Driveline vibes after carrier bearing/u joint replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Buckwheat893, Sep 29, 2020.
  1. Sep 29, 2020 at 1:33 PM
    Buckwheat893
    Buckwheat893 [OP] Well-Known Member
    Cody
    Tucson, AZ
    2011 AC
    Anybody have issues after carrier bearing/u joint replacement? I recently replaced the bearing and u joints and now I have vibrations at varying speeds.
    I had the infamous takeoff vibrations prior to the replacement and the oem carrier bearing was essentially nonexistent. Now, I have no takeoff vibes but do get vibes at 25-40, 55-65 and 75+ mph.
    I have tried repositioning the carrier bearing, the carrier bearing drop kit, and all that changes is the speed at which the vibrations happen. What gives? Do I need to have the driveshaft balanced? I’ve double checked everything and it all appears to be correctly installed. Any help is appreciated.
  2. Sep 30, 2020 at 7:18 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Did you add any lift to the rear, or is this a stock truck with driveline vibes?
  3. Sep 30, 2020 at 8:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Musubi3[QUOTED] likes this.
  4. Oct 1, 2020 at 4:59 AM
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    Did you mark the driveshaft's radial positions on each side of the carrier bearing prior to separating for replacement? They need to go back together the same way they came apart....
  5. Oct 1, 2020 at 5:02 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    This. your driveshaft is out of phase now. Doesn’t matter at the diff flange or tranfer case output flange but the driveshaft is balanced in phase will all these pieces aligned in a particular fashion. They must remain that way in order to stay balanced or get rebalanced is your only option. Not a huge deal, doesn’t take very long.
  6. Oct 14, 2020 at 2:00 PM
    SilverYeti
    SilverYeti Well-Known Member
    2010 Silver Tacoma TRD Offroad
    Pelfreybilt sliders ARB bumper WARN winch
    Recently went through this and thinking of getting mine balanced next week. Did you get yours balanced, did it fix the vibes? Thanks!
