Driveline vibration Tsb out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotacerttech, Dec 22, 2012.
  1. Feb 20, 2014 at 7:23 PM
    #661
    oklahomastig
    oklahomastig Well-Known Member
    Oklahoma City, OK
    2013 Tacoma TSS 4x4
    Picked mine up for the second time. This time they put the new Engine Mount in and the steering damper. of course it didn't fix anything, but they had to do that before they measured the angles. Anyway looks like they ordered 48220-04220 and 48210-04580 for the leaf springs. Said it's gonna take about a week to get the parts in. The work order says "Angle between 0.3 and 1.5 degrees so i'm not sure why they ordered those parts, but I trust their judgement.
  2. Feb 20, 2014 at 10:03 PM
    #662
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    did you have the previous driveline TSB done? if not they DEFINITELY ordered the wrong part.
    Also i would request they order the firm ride pack as you will get the better 4 leaf pack vs the 3 leaf.
  3. Feb 21, 2014 at 7:04 AM
    #663
    rainmn
    rainmn Well-Known Member
    My truck is going in on Wednesday to have this done....hope they get it right. I did at least get confirmation that they have the angle finder, so that's a good start.
  4. Feb 21, 2014 at 7:16 AM
    #664
    KMitch
    KMitch Well-Known Member
    Colorado
    14 DCSB TRD Off Road
    2014 TRD OR here...only vibration I notice is under moderate to heavy acceleration from a stop. Would this TSB apply?
  5. Feb 21, 2014 at 7:25 AM
    #665
    oklahomastig
    Oklahoma City, OK
    2013 Tacoma TSS 4x4
    To my knowledge the previous TSB was never done. When I got the truck I registered it online with ToyotaCare and it didn't have any maintenance records. The work order didn't mention anything about a previous TSB either. I guess when I take it back in, they'll put those on and realize it didn't fix anything... Looking at the TSB, What parts would have been the correct ones?
    What's the advantage of the firm ride setup over the 3 leaf?
  6. Feb 21, 2014 at 7:42 AM
    #666
    rainmn
    That is exactly what this TSB is for.
  7. Feb 21, 2014 at 7:43 AM
    #667
    oklahomastig
    Oklahoma City, OK
    2013 Tacoma TSS 4x4
    Looking at it some more, I'm really not sure. Since I believe I have Standard suspension (It's a Base model with TSS package, and it rides rough so i'm assuming standard suspension) and the TSB wasn't performed, I need to refer to Table 3. Table 3 says for Angle between 0.3 and 1.5 for a 4x4 Double Cab is correct parts, but then there's a 4x4 Double Cab S-Long. Is that the long bed? Because I have the long bed model, which correlates to the VDS (My VIN has MU4FN1 in it) but there's not a spot on the table for the Long Bed with angle between 0.3 and 1.5, they're using the short bed code and springs. I'm guessing that would probably make a significant difference.
    EDIT: Ok nevermind, it looks like on the Table 3 for the Long Bed, it has a angle between -0.1 and 1.1 degrees with the same parts that I got ordered. I really wish they put the Joint Angle on here. My guess is the angle is somewhere between 0.3 and 1.1 and they originally saw the short bed column but then realized it was the same part for the long bed. I think i'm good.
  8. Feb 21, 2014 at 8:01 AM
    #668
    KMitch
    Colorado
    Thanks for the confirmation.
  9. Feb 21, 2014 at 8:14 AM
    #669
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    Im so happy i found thread for the TSB, i went into the dealer yesterday complaining about turbulence/vibration while driving. They said it was normal and walked away.
    Also also noticed that clunk noise in the rear....
    Thanks TW
  10. Feb 21, 2014 at 1:10 PM
    #670
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    im assuming they walked away because it has been told before a bunch of times.
    Should i be worried that my truck is an I4 auto prerunner 2wd DC? A lot of feedback throughout this whole thread has been mostly v6 engines, and a couple pages back about the Regular CAB I4 not being apart of the TSB.
    its a prerunner so my suspension is basically the same as the 4x4 brothers
  11. Feb 21, 2014 at 7:15 PM
    #671
    HXC
    HXC Well-Known Member
    Cory
    Houston, Texas
    2011 white Dbl cab 4x4 6spd man.
