driveline vibration cured with 3 degree shims
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dewey7015, Jan 15, 2019.
  1. May 8, 2019 at 8:25 PM
    whatjones911
    whatjones911 Well-Known Member
    2018 DCSB OR 4x4 MT
    I'm still working on curing the take off shudder after 3" lift in the back. @Dewey7015 did you leave the carrier bearing drop in or did you take out after installing the shims?
  2. May 10, 2019 at 8:38 AM
    jwilson2899
    jwilson2899 Well-Known Member
    Front Royal, VA
    2017 Tacoma DCSB TRD OR 4x4, BP-51's with medum Dakars, TRD Proser, 285/70/17 KO2s
    Full on TRD "Proseur", BP-51/medium Dakar, 285/70/17 KO2's, HID/LED everywhere
    I'm interested I knowing the same thing myself @Dewey7015 since I'm having a similar shudder, most pronounced around 25 MPH.
    Taudelta likes this.
  3. May 10, 2019 at 11:29 AM
    Dewey7015
    Dewey7015 [OP] Well-Known Member
    Massachusetts, USA
    2018 TRD sport
    I took it out. Just the shims, and the add a leaves in the back.
    jwilson2899 likes this.
  4. Jun 19, 2019 at 9:43 AM
    Mack411
    Mack411 Well-Known Member
    2017 Quicksand Tacoma Trd-OR
    What 3 degree shims are best for an ome hd leaf pack?
  5. Jun 20, 2019 at 11:39 AM
    birry
    birry Well-Known Member
    Oklahoma City, OK
    2008 4x4 DCSB
    OME 885, Bilstein 5100's, Wheeler's (single) AAL
    Interested in this as well. I recently installed a 2.5" suspension lift and have the take-off "shudder" under 10 mph AND the 55-65 intermittent vibe. Seems like *maybe* some shims could help?
    FYI: Already replaced the CV axle bearing with ECGS, which completely took care of the 25-35 mph vibes.
    One of these days I'll have a truck that doesn't shudder and shake!
  6. Jun 20, 2019 at 2:44 PM
    Dewey7015
    Massachusetts, USA
    2018 TRD sport
    I did the same thing..just put in the wheelers 3 degree shims, and it worked as it should.
    birry[QUOTED] likes this.
  7. Jul 9, 2019 at 6:05 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    For the record - I purchased and installed the Wheeler's 3 degree shims, and they haven't really helped with the take-off shudder. What DID help was having all my camping gear in the back when I went on my road trip last week. I didn't notice the shudder at all when loaded with a bed full of stuff. I guess that indicates that my issue is mostly axle wrap?
    I HAVE noticed a slight decrease in some of the higher speed vibes I was getting between 50-60 mph. So I guess that's a win.
    Side note - my Taco lean got way worse with the shims. I've triple checked the orientation of the shims, and they are installed correctly (both have the thin side facing forward).
  8. Jul 9, 2019 at 6:11 AM
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    mine gets kinda bouncy in certain slow down situations similarly. No lift here. sometimes I cant even tell if its the road or the tires or what.
    Gonna try putting a sandbag in the back and see if it helps any.
  9. Jul 9, 2019 at 6:16 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    Good idea. I might try that on the passenger side as my lean correction and anti-vibe sand bag(s) :rofl:
    fiftyxp[QUOTED] likes this.
  10. Jul 21, 2021 at 7:24 AM
    Davidwallace93
    Davidwallace93 Member
    David
    2021 Tacoma TRD Off Road
    is this only for 4wd? I have this issue with my brand new 2021 it came from the dealer with level kit, wheels/tires. TRD Offroad.
