Driveline vibration Tsb out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotacerttech, Dec 22, 2012.
  1. Feb 8, 2014 at 6:57 AM
    #581
    ewkplymi
    ewkplymi Member
    Plymouth, MI
    2012 Tacoma Regular Cab
    Toyota - Round number three....
    Had to split PDF to download to forum.
  2. Feb 8, 2014 at 7:25 AM
    #582
    rustbus
    rustbus Well-Known Member
    western Canada
    2012 TrailTeam Pro - white
    cool thanks!
    except mines MT...and i have some new vibes @ 2300rpm :(
  3. Feb 8, 2014 at 9:10 AM
    #583
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    you are a saint and a hero.. thank you very much!
    Tacomaworld is awesome!
    Now to figure out which ones are the 4 leaf packs?
    So it looks like they are using the same rear transmission mount as before... but then new bump stops and u bolts and tons of different rear spring configs..
    Looks like they flatten the first u joint out by using the lower rear transmission mount... then get the proper angle for the rear joints... though they never measure the center joint angle... oy also theres no indication as to which way is the proper way to put the "caster blocks" but if you do some deductive reasoning it seems like they are actually trying to create a bigger angle at the pinion, by twisting the axle down, which would make sense as this would then put the two rear u joints in a good proper parallel form.
  4. Feb 8, 2014 at 9:29 AM
    #584
    EWM
    EWM Active Member
    I am confused about part 1 though. Since T-SB-0132-08 changed the mount to the 12371-31250 mount back in '08, and that bulletin has a production break-in point, doesn't it mean that anything past '08 should have the new mount already? T-SB-0132-08.pdf
  5. Feb 8, 2014 at 10:57 AM
    #585
    EWM
    EWM Active Member
    I think the "caster blocks" will already be incorporated into the spring perch area. There are no separate parts listed in the TSB for this. The different spring packs seem to be giving the different angles. I think this keeps them from having a single set of 3 and 4 pack springs and disassembling the leaf, installing wedges, and reassembling. The center joint angle will change along with the second driveshaft angle when the pinion angle is changed.
  6. Feb 8, 2014 at 11:32 AM
    #586
    nd4spdbh
    SoCal
    Either way i am glad this tsb came out as now they can install a 4 leaf pack on my trd off road and hopefully solve 2 of my issues... i will just note that they should raise the ass end of the truck from the hitch ~ 5/8ths of an inch to account for the extra thickness of the leaf as well the extra ride height of the extra leaf when they do the measurements.
  7. Feb 8, 2014 at 11:51 AM
    #587
    oklahomastig
    oklahomastig Well-Known Member
    Oklahoma City, OK
    2013 Tacoma TSS 4x4
    Thanks for posting the PDF! I'm a first time owner of a vehicle still under warranty, so do I just make an appointment with my local Toyota Dealer, tell them the TSB number and they'll take it from there?
  8. Feb 8, 2014 at 2:34 PM
    #588
    nd4spdbh
    SoCal
    should be.... having the TSB number definietly makes it super easy.
  9. Feb 8, 2014 at 4:16 PM
    #589
    2011Streaker
    2011Streaker Well-Known Member
    Maine
    2012 DCSB TRD Sport
    Good luck, let us know! I bet they're gonna need to order your parts for you so I suspect we won't have a first review til the end of the week at the earliest?
    I really hope this fixes it!
  10. Feb 9, 2014 at 5:56 AM
    #590
    Marcoc
    Marcoc Well-Known Member
    Connecticut
    2017 Tacoma TRD Off-Road LB
    2017 Tacoma TRD OR LB white w/tech package
    Wonder how this would apply to lifted trucks. My 2010 has the 15-25mph vibe as described but I am running a rear Toytec AAL plus angled shims. Wonder if they would just tell me to take a hike our what. Think I may call Toyota of America and see if my truck is even covered. Not sure what to do. Not about to remove my lift for a TSB that may not even work.
  11. Feb 9, 2014 at 6:04 AM
    #591
    Tacoma Mike
    Southern Maine
    It says right in the tsb aftermarket suspension the tsb does not apply.
