Driveline vibration of axle/transmission shaking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by QCyota, Dec 25, 2020.
  1. Dec 25, 2020 at 6:06 PM
    QCyota
    QCyota [OP] Active Member
    2016 MGM trd sport AUTO, dclb 3.5l
    Bilstein 5100 all around Old man emu 2887 coils Icon progressive add-a-leaf
    Hi everyone, I am new here and this is my first post. I am used to many facebook groups, and I did many researches there before. But today I need your help with an issue that I cannot solve.
    here is the problem:
    A few days ago I drove about 500 kms on 4 hi on a gravel road which was snowy and icy and when I came back to the pavement I switched back to 2wd and noticed an issue. When I was speeding from a complete stop, at a low speed and a low RPM ( 1000-1500 ), the truck shook very intensively and the issue occured every time the truck shifted to the next gear and rpm dropped to 1000-1500, always when speeding... today the temperature here has reached 10 C so everything melted under the truck and on the wheels, and the issue is the same! I feel like it comes from the tranny, the drive shaft or the rear diff. I carefully washed the wheels, and everything under the truck to eliminate all the snow and ice that could be anywhere and I took off the last rear section of the driveshaft to apply grease to the slip yoke and inspect the U joints and the center bearing ,that seem in very good shape. Do you have any idea? Truck has 77k kms. It praticaly feels like missfires that disappear at 1500 rpm and above and only occurs when pressing the gas pedal just enough to provide a mechanical leading but not enough to downshift. It is not quite a feeling of an unbalanced wheel either, since the cycle of the vibration is faster than the spinning wheels speed
    SR-71A likes this.
  2. Dec 25, 2020 at 7:00 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Fried atf and/or glazed the torque converter clutch.
    Check, smell fluid?
    Try driving in S3; does it go away?
  3. Dec 25, 2020 at 8:03 PM
    QCyota
    I am wondering how could this happen with its oem atf cooler... considering it only has 50k miles and towed only a few times!
    I will add this fact: on my 500 kms ride there were 250 km of the road that has not been recently plowed and I did not use neither S4 mode nor etc button... maybe riding this way in fresh snow for a while on 4hi, low rpm did not allowed the atf to cool enough ?
  4. Dec 25, 2020 at 8:11 PM
    splitbolt
    NW Arkansas
    300 miles in 4 hi on slippery terrain and the torque converter out of lock up...I can see it happening.
  5. Dec 25, 2020 at 8:21 PM
    QCyota
    I don’t know about lock up fonction, could you tell me more about that? Thank you
  6. Dec 25, 2020 at 9:04 PM
    splitbolt
    NW Arkansas
    Full lockup occurs when the engine is locked at a 1:1 ratio with the transmission input via torque converter clutch engagement. It usually occurs when cruising, at around 40 mph.
    There's also a partial duty, called flex lockup that occurs at various speeds/gear changes during acceleration and deceleration.
    Basically, anytime the torque converter is not in full lockup, it's generating heat. How much heat depends on how much 'slip' between the turbines. Things like towing or slip-sliding down an icy road for hours on end with a 'more pedal' mentality can generate a lot of heat.
  7. Dec 25, 2020 at 9:38 PM
    QCyota
    Very clear explainations, thanks! So I guess that the torque converter is automaticaly locked in S mode and this way cannot use its flex mode ?
  8. Dec 25, 2020 at 10:13 PM
    splitbolt
    NW Arkansas
    No...full lockup can occur in D or S.
    The reason I suggested S3 is it should eliminate flex lockup.
  9. Dec 26, 2020 at 6:03 AM
    QCyota
    I see, so according to you, if I had use the S4 mode during all my last ride (as toyota recommands for towing), would it has helped to eliminated flex lockup and keeps the trans less hot in temperature ?
    Sorry , I am asking many questions but it is hard to believe that truck is not meant for this purpose and I try to know what could I do different to avoid this issue! S mode ? Etc button?
  10. Dec 27, 2020 at 3:26 PM
    QCyota
    It does not go away in S3, shudder still there but maybe, less often. Could this even be the torque converter? I will bring it to the dealer to have the atf checked
  11. Dec 27, 2020 at 8:20 PM
    gearcruncher
    Canadain bumper technician
    I suggest a missfire test .
    You feel the shuddering at 1500 rpm in every gear ?
    Warm up the truck
    Put the transmission in drive with your foot hard on the brake pedal and bring the engine revolutions up to 1500 in your driveway .
    Do you feel the engine stumble when the rpms hit 1500 ?
    This is a missfire test .
    Allow your transmission to cool after the test by running the engine with the transmission in park
    Here are more vibration tests
    https://www.tacomaworld.com/threads/vibration-diagnostics-for-all-tacomas-write-up.520607/
  12. Dec 27, 2020 at 8:28 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    S3 is a bad idea because the TC will never lock.
    Driving in 4HI is no different than 2HI as far as the tranny is concerned. It doesn’t heat up faster.
  13. Dec 27, 2020 at 8:43 PM
    QCyota
    I do not feel it in every gear. It occurs when the rpm is downed to 1000 or under after an upshift and when I gently keep the gaz pedal pressed ( not enough to downshift but enough to maintain a weak acceleration)
    I will do do the missfire test tomorrow and come back
  14. Dec 27, 2020 at 8:50 PM
    splitbolt
    NW Arkansas
    That was the intention, as It was a test to see if the tcc might be affected.
  15. Dec 27, 2020 at 8:52 PM
    Sharpish
    Brian
    Gotcha. I misread that.
  16. Dec 28, 2020 at 5:00 AM
    QCyota
    I absolutely dont feel the engine shuderring when executing the missfire test
    gearcruncher[QUOTED] likes this.
  17. Dec 28, 2020 at 5:20 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    From what I have read on here, many 2016 trucks with the AT were shipped low on ATF from the factory.
    You could try checking the ATF level yourself. I bet its low. There are several writeups on here, though I dont specifically know the sequence for 3rd gens.
    Probably wouldn't hurt to do a drain and fill while you were at it.
    QCyota[OP] likes this.
  18. Dec 28, 2020 at 5:42 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Op's truck sounds very similar to a buddies 2019 trd where the engine lugs at 1000-1200 rpm and shakes the truck. Seems its real noticeable around 35 mph. He can't recall doing it with the stock tires and height...never drove it long enough before giving it a lift and 33'' tires.
  19. Dec 28, 2020 at 6:51 AM
    gearcruncher
    Thank you for performing the shudder test . An engine missfire is now eliminated .
    Do you know if the dealer updated your transmission computer ( ECU ) with a technical service bulletin ?
    The dealer would have placed a new sticker under the hood of the truck
    Are you positive they checked the transmission fluid level ?
    Becuase the transmission is completely computer controlled , are there any trouble codes ? I hope you have a scan guage / ultra guage ?
  20. Dec 28, 2020 at 6:52 AM
    QCyota
    The question is : if i’m low and I drove so during 4 years and then I check the level myself and add 1 qt for example, would I hide a fried fluid issue that itself caused my torque comverter to toast ? Who knows and how to know ?
