Driveline vibration Tsb out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotacerttech, Dec 22, 2012.
  1. Jul 21, 2014 at 4:23 PM
    #1081
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Dealer called me today and my parts are in, didn't take long at all. I have an appt. set for this Friday at 7am so I will reoport back after it is completed.
  2. Jul 22, 2014 at 4:13 AM
    #1082
    bw4706
    bw4706 Well-Known Member
    Illinois
    09 Toyota Tacoma DCSB
    Bilstein 6112's , Eibach Coils,Hankook Dyna Pro MT 265/75/16, SPC UCA's, General Spring HD leaf packs, De-Badged, Ranch Bed Cap, Mag Light Seat Mount driver and passenger, Mini Mag Console Mount,Hard wired GPS, LED's in and out, MB TKO Wheels, After market grill, Heated seats, Diff breather relocation mod, LED Under Hood Lighting, LED Bed Lights, Aux. LED Reverse Lights, 30" L.E.D. Light Bar, Redline Tuning Hood Struts & EZ Down Tailgate. 6 Circuit Aux. Fuse Panel W/Circuit Breaker. Front & Rear Facing DVR cameras, High Lift Jack Bed Rail Mount. Clazio Leather Seat Covers. All Pro Heavy Duty Rock Sliders, 4x4 illuminated switch mod, Ignition converted to Push to Start. Bushwacker fender flares, Cali Raised side projector ditch lights. Cali Raised L.E.D. fog lights. 3 x 3 L.E.D. rear spotlights , Anzo headlights and taillights.
    The dealer replaced every part like the TSB stated. The general spring leaf packs are identical to the TSB springs (3 leafs plus one overload ) as far as the amount of lift they provide. The TSB probably works 10 -20% of the time. I have yet to see a total fix for this issue. Three techs I know at the dealer have the same issues after doing the TSB on their own trucks. Hopefully others have better luck.
  3. Jul 22, 2014 at 8:43 AM
    #1083
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yes they might have a 3+1 setup between the TSB spring and general spring... that does not mean they are made the same.... the TSB spring has a different overload spring to reduce axle wrap than the old OEM spring (which is one of the major factors in the vibration)
    Also the lift ammount you might of gotten is the same but do you have 2* or 3* shims turning the pinion down on your general springs... no, which is what the TSB springs have.
    Again, your screwed yourself on the TSB because you didnt use TSB springs.
  4. Jul 22, 2014 at 9:03 AM
    #1084
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    No. There is nothing in the manual calling for greasing them and no zerks available for a grease gun.
  5. Jul 22, 2014 at 1:28 PM
    #1085
    nd4spdbh
    SoCal
    do some searching.... i think it was either 07 or 09's all started to come with zerks on the driveshafts.
  6. Jul 24, 2014 at 6:48 AM
    #1086
    bw4706
    Illinois
    I'm at 59K and filing complaints with the BBB and Toyota Corporate was enough to get them to do mine. I was also given a credit for the price of the General Spring HD leaf packs I purchased before they agreed to do the TSB
    The vibe is still there, so they are now having a Rep. come out next week to see what he says about getting the vibe issue solved. We'll see what happens.
  7. Jul 24, 2014 at 7:24 AM
    #1087
    nd4spdbh
    SoCal
    hes going to say.... you didnt use the TSB leaf pack and thus the TSB was not followed thats why there are still vibes.
  8. Jul 24, 2014 at 8:02 AM
    #1088
    bw4706
    Illinois
    The dealer had no problems with the leaf packs. They are identical to the TSB leafs. That's why they gave me a full credit for the price of the leafs and the labor I paid to have them installed. I'm also getting this all done for free and out of warranty. You seem to be stuck on the leaf packs for some reason. Have you measured the General Springs and compared load ratings with actual weight in the bed ? I'm curious to see your results. Your comparison may be helpful to me and others.
    Also, How did you eliminate all your vibes ? Do you have any info on a TSB which states they provide axle shims ? I haven't seen this on the TSB.
    I'll ask them about the shims next week.
  9. Jul 24, 2014 at 9:28 AM
    #1089
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    The shims he is talking about are now part of the new TSB leaf-packs, page 6-8 of the new TSB cover all the different TSB packs that are available for the trucks depending on your drive line angle specifications. What was the part # of the springs you had them install? If you look under your truck to you have a shim under the leafpack?
  10. Jul 24, 2014 at 10:48 AM
    #1090
    nd4spdbh
    SoCal
    like stated before... the ENTIRE thing about this TSB is the PROPER leaf springs.... while yess your general springs had 3 leafs + 1 overload and fit on the tacoma, the similarities stop there. The TSB leaf packs have a slightly different overload spring that reduces axle wrap by contacting the main leafs sooner, as well as having proper degree shims depending on the angles measured by the dealer.
    Your general springs ARE the problem to why you still have the driveline vibes plain and simple.