  12. Feb 9, 2014 at 9:30 PM
    #592
    Marcoc
    Connecticut
    Thats crap. Because an add-a-leaf changes the driveline that much. Lets see what others do. Plenty of lifted Tacos out there.
  13. Feb 9, 2014 at 10:16 PM
    #593
    nd4spdbh
    SoCal
    we are talking different leaf packs in DEGREE increments... your ad a leaf is HUGE comparatively.... of course they arnt going to offer anything as you modified the rear suspension.
  14. Feb 10, 2014 at 5:33 AM
    #594
    Marcoc
    Connecticut
    Guess that means that 90% of members on here won't get their Trucks fixed. Many of us are running modified suspensions. I am not about to remove my lift to go get a "fix" that may not even work. You stock guys have fun driving wimpy trucks;)
  15. Feb 10, 2014 at 9:06 AM
    #595
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    If the TSB works , it will point the direction towards a fix for the lifted trucks there tough guy
  16. Feb 10, 2014 at 9:12 AM
    #596
    WillRunner05
    WillRunner05 Well-Known Member
    WIll
    Houston, TX
    TRD Off Road
    ICON Suspension, LR UCA's
    I'm fortunate that all my lift parts are sitting in the garage, I was planning on installing but I went in for my 15k mile service and complained about the steering vibration and the service advisor set me up for TSB. So they put the Steering Damper, Tranny Mount and 4pack Leafs on order. Hopefully it will be there on Friday.
    I didn't even ask about the Driveline clunks I've been experiencing as I've been following the other threads and thought this was something Toyota was not going to fix and just blow me off telling me "it's normal".
    My concern is that I have an ICON stage 2 kit, and I wonder if this will be compatible with the new 4 leaf pack, or will it bring the driveline vibs back??? :confused:
  17. Feb 10, 2014 at 1:36 PM
    #597
    TheGoodLife
    TheGoodLife Active Member
    BC, Canada
    2011 4x4 DCLB TRD Sport
    Truxedo LoPro QT, DeeZee Rubber Bed Mat, EGR In-Channel Rain Guards, EGR Aerowrap Hood Shield, WeatherTech Floor Liners, PopnLock PL8521 Power Tailgate Lock, All-Pro Expedition Series Pack Rack (Welded), AutoHome Columbus Variant Roof Top Tent (Small), X-Pel Headlight Protection, Differential Breather Relocation Mod., ScanGauge OBD II Scanner, Hopkins 47297 Insight Brake Controller, Toyo Open Country A/T III 265/65R17XL (summer OEM rims), Bridgestone Blizzak DM-V1 265/65R17 112R (winter OEM Rims).
    Great news for all on the release of T-SB-0008-14.
    On a different matter, has anyone posted a PDF copy of T-SB-0057-12, which apparently replaces T-SB-0119-10 for the Steering Intermediate Shaft Rattle Noise issue? Not to be confused with T-SB-0057-13 (Rear Diff Whine Noise). Sorry if it is on TW somewhere, but my searches couldn't locate the updated copy.
    Just getting my paperwork in order to meet with the Dealer.
    Thanks to everyone that contributes to the resolution of these issues.
  18. Feb 10, 2014 at 1:46 PM
    #598
    Tacoma Mike
    Southern Maine
    This.
    You modify your truck and expect Toyota to fix a drive line vibe for your truck for free??????
    He heheheheheh love it ....
  19. Feb 10, 2014 at 2:16 PM
    #599
    nd4spdbh
    SoCal
    I would like to know about the steering shaft clunk as well.
    As far as the driveline vibe it makes sense... Make the front u joint almost 0 degrees by lowering the tail of the transmission / tcase.
    Then by changing the rear pinion angle match the angle of the center joint to put the rear shaft in a good harmonic, it's simple driveline mechanics... But a soft center support bearing and lots of axle wrap make it hard to get rid of. They should of really gone with a much stiffer center support bearing to go along with this.
  20. Feb 10, 2014 at 3:21 PM
    #600
    Smashing
    Smashing Well-Known Member
    Rochesterish NY
    2017 DCLB Sport
    Wondering what "second order drivetrain vibration" means. I bought my 2010 in December as a Certified Toyota. I'm a bit out of the warranty for the springs (45K) but I still have the 12mo/12k certified coverage. Any idea how they'll react on this?