    I noticed that when I take my truck in to have it serviced they dont even follow the tire pressure that is posted on the door which is 29 front 32 rear they go straight to 35 all around. I had it in and when I drove it home it rattled at 70mph. I dropped the pressure the next morning to what the door says and it is significantly less and tracks better on the highway. I still have stock tires and rims on my'11 I think i have a hard spot on one of my tires and have had it in multiple times for balancing but nothing worked, finally just figured i would deal with it. Really frustrating since my toyota care just ran out and i dont want to pay for balancing when I know thats not the case.
  12. Feb 21, 2014 at 9:11 PM
    #672
    rusbob
    rusbob Active Member
    Pensacola, Fl
    2012 sr5 4x4
    Yeah, they kept it for a week, then had me come get the truck sayin' they had to order the parts. That was a week ago....
  13. Feb 22, 2014 at 7:43 AM
    #673
    KaPantsKey
    KaPantsKey Well-Known Member
    Kyle
    SC
    13 MGM DCSB TRD-OR
    Just got my truck back from the dealer. They ordered the insulator and a new 3-leaf pack, unfortunately. I requested the 4-leaf pack but they said they can't do that because the VIN does not call for it. Has anyone else got this answer? And has anyone done the TSB with the "new" 3-leaf pack and seen good results?
  14. Feb 22, 2014 at 9:52 AM
    #674
    KaPantsKey
    Kyle
    SC
    13 MGM DCSB TRD-OR
    I could give that a try, but they seemed like they wouldn't budge because of the VIN number. He said if I wanted the 4-leaf I'd have to pay.
  15. Feb 22, 2014 at 9:57 AM
    #675
    GTOJim
    GTOJim Well-Known Member
    Jim
    SF Bay Area
    2013 PreRunner TRD OffRoad V6
    My 2013 OR came with the three leaf pack. Had the TSB done and the dealer replaced my leafs with 4 leaf pack at my request. Guess it's going to depend on the dealer.
  16. Feb 22, 2014 at 3:47 PM
    #676
    nd4spdbh
    SoCal
    According to the tsb the off road package should of come with the firm ride suspension in the first place. but if your taco was built before October 2013 and you have the TRD or... You got the standard 2 leaf + overload
    To the person a few up saying they wouldn't order the 4 leaf... Put 400 lbs of weight in the bed... And show up to the dealer and state you want the 4 leaf pack as the truck is bottoming out. The squeaky wheel gets the grease... If they need a vin number tell them one moment... Walk out to a TRD sport on the lot and copy that vin
  17. Feb 22, 2014 at 4:32 PM
    #677
    KaPantsKey
    Kyle
    SC
    13 MGM DCSB TRD-OR
    I like your style. I will be moving in a few weeks, so I will make sure to load down the bed and bring it to the dealer. It just bugs me that some dealers do it with no questions and others are so anal. It's not money out of their pocket, so what does it matter? There should be some communication between dealers and Toyota. Maybe then they could fix issues on the first try.
  18. Feb 22, 2014 at 5:13 PM
    #678
    bear263
    bear263 Well-Known Member
    Florida
    2013 PreRunner TRD SP
    LED interior lights. Steering wheel mod. New radio. Amp, speakers and sub woofer.
    Please clarify the leaf spring count.
    3 springs is two with a helper or 3 springs is three with helper?
    My '13 trd sport has 3 with a helper.
  19. Feb 22, 2014 at 6:06 PM
    #679
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    3 is 2 with a helper(Non TSB), 4 is 3 with a helper(TSB)
  20. Feb 22, 2014 at 9:33 PM
    #680
    Carguyco
    Carguyco Active Member
    Colorado Springs
    2014 DCSB TRD Sport
    It does cost them money...Toyota pays them a lower shop rate to perform warranty repairs than does the regular "walk in" customer. I agree they should smile and take it..but some Service Managers pay plans make them feel "forced" to turn away the questionable warranty work
