Driveline vibration Tsb out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotacerttech, Dec 22, 2012.
  1. Mar 24, 2014 at 11:21 AM
    #821
    AR31
    AR31 Active Member
    Cleveland, Ohio
    2006 Tacoma TRD Sport 4X4
    Interesting. Bought mine used two years ago so I'm probably out of luck. Dam
  2. Mar 24, 2014 at 2:29 PM
    #822
    EWM
    EWM Active Member
    KaPantsKey, chas44, rainmn, Can you help with a favor? Can any of you look at the overload springs on your new leafs and let me know if the pads at the ends of the overload leaf are different between the drivers and passenger sides? Mine are smooth pads on the drivers side and rough textured pads on the passenger side. I don't know if it really matters, but just wanted to check it out.
    Thanks,
  3. Mar 26, 2014 at 2:59 PM
    #823
    Hydrotaco
    Hydrotaco Member
    South Louisiana
    TRD Off Road
    All finished up today, no more vibes :D ...
  4. Mar 26, 2014 at 6:47 PM
    #824
    mossyoaks
    mossyoaks Well-Known Member
    Chip
    Beaufort, SC
    I first noticed a squeak coming from the driveshaft/u joints about a year ago on my 06 Reg Cab w/50K miles. Ordered some joints w/grease nipples and planned to replace. Never got around to it as I only drive my truck about twice a week on short around town errands. The squeak went away.
    Then 6 months ago the 'shudder' appeared during acceleration 25mph+. That's when I was alerted to the TSP and all the woes experienced by others here on the forum. Too late for warranty work :mad:
    Now, the shudder is extreme. It's there in all the power bands, accel and deceleration. So severe that it rattles my phone out of it's cradle on the vent holder!
    When I stopped in to discuss with my local dealer's service manager, he was very familiar with the TSP and problem.
    He explains that they have lost $$$ attempting to repair via the TSP and that the problem is the driveshaft. Once the u-joints failed, the driveshaft became out of balance when internal balancing was thrown off. Only fix is new u-joints and driveshaft.
    Of course, Toyota will not assist in repair cost.
  5. Mar 27, 2014 at 5:40 AM
    #825
    KaPantsKey
    KaPantsKey Well-Known Member
    Kyle
    SC
    13 MGM DCSB TRD-OR
    Will do. Just saw this. Give me some time.
  6. Mar 27, 2014 at 7:16 AM
    #826
    chas44
    chas44 Well-Known Member
    Virginia
    2012 TRD Sport
    Just saw this too, I'll look this evening.
  7. Mar 27, 2014 at 5:19 PM
    #827
    mossyoaks
    Chip
    Beaufort, SC
    Good advice!
    Thanks Shipmate!
  8. Mar 27, 2014 at 5:50 PM
    #828
    devkurf
    devkurf Member at Large
    midwest
    So, does a rear lift change the drive line angles? Possibly causing/amplifying vibrations, and probably speeding up wear on the center support bearing?
    If that is true wouldn't the same would be true if the rear leaf springs lost their arc and dropped say 2-3 inches? You would see the same change in drive line angle, vibrations with the shaft, and early CSB failure. If I'm way off, let me know.
  9. Mar 27, 2014 at 5:56 PM
    #829
    AEmedic
    AEmedic Well-Known Member
    Boise, ID
    2014 DCLB 4X4 TRD Sport Supercharged
    TRD Supercharger, Toytec Adj. Coil-Overs, Bilstein 5100's, JL Audio system w/Kenwood DNX9980HD HU
    So, I have my appt set up for Monday. They printed me a list of what they said they will do but they didn't measure the driveline angles...
  10. Mar 28, 2014 at 2:06 AM
    #830
    MudFlap
    MudFlap Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    What fixes the take off shudder is the way the new leaf pack mounts to the axle. It turns the pinion angle slight upwards to straighten the angles a bit. Also IMO the main reason for the shudder was the weak leafs, when torqued by the drive line would twist into an "S" shape throwing off the angles even more. The stiffer springs prevent the twisting (or aka axle wrap).