  11. Jul 24, 2014 at 1:46 PM
    #1091
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    think of the shims as the 5th leaf on a 4 leaf pack (3 fulls, 1 helper, 1 shim)
    it is one unit with a specific Toyota part number depending on how fat the shim is that is stuck to the pack itself
    TSB is exactly this:
    1) confirm vibe
    2) drop prop shaft drive in FWD confirm vibe is gone
    3) put back together
    4) replace tranny/engine mount (severe vibes can wreck the original one)
    5) install steering damper (useless but needs to be done)
    6) ---edited---proceed to 7
    7) lift vehicle on ride-height apparatus such as alignment rack (wheel lift)
    8) grab digital protractor and measure sh*t, do some maths
    9) according to the math in step 8, install one pair of the specified Toyota leaf packs listed in the TSB
    skip any of this and still have vibes ? you did it wrong.
    do all of this and still have vibes ? work it out with Toyota california
  12. Jul 25, 2014 at 5:59 AM
    #1092
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    Your step 6 isn't there; (unless they changed the bulletin)
    Once you change the tranny mount, in all cases, have to measure and do the spring replacement...
    [Step 4, (4A,B,C,D) in the bulletin is the damper; goes right to step 5 (raise on drive-on hoist/alignment rack.) and step 6 (angle mesure)
  13. Jul 25, 2014 at 7:06 AM
    #1093
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    right, my bad...straight to protractor....edited
  14. Jul 25, 2014 at 7:28 AM
    #1094
    gravedgr
    gravedgr dirty Ford driver
    Doug
    Alpharetta, GA
    2014 Tacoma 4x4 DCSB TRD Off Road (Blue) - gone
    Method Racing Mesh wheels (17x8.5), Cooper ST Maxx tires (285/70/17), Toytec Ultimate lift (3"), Wet Okole seat covers, WT mats, Gemtex mirror, CF stubby antenna, scoop hood, painted grill surround, SOS bumper, SOS bed rack, Tepui Autana RTT, Engo 10k winch, bed lights, under hood lights, diff breather, 12v bed socket, 31M battery + battery monitor
    Skipped to the end of the thread to ask - does this apply to 2014s? I think I have a faint vibration when accelerating, up until around 20-25 mph.
  15. Jul 25, 2014 at 8:12 AM
    #1095
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2005 – 2014
    T acoma T ransmission(s): 5AT
    VDS(s): JU4GN, JU62N, KU4HN, KU72N, LU42N,
    LU4EN, MU4FN, MU52N, TU4GN, TU62N,
    UU42N, UU4EN
  16. Jul 25, 2014 at 7:27 PM
    #1096
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Took my truck in today for the TSB and wow is all I can say! The truck should of came like this from the factory, night and day difference and my vibes are gone. It took two service appt. to have it performed, one to drop the drive shaft and confirm and then today's appt. to install all parts. The 4 leaf pack rides really well and I gained my height back in the rear.
    What I did find interesting is that none of the 14' Tacoma's on the dealer lot had any degree shims with the 4 leaf pack. Everything but the reg cabs now have the 4 leaf pack though.
  17. Jul 26, 2014 at 12:13 PM
    #1097
    OCNutty
    Northern, Va.
    With your expertise, probably checked this; but is everything torqued right? I can see 2k later miss-torqued parts showing a problem. Other have reported loose shock bolts etc.
    Anyway, even tho the truck is outside the 3/36, you have a year on their fix to gripe. Maybe torque on leafs, maybe another bad drive shaft?
    There is a tsb out for replace of dr shafts (under the 5/60) for prerunners for rear end hit.
    Good luck.
  18. Jul 28, 2014 at 11:47 PM
    #1098
    davidk890
    davidk890 Member
    david
    seattle
    '11 Tacoma 4x4 TRD Sport
    I have a 2011 tacoma DCLB,
    bought it off auction for a great deal with 28k in september.
    now it has 50700,
    it started vibration at accels and sometimes during decels. it was worse at inclines.
    took it into toyota of lynnwood Wa.
    had a tech test drive it and
    then was told that the "diff/driveline/driveshaft was slipping or locking up" i dont remember her exact words and when asked to explain.
    she could not give me a answer, other than that the driveline will be replaced
    under 60k warranty.
    TLDR; What should i expect in this situation?
  19. Jul 29, 2014 at 6:32 AM
    #1099
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    not enough info...that statement about the problem is all over the place and not make sense. driveline replacement means pinion, cb, front and rear shafts, u-joints. no way all that is bad or 'slipping'
    it just doesn't make sense
  20. Jul 31, 2014 at 3:05 PM
    #1100
    SLOBRA
    SLOBRA LET IT EAT®
    Albuquerque, NM
    2012 DCSB 4x4 TRD O/R
    Dropped my truck off at the dealer this morning for the 15-25mph vibration. They just called and said the driveline angle was +.5 degrees and are ordering a transmission mount, rear leaf springs, and a steering dampener to be installed next week. Here's hoping...
