. The carrier bearing drop looks to have gotten you pretty close. And a 2 degree shim should get you within the ball park of a degree difference for operating angles 1 and 3.
  17. Jan 2, 2022 at 6:07 PM
    #57
    Jwjones2112
    Jwjones2112 Member
    For what it’s worth, I had exactly what you described after I installed a similar lift a few months ago. Thought it was the drive line but couldn’t solve it.
    However, I didn’t use a torque wrench on the lugs. Went back and torqued the lugs properly and all vibrations are gone.
  18. Jan 2, 2022 at 6:08 PM
    #58
    tacoma909sport
    So Cal
    14 DoubleCab Sport
    i do have a tourqe wrench and i do use it often.. i have operating angle issue.. i think im going to order angle shims tonight.. and a new set of center bolts.
  19. Jan 2, 2022 at 6:09 PM
    #59
    o0_henry
    South Texas
    Something like this should work. I personally went steel and painted it some some zinc primer and black paint. You don’t have to replace the center pin but I would recommend it, double check the existing size before ordering.
  20. Jan 2, 2022 at 6:13 PM
    #60
    o0_henry
    South Texas
    Leave one wheel on and drop the axle on the other side, 2 C-clamps to hold the leaf pack together and it’s a pretty quick 2-3 minute swap.you’ll spend more time getting the center pin to line back up in the hole on the axle then anything.