  11. Mar 28, 2014 at 4:20 AM
    #831
    chas44
    Virginia
    2012 TRD Sport
    I agree with this. At first the leafs were pretty dern stiff, but now they feel pretty good.
  12. Mar 28, 2014 at 5:35 AM
    #832
    chas44
    Virginia
    2012 TRD Sport
    Yeah it was a little jarring at first when hitting bumps, etc. I will admit I am super happy with how this all shook out. I am noticing more and more that I have some decent rake and can't decide if I want to level or not. Definitely not before 36,000 miles though.
  13. Mar 28, 2014 at 8:35 AM
    #833
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The new springs turn DOWN the axle INCREASING pinion angle to match the angle of the trans u joint angle. Just look at the shims on the leaf springs.... fat end of the shim is on the front side of the axle.
    I LOVE how much more firm the new 4 leaf packs are over my original 3 leafs that came on my off road... it rides like a truck should now, and i dont have to worry about putting 100 lbs in the back and having the headlights shoot to the moon.
  14. Mar 31, 2014 at 4:37 PM
    #834
    akhermit
    akhermit Well-Known Member
    Anchorage Alaska
    12 DCSB Magnetic Gray Metallic TRD Offroad
    I went in today for my Toyota Care service, told them about my issue with the vibration again, and to my surprise, the head mechanic was aware of the TSB, and said they would order the parts. Should be a little over a week, then schedule an appointment. Much different than the last time around. I might get a smooth accelerating truck after all, which is the biggest issue I have with my Tacoma. Other than that, I love it.
  15. Mar 31, 2014 at 6:12 PM
    #835
    KMitch
    KMitch Well-Known Member
    Colorado
    14 DCSB TRD Off Road
    Got my truck back today. I also can confirm vibration is gone.
  16. Mar 31, 2014 at 9:02 PM
    #836
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Maybe that dealer just has A-holes in service area?
    A dealer service tech once told me the u-joints can't be done on 05 Tacoma and they'd have to replace the entire driveshaft as an assembly. I haven't gone to that dealer since then.
  17. Apr 1, 2014 at 12:44 AM
    #837
    CorpsmanUp
    CorpsmanUp Well-Known Member
    Gibby
    Suffolk, VA
    2013 Taco DCLWB 6in lift 35s 4.56s, air lockers AP F&R bmpers warn 10k winch Rigid fogs & floods custom pro top shell
    6in procomp stage 2 lift with PC Coilovers, 35x12.50 Nitto MTs, Moto metal 18x10 with -44 offset HID and LED's everywhere, ladder bars, rear disk brake conversion, hood struts, K&N cold air intake, Flowmaster 40 series, pro comp skid plates, train horn, pa system, all silver trim inside painted black all pro apex front bumper with full hoops warn 10k winch, all pro high clearance rear bumper with custom door hinge tag holder, pro top custom windowless camper shell. ARB onboard air compressor, rear ARB air locker, 4.56 gears front and rear, waterport pressurized water system, pop and lock tailgate.
    Anyone had this done on a lifted one yet? I've already got trac bars and a 1" carrier drop but still a little vibe on take off between 0-10mph.
  18. Apr 1, 2014 at 4:06 AM
    #838
    Tacoma Mike
    Southern Maine
    Can't ,,,,,,,,,NON MODIFIED VEHICLES ONLY...........
  19. Apr 1, 2014 at 10:43 AM
    #839
    TRDMEDIC
    TRDMEDIC Well-Known Member
    Sacramento, CA
    14 DC OFFROAD
    For those of you who got rid of the vibs with new tbs. Did you guys also have vibs at high speed 60-75mph. If so did that get eliminated as well?
  20. Apr 1, 2014 at 10:49 AM
    #840
    oklahomastig
    oklahomastig Well-Known Member
    Oklahoma City, OK
    2013 Tacoma TSS 4x4
    For those that have had it done, how long did it take to get new Leaf springs in? My 2013 went in about 3 weeks ago and I still haven't gotten any word from the dealer, and when I called, he said they weren't in yet. Is this typical?
