Driveline vibration Tsb out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotacerttech, Dec 22, 2012.
  1. May 1, 2013 at 3:18 PM
    #361
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    My dealer threw all the parts on in one shot today. It actually seems slightly better but I can still tell it's there. Luckily it doesn't seem to have made it any worse like some are saying. Mine wasn't very bad to begin with though. Will see how it goes over the next couple days. Ride with the new leafs seems the same.
  2. May 2, 2013 at 1:21 PM
    #362
    tpr676
    tpr676 Well-Known Member
    I installed Hellwig helper EZ-550 I still had shudder/vibe after new drive shaft, for less than $60 with shipping and 45 minutes of your time it did help. I don't know if these springs are softer or not but so far I am pleased with with the helpers.
  3. May 2, 2013 at 2:39 PM
    #363
    bjboucher
    Brad
    San Antonio, Texas
    Funny you mention these, I ordered some this morning. Been looking at them for a week or 2 but waited until they installed my new leafs to order them. I'll be putting them on this weekend. I mainly ordered them to help with handling a load as I take a 4,200 mile road trip, not to handle the shudder, but if it does both that's great.
  4. May 2, 2013 at 2:58 PM
    #364
    graywolf2011
    graywolf2011 Well-Known Member
    Orlando Florida
    11 Tacoma 4X4
    undercover hard toneau, stainless steel nfab step bars
    I have not read this entire thread, but has any dealership measured the angles between the output shaft and pinion shaft? These angles must be identical, and the carrier bearing must be almost zero degrees(slight angle is needed for lubrication of u joint). If the output angle and pinion angle are not identical, you will get conflicting harmonic vibrations between the 2 angles, driveline 101, Toyota knows this. Any 2 piece drive shaft must adhere to this principle. This is a simple shim adjustment if this is the cause of the vibes. Just a thought.
  5. May 2, 2013 at 3:14 PM
    #365
    Trd2013taco
    Trd2013taco Member
    NC
    trd off road
    2013 off road dcsb .. i get an occasion vibration from a dead stop to hard acceleration but once she gets going it goes away ..other then that no vibrations in normal driving.. is this the shutter/vibration everyones having?
  6. May 2, 2013 at 3:25 PM
    #366
    waYnewaGner
    waYnewaGner New Member
    waYne
    Liverpool, NY
    09 Tacoma Trd
    Hey all,
    I know the TSB said something about 15-20 mph, but my vibration was coming at about 51. Had it balanced, and aligned like 20 times, so that was not the issue.
    Anyone else have the problem at a different speed?
    My Tacoma is currently in the dealership shop, and "might" be released tomorrow.
    Anyone? Bueller?
    waYne
  7. May 2, 2013 at 3:29 PM
    #367
    tpr676
    They do help with the axle wrap, and I believe axle wrap is the root of this shudder.
  8. May 2, 2013 at 3:32 PM
    #368
    tpr676
    They replaced my driveshaft it was out of balance, could be the vibration you feel at higher speeds. I had some vibs higher than that have not had a chance to hit the interstate.
  9. May 9, 2013 at 4:30 PM
    #369
    jgrm1
    jgrm1 Well-Known Member
    Midlothian / Waxahachie, Texas
    2021 Tacoma Double Cab Long Bed
    Did they eliminate the shudder?
    -Jeff
  10. May 9, 2013 at 5:33 PM
    #370
    tpr676
    They helped a lot worth $ 60.00
  11. May 9, 2013 at 6:08 PM
    #371
    bjboucher
    Brad
    San Antonio, Texas
    I really don't notice any difference with them on there. I wasn't putting them on for the shudder though, just a little extra insurance when I have to carry a load.
  12. May 9, 2013 at 10:16 PM
    #372
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ... ^^^ ... You gave "moi" (in my best French) a great idea ... :D
  13. Jun 7, 2013 at 5:48 PM
    #373
    Willcory
    Willcory Well-Known Member
    San Antonio TX
    2013 Black Tacoma 4x4
    I just had the tsb done.. did they install the 3 leaf pack on yours? I want my 4 leaf pack back on casue it sags when pulling my boat
  14. Jun 7, 2013 at 8:03 PM
    #374
    DESRTRNNR
    DESRTRNNR Well-Known Member
    Phoenix
    13 DCSB TRD off road 4x4
    what dealer did you go through? i'm having a hard time getting autonation toyota do get my tsb done up here in austin
  15. Jun 7, 2013 at 8:06 PM
    #375
    Grieby54
    Grieby54 Horsebit
    Sam
    Castle Rock, CO
    '13 TRD Off Road 4x4 DCSB MGM JBL/Entune/Nav
    WeatherTech Digital Liners, ImMrYo rear view mirror bracket, color matched grille, Tacoma door sill protectors, OEM hood protector, clear bra, tint, OEM roof rack, trimmed front mud flaps to match rear clearance, debadged, color matched grille, Plasti Dipped front Toyota emblem, OME 884X coils with trim packer on driver's side, OME Nitro Sport 9000 shocks, Deaver/ToyTec AAL with OME N182 shocks, 265/75/16 Duratracs, ProComp 7032 16" wheels
    A quick update:
    Added an OME lift with a 1.5" AAL and the 15-25 mph vibrations are GONE. Not sure if it's because I torqued the U-bolts down to about 90 lbs or the AAL or both, but it's gone.
  16. Jun 7, 2013 at 8:09 PM
    #376
    Willcory
    San Antonio TX
    Universal Toyota off 35n
    mark davis is who i been dealing with, real good group of guys over there
  17. Jun 8, 2013 at 5:30 AM
    #377
    bjboucher
    Brad
    San Antonio, Texas
    They gave me a new 4-leaf pack when I had the TSB done.
  18. Jun 8, 2013 at 5:31 AM
    #378
    bjboucher
    Brad
    San Antonio, Texas
    North Park Toyota did mine without hesitation. Fred was my service manager if you want to give him a call.
  19. Jun 8, 2013 at 5:31 AM
    #379
    bjboucher
    Brad
    San Antonio, Texas
    Awesome news. I'm installing the OME kit with Dakars 2 weeks from today!
  20. Jun 11, 2013 at 5:23 AM
    #380
    waYnewaGner
    waYne
    Liverpool, NY
    09 Tacoma Trd
    O.K. had all of the TSB stuff done. Fixed nothing. Made it worse.
    Now, I've got the driveline vibration under hard acceleration and a severe bounce at 50mph.
    Had the Toyota Field Technical Supervisor come in and his official response about the vibration "This is a characteristic of all Tacoma's from 2007 to the present. Including the 2013's."
    Anyone else find that unacceptable?
    Also, now I can hear a clicking from the back end when I the truck is down shifting at low speeds.
    Thinking about a trade-in. Any thoughts???
    waYne
