Driveline vibration Tsb out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotacerttech, Dec 22, 2012.
  1. Jun 2, 2014 at 11:46 AM
    #1021
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    ANOTHER TSB.... jezus.
    Sounds like the guy had old information as dealers were told to hold off on the OLD tsb in order for this new TSB 0008-14
  2. Jun 2, 2014 at 6:31 PM
    #1022
    bentaxleracing17
    bentaxleracing17 I'D BRRAAAP THAT
    Kansas
    2014 Double Cab TRD 4x4
    XD ADDICTS W/KM2s Leveling kit
    I bought the 2014 TRD Sport 4X4. Now has 3500 miles with a leveling kit. Getting a pop/thud from the right rear when going over 45mph tracks or other bumps. Have not yet taken it to the dealer. I have checked u-bolts and re-torqued. What should I look for??
  3. Jun 2, 2014 at 8:20 PM
    #1023
    bueller
    bueller Well-Known Member
    AZ
    I would bet he's wrong and he's talking about the previous TSB. TSB-0008 is the newest one and seems to be working rather well based on reviews here in this thread, me included.
  4. Jun 2, 2014 at 8:33 PM
    #1024
    rusbob
    rusbob Active Member
    Pensacola, Fl
    2012 sr5 4x4
    TSB-0008 worked for me too. No more vibes.
  5. Jun 2, 2014 at 9:12 PM
    #1025
    crsexmex
    crsexmex Active Member
    Vinny
    Clinton, Ut
    2012 Off-Road
    HID Kit Nokya 3K Fog bulbs
    I really don't know what kind of BS is going on but I can wait a couple months to see if any new updates come out. I found it a bit odd when the rep said TSB-0008 doesn't fix the problem. I'm sure Bueller is right and they're going off of old information.
  6. Jun 2, 2014 at 11:55 PM
    #1026
    bueller
    AZ
    The reason I said that is because when I took my truck in the first time, I got the same exact answer as you did. I had to be the one to tell them about TSB-0008 as they knew nothing about it. It took three dealers before I found one that knew what they were looking at and performed the TSB.
  7. Jun 3, 2014 at 6:37 AM
    #1027
    ReidStylez
    ReidStylez Well-Known Member
    Reid
    Kansas City
    11 PreRunner SR5
    Anyone know if they'd do this TSB if I've installed helper air bags?
  8. Jun 3, 2014 at 6:40 AM
    #1028
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    probably not, you need to put it back to stock
    does it matter no, but can they refuse tsb yes.
  9. Jun 3, 2014 at 6:42 AM
    #1029
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    agreed. when I went in the foreman said doesn't work and he had not yet done 0008-14....mine was the first 0008-14 and it worked great and the foreman wrote it all up and send it back to toyota corp that it worked.
    for every tsb installed that works or doesn't work, toyota corp. tracks it all
  10. Jun 3, 2014 at 8:45 AM
    #1030
    crsexmex
    Vinny
    Clinton, Ut
    2012 Off-Road
    Thanks for the info... I'll be going back to get this done.
    Makes me wonder if they even called Toyota... Thanks bra! By the way your truck has the best color ever.. :D
  11. Jun 3, 2014 at 9:45 AM
    #1031
    nd4spdbh
    SoCal
    Best thing you can do... PRINT OUT THE TSB AND SHOW IT TO THEM.... from my expierence you literally have to force feed them the knowledge as 95% of them dont know much more than how to change oil... and barley at that.
  12. Jun 4, 2014 at 10:56 AM
    #1032
    GTOJim
    GTOJim Well-Known Member
    Jim
    SF Bay Area
    2013 PreRunner TRD OffRoad V6
    Dealer did the TSB on my 2013 with air shocks.
  13. Jun 4, 2014 at 11:32 AM
    #1033
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    That's great info Jim! Thank you!
  14. Jun 4, 2014 at 4:01 PM
    #1034
    AEmedic
    AEmedic Well-Known Member
    Boise, ID
    2014 DCLB 4X4 TRD Sport Supercharged
    TRD Supercharger, Toytec Adj. Coil-Overs, Bilstein 5100's, JL Audio system w/Kenwood DNX9980HD HU
    They would not do the TSB on my truck because I added the Toytec adjustable COs on the front of mine to carry the weight of the heavy plate bumper. It is at almost exactly stock height and they said no way... They consider it a lift/leveling kit. My argument was that it is currently no different than just buying new stock replacements from Napa and they said no way.
  15. Jun 4, 2014 at 6:01 PM
    #1035
    nd4spdbh
    SoCal
    go to a different dealer or go back and be like look. the rear is UNTOUCHED.
  16. Jun 5, 2014 at 5:59 AM
    #1036
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    please reread the tsb and understand why any modified suspension throws out the ability to perform the tsb. the protractor can only measure accurate angles if vehicle is ride height front and back. it is measuring to 1/10th degree. if front is lifted in the slightest the angles will be off therefore garbage measurement.
    sheesh
  17. Jun 5, 2014 at 8:52 AM
    #1037
    nd4spdbh
    SoCal
    OY... more mis information. You will get the same measured rear pinion angle with the stock rear suspension if you had the front lowered on 20in tires as you would lifted 6in with 37s... as the rear relative joint angles DONT change with regards to the front height of the truck.
  18. Jun 5, 2014 at 9:24 AM
    #1038
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    nope. the protractor measures the driveshaft angle relative to the ground. any lift front or back changes the angle of the dangle and measurements are crap
    but you can keep believing what you want.
    no tsb if suspension modified from stock
  19. Jun 5, 2014 at 9:42 AM
    #1039
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    Toyota will not ( and should not) take any responsibility for any mod to the truck relative to performin the TSB. Any mod will have to be removed back to stock; the base condition the TSB is supposed to fix. Then after the TSB put your mod back on. May be a pain, and mod may not matter to the rear angles, but that's the way it is.
    I'm making an appointment for scheduling the TSB work on my prerunner. I'll tell them in the appointment the TSB number, explain what it's supposed to do, plus all the other work done incl. tire balance and alignment so they cannot blame it on something else. Also I'll ask them about the availability of the measurement tool (checked with SnapOn, it's $89.00) so when i take it in there's shouldn't be any misunderstanding.
    I've NEVER had a dealer pay attention to TSB's unless they're forced to.
    Then we'll see what happens.:confused:
  20. Jun 5, 2014 at 9:53 AM
    #1040
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    +1 if you can get an alignment.
    the TSB geetered my front toe slightly
    (even microscopic changes in back can change thrust angle and front toe)
    needed front end alignment to make steering wheel centered again like it was originally
    truck is 100% I could not be much happier. whole new world...I drove it one year before tsb. I guess you -can- polish a trd after all
