Driveline vibration Tsb out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotacerttech, Dec 22, 2012.
  1. May 28, 2014 at 5:44 PM
    #1001
    BillyP
    BillyP Well-Known Member
    Billy
    Cedar Point, NC
    13 DBL Cab TRD-OR
    Well, I got her back today. They replaced the rear springs and added the steering dampner. They had already added the transmission mount.
    No vibrations while accelerating, but I do have a vibration from 30-25 while braking and a little vibration when cruising at 58-62. Will see how things go... don't know if it will bother me.
    At least I got it back... after 3 1/2 weeks :rolleyes:
  2. May 29, 2014 at 8:16 AM
    #1002
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    2012 Tacoma TRD T|X Baja
    Pelfreybilt IFS Skid, Mid Skid and Plate Bumper, Rigid Industries Dually's, ARB CKMA12 On Board Air, Kenwood TM-281A Radio, Rear view mirror relocation bracket, Wheelers SuperBumps, Toytec Baja Spacer
    Went ahead and did the TSB. I was a bit hesitant seeing mixed results. They did the leaf pack, steering wheel dampener and one other thing (its on my paperwork) so far so good. No more vibration and it feels a lot smoother than it did. Still driving it around and will report back after more than one days use.
    Alex
  3. May 29, 2014 at 11:21 AM
    #1003
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    What's the actual difference between firm ride and standard ride? Would the firm ride be less prone to sagging and have better load capacity?
  4. May 29, 2014 at 11:46 AM
    #1004
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Further to the question above, I'm going to be contacting my dealer regarding this TSB.
    What else should I have them look at on my 2013 while it's there?
    Tranny Fluid Level for example?
    Anything else?
    Cheers,
    Jay
  5. May 29, 2014 at 1:07 PM
    #1005
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    firm ride = 3+1 leaf pack, standard = 2+1
    DONT ACCEPT ANYTHING other than the 3+1 leafpack.
  6. May 29, 2014 at 1:47 PM
    #1006
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Gotcha, thanks!
    My 2013 already has the 3+1. I wonder how I would find out if it's already got the updated TSB springs or not?
  7. May 29, 2014 at 3:34 PM
    #1007
    nd4spdbh
    SoCal
    do you have a TRD SPORT or SR5 with the tow package? if so your truck came default with the 3+1 leaf packs.
  8. May 29, 2014 at 4:26 PM
    #1008
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Ya, it's a TRD sport with tow package and came default with 3+1. Just don't know if they actually changed anything on the 3+1 springs since 2013 or if I already have the latest?
  9. May 29, 2014 at 5:26 PM
    #1009
    nd4spdbh
    SoCal
    your 2013 springs are not the same as the 3+1 leaf packs found from the TSB. they are different
  10. May 29, 2014 at 6:47 PM
    #1010
    wesplains
    wesplains Well-Known Member
    West
    Middle of USA
    Tacoma TRD Sport
    SnugTop, Aries Stealth Bull Bar, OEM Bed Mat, Wet Okole Seat Covers, Husky Floor Mats, OEM Cab Rack, Amp Bed Extender, VooDoo Bad Brackets with Cargo Basket. Yakima racks on cover. MagnaFlow Muffler, KC Running Lights, Console Vault, Dash Cam, Side Moldings, UltraGauge
    (nd4spdbh) your 2013 springs are not the same as the 3+1 leaf packs found from the TSB. they are different.
    Not trying to be a smart ass, but how do you know? What is the difference?
  11. May 29, 2014 at 9:07 PM
    #1011
    chas44
    chas44 Well-Known Member
    Virginia
    2012 TRD Sport
    I just wanted to check-in, got my tsb done a few months ago and everything is fine, still no vibes.
    Wondering if anyone has leveled the truck since getting the new leafs? Doesn't matter how, but if you did can you state what equipment you used? The rake on my truck is starting to itch me towards leveling and would be curious about others' experiences.
  12. May 29, 2014 at 9:23 PM
    #1012
    nd4spdbh
    SoCal
    Not exactly sure what the main difference is. Obviously different part numbers, looks like the overload leaf is a little different and the different degree shims on the bottom of the leaf pack.
