Driveline vibration on acceleration?- 09 TRD stock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trd09, Aug 8, 2009.
  1. Aug 8, 2009 at 12:02 PM
    trd09
    trd09 [OP] Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    Hi all, just wanted to run this by you guys to make sure it's normal (or not).
    When I accelerate from a stop all out (wot), through first gear there seems to be a slight vibration. If I had to guess, I'd say it sounds (and feels) like the driveshaft shuddering. I've seen a video posted and it seems like that. It's not too noticeable and only happens wot. It also seems to happen more when the back end squats more (ie, going up a hill) vs not. Once it shifts out of first it's fine.
    Is this normal? It's a brand new stock TRD sport access cab 4x4. Love the truck btw.
  2. Aug 8, 2009 at 5:36 PM
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    ttt
  3. Aug 8, 2009 at 5:37 PM
    slo blue
    slo blue Member
    Ohio
    09 off road
    cheap lift for now, 285-75-16 km2's
    they all do it
  4. Aug 8, 2009 at 6:00 PM
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    any aftermarket spacer kit that could fix this?
  5. Aug 9, 2009 at 1:43 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    From a standstill to WOT??
    That's a pretty extreme situation to put the driveline through. I wouldn't be surprised that your pinion is pivoting pretty extremely under the torque load and it's going OUTSIDE the sweet spot of the U-joint which can result in vibrations. If you keep doing that - you're gonna start blowing out u-joints.
    Have you taken it to the dealer?
  6. Aug 9, 2009 at 4:09 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    He has an automatic so it's not like he's dropping the clutch, hell I do greenlight - WOT almost every light myself :cool:
    From what I've gathered reading on it and my own truck, usually it seems to be more speed based than rpm based. I can say I've never noticed it at WOT on my truck though, but I have the AAL TSB and off-road suspension. Also I got rid of a ton of vibration by tossing the stock bfg rugged trails, not sure how the dunflops hold up or work into that on the sports...
  7. Aug 9, 2009 at 4:58 AM
    Janster
    Jandy
    Lancaster, PA
    There's still gonna be a great amount of torque at WOT regardless of transmission.
    The question here is - when he says WOT, what exactly does he mean?
    If he starts off normally (not WOT), does he still get the vibrations?
    If not, then I'd say....drive the truck normally to prevent the vibrations. These trucks aren't meant to start off WOT everytime. If you do that all the time, something will break and you'll wanna upgrade to parts that can handle the torque load if you plan on continuing to drive like that.
  8. Aug 9, 2009 at 5:54 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    So, out of curiosity what exactly is going to break? People don't need to swap out driveshafts after dropping in a TRD SuperCharger or other things... they're built to handle the power. also, I'd be willing to venture towing 6500lbs is a lot harder on the drivetrain than spinning tires.... Also i've tested trying to 'launch' using the auto transmission @ 2500rpm.... it waited to shift into first until it dropped to about 1500 revs... so I really don't see the issue :shrug:
    But anyway that's going off-topic... I am curious if his vibrations seem RPM based or speed based as well.
  9. Aug 9, 2009 at 6:43 AM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    The drivetrain can handle it. I have the trd blower and have no problems doing wot. They wouldnt warranty it if it couldnt.
  10. Aug 9, 2009 at 7:08 AM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    what is wot
  11. Aug 9, 2009 at 7:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Wide Open Throttle
  12. Aug 9, 2009 at 9:45 AM
    warpig
    warpig Member
    Kentucky YeeHaa!!
    2011 TX Pro
    Mine started doing this from 0-15 mph the day I had the spring TSB done. Dealer said it was due to the stiffness of the new springs that more road and drivetrain vibrations where felt. I say BS!!
  13. Aug 9, 2009 at 11:46 AM
    Janster
    Jandy
    Lancaster, PA
    If you're launching the truck ALL THE TIME - stuff ain't gonna last.
    U-joints can break
  14. Aug 9, 2009 at 2:05 PM
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    i'm not performing any launching technique (i agree, not the best thing for the truck) and i don't drive around smoking the tires. this happens not only at wot, but a solid 3/4 throttle.
    if it's the driveshaft angle when the back end squats (which i did some more research, it likely is) i don't have much of a problem with it (it doesn't happen too much and isn't too noticeable).
  15. Aug 9, 2009 at 7:23 PM
    PropJet
    PropJet Well-Known Member
    KS
    '09 DC TRD Off Road
    ToyTec Ultimate Lift Kit, Moto Metal 955's, GoodYear DuraTrac 265/75/16's, N-Fab Nerf Bar
    My '09 has the first gear shudder on every acceleration, and I pretty much baby it for the most part. Naturally, the dealer claims not to be able to duplicate this issue... nor the hard shift from 1st to 2nd... nor the transmission "clunk" when starting and stopping...
    Ridiculous for a brand new $30k truck. I'm learning to live with it, but my opinion of Toyota quality is going downhill fast.
  16. Aug 10, 2009 at 11:25 AM
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
  17. Aug 10, 2009 at 11:29 AM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    My 09 has done that since I drove it off the lot. Never had any other truck in 20 years that did that.
  18. Aug 10, 2009 at 1:52 PM
    Janster
    Jandy
    Lancaster, PA
    Then you're not truely doing WOT.....
    Anytime I see someone say WOT - I'm thinking, balls to the wall, foot to the floor..... Totally different than 3/4 throttle.
    I've recently developed a minor vibrations at take-off. I just noticed it the other day. I know it hasn't been doing that for the last 2 or so years I've owned it. Not sure what it could be and not even sure I've felt it since.
    But with my warrantee coming up in March, I'll be certain to do some investigating soon.
  19. Aug 11, 2009 at 6:29 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    I dropped my truck off today at a local off-road shop for this vibe/shudder issue. We'll see what they find.
  20. Aug 13, 2009 at 9:07 PM
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    update?