  13. May 31, 2014 at 7:30 AM
    #1013
    EWM
    EWM Active Member
    It looks like the 2 leafs below the main one are a bit longer than the originals, but the main difference is that the overload spring is flatter. The overload on my originals was really negatively arced and allowed the axle to wrap more.
  14. Jun 1, 2014 at 3:55 AM
    #1014
    hambone11
    hambone11 Active Member
    Jack
    NYS
    13 TRD Off Road
    Got the TSB done on my `13 TRD Off Road Taco and noticed vibration at about 35 mph down to a dead stop. Dealer had it for a week, swapped out driveshaft, rechecked installation on TSB and swapped out a set of tires from another truck on the lot. They road force balanced all my tires and found they could not balance them out. Tires out of round they say. Dealer working with BF Goodrich and Toyota to warranty me a new set of tires. Still not convinced that`s the problem but if the dealer is willing work towards new tires I say go for it and see if that works. If not back to the drawing board! Pisses me off. I have had GM trucks all my life until this Taco. Constantly back to the GM dealer with various issue. Guess Toyota is no different.
  15. Jun 1, 2014 at 10:09 AM
    #1015
    crooks420
    crooks420 Well-Known Member
    Jesse
    San Gabriel
    05 AC Prerunner SR5, 12 DC LB 4x4, 70 FJ40
    I have 81,000 miles on my 2005 AC 4-cyl., manual Pre-Runner and it is great; Aside from the leafspring TSB done in 2009, the only other services have been oil changes and replacing the airfilter a few times..... great truck with zero issues.
    So far the same with my 2012, but I only have about 7,000 miles on that one (I still drive the 05 mostly).
    Jesse
  16. Jun 1, 2014 at 10:32 AM
    #1016
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    If the prob. disappeared with the tire swap, why wouldn't tires be the cause? It would have been nice to drive it with the tire swap though....
  17. Jun 2, 2014 at 10:08 AM
    #1017
    crsexmex
    crsexmex Active Member
    Vinny
    Clinton, Ut
    2012 Off-Road
    HID Kit Nokya 3K Fog bulbs
    Just dropped off my 2012 at the dealership for the vibe. I drove with a service rep and he agrees with the issue so hopefully it will get fixed.
  18. Jun 2, 2014 at 10:13 AM
    #1018
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I went to Kelowna Toyota on Saturday to book an appointment for my vibrations on takeoff as well as cruising around 75km/h.
    The lady's attitude at the service desk totally rubbed me the wrong way. Everything she said basically made me feel like I was arguing with her.
    First asked if I was lifted. I said yes, with the OEM TRD Baja. She asked who installed it and I said a different shop, she said you may have to return the truck to stock before they will look at the vibration. I mentioned a new TSB that came out in Feb and she said that was for the US and doesn't apply to Canada! Anyway, it went on from there but needless to say, I wasn't impressed with her negative attitude!
    I was going to install my Wheeler's AAL's this weekend, but decided to wait until after it gets looked at.
    My appointment is booked for June 13th so we'll see what happens.
    Cheers,
    Jay
  19. Jun 2, 2014 at 10:48 AM
    #1019
    crsexmex
    Vinny
    Clinton, Ut
    2012 Off-Road
    Just got off the phone with the dealership and the service rep told me to hold off on the TSB because of a conversation he had with Toyota. I was told Toyota is in working on a "fix" since the current TSB is not a cure to the problem. If I don't hear anything in the next 6 months, I'm getting the TSB done. Time for me to eat an EAD Sandwich... :playball:
  20. Jun 2, 2014 at 11:31 AM
    #1020
    KMitch
    KMitch Well-Known Member
    Colorado
    14 DCSB TRD Off Road
    I did a 2.5" OME lift with progressive 3 pack AAL after the TSB. Without the CB drop kit, I had a slight shudder from 25-30mph (only could notice on slight acceleration or deceleration). Once I put in the drop kit, I only notice the slight shudder from 25-27mph. Could probably add a washer or two and try it out but doesn't bother me enough right now to try.
