Driveline Vibration TSB #T-SB-0132-08 / feedback needed??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ACE_Taco, Mar 25, 2010.
  1. Mar 25, 2010 at 3:20 PM
    ACE_Taco
    ACE_Taco [OP] Long Range Practical Marksman
    NC
    08 DBLCab TRD 4x4
    OME 885x Coils, Dakar Leafs, OME Shocks, TC UCAs, BHLM, Tailgate MOD, WeatherTec Window Deflectors, WeatherTec Floor Mats, Blacked Out chrome bumber, Satoshi Grille, Wet Okole Seat Covers
    I would like to hear from you all that had this Driveline TSB done. Did it help with your vibration problem?
    After all the vibe issues I had, my original dealership stated that my '08 already had the new mount. However, I took it to another dealership today and they removed the DS. Then, they drove it in 4H and said the vibes were not there. They have me scheduled for the TSB.
  2. Mar 26, 2010 at 12:00 PM
    DIRTRIDER
    DIRTRIDER Active Member
    EAST AURORA,NY
    07 WHITE SR5 4X4 V6
    BULL BAR,DRIVING LIGHTS W/ OEM SWITCH,BLACK STOCK WHEELS,265/75/16 TIRES,XM RADIO,EXTRA BED D-RINGS,SPRING TSB,5100'S @ 1.75",FOG LITE MOD, A/C COMP.MOD
    I had a low speed vibe, 2/3 upshift and downshift between 10-25mph about 2000mi after i had 5100's set at 1.75 and the rear spring tsb done.265/75/16 a/t tires. The dealer installed the tsb mount and two rear driveshaft u joints, cured about 1/2 of the vibe. I ended up putting in the carrier bearing drop kit and 3 degree shims in the rear axle to cure the rest of the vibe. 07 accees cab with v6 auto.
  3. Mar 26, 2010 at 2:57 PM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    Thanks for the feedback. I called the dealer again today and the Service Advisor mentioned that the mount I had was not the updated one. I hope it helps my issue with vibes.
  4. Aug 20, 2010 at 7:14 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Bumping to bring this back up...
    Has ANYONE gotten this TSB performed?
    "Some customers may complain about a vibration felt in the seat, floorboard, and/or steering wheel between 15 – 25 mph caused by a second order driveline vibration. Use the following repair procedure to address this concern."
    "• This repair is covered under the Toyota Powertrain Warranty. This warranty is in effect for 60 months or 60,000 miles, whichever occurs first, from the vehicle’s in-service date.
    • Warranty application is limited to correction of a problem based upon a customer’s specific complaint."
    Now that I have the axle-wrap thumps pretty much licked, this vibration is ever so much more apparent to me.
    Any experiences at all? Did it solve your problems of this sort if you got it?
    Thanks!
  5. Dec 5, 2010 at 12:55 PM
    yodaman
    yodaman Active Member
    Bellingham
    07 TRD Sport 4x4 V6 Automatic
    Yokohama tires Skyjacker canopy add more later
    Just had the TSB done on my truck. I'm still undecided about it. As crazy as this sounds when I'm driving to my home which is uphill for several miles I don't feel the vibes but when going down hill away from my home I feel them???
    I need to drive my truck a bit more to decide.
  6. Dec 5, 2010 at 1:01 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    It was better after I got the TSB done. However, it was still there. Its not as noticeable anymore. The engine rattle, leaf squeak and dash noise kind of muffle it.
  7. Oct 1, 2011 at 9:32 AM
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    11 DC TRD OR 4x4 Pyrite Mica
    Hopefully this is what I need.
  8. Oct 1, 2011 at 9:36 AM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    06 Prerunner 4.0 a/c beast
    k&n cai 63 series intake, blacked out headlights, blacked out tailights, magnaflow pro offroad 17115 dumped, URD competetion y-pipe, total chaos 3.5" long travel, fox 2.5x8" remote resevoir shocks, allied 4" spindles, toytec 2" AAL, 20% tint up front and 5% rear, satoshi grille, ddm 50w 6000k hid's. wet okole custom trd seat covers with heaters. 4:56 nitro gears with arb rd129 air locker, arb ckmta12 dual air compressor.
    check u joints
  9. Oct 9, 2011 at 12:50 PM
    matts11
    matts11 Well-Known Member
    TN
    Has anyone had this tsb done on a model later than a 2008? The TSB make sit seem like they had a production change in components and thus this does not apply to 09-11 model year trucks. True?
  10. Jan 11, 2012 at 9:07 AM
    Sgtfluffy16
    Sgtfluffy16 Well-Known Member
    Corey
    PA
    07 Tacoma Double Cab TRD Sport
    20% tint, HID headlights/ yellow fog light bulbs and LED lights interior/exterior lights. 4.5 Inch RCD lift, 1 Piece custom driveshaft, AEM intake, Dynomax Exhaust, Amp research Moto-bed extender, Extang Express tonno.
    If my 07 has 76k miles on it and im not the original owner.. does anyone know how much it costs for the parts outta pocket?
  11. Apr 29, 2013 at 11:16 AM
    rlandr
    rlandr New Member
    pennsylvania
    toyota tacoma
    had the rear springs replaced, transmission mount and steering dampener, vibration still there
  12. Apr 29, 2013 at 1:10 PM
    Grieby54
    Grieby54 Horsebit
    Sam
    Castle Rock, CO
    '13 TRD Off Road 4x4 DCSB MGM JBL/Entune/Nav
    WeatherTech Digital Liners, ImMrYo rear view mirror bracket, color matched grille, Tacoma door sill protectors, OEM hood protector, clear bra, tint, OEM roof rack, trimmed front mud flaps to match rear clearance, debadged, color matched grille, Plasti Dipped front Toyota emblem, OME 884X coils with trim packer on driver's side, OME Nitro Sport 9000 shocks, Deaver/ToyTec AAL with OME N182 shocks, 265/75/16 Duratracs, ProComp 7032 16" wheels
    Had it done and my vibration is worse.
  13. Apr 29, 2013 at 3:27 PM
    tpr676
    tpr676 Well-Known Member
    Plus drive shaft, still there.
  14. Dec 3, 2013 at 7:31 AM
    BWHolmes
    BWHolmes New Member
    WV
    13 TRD Sport Crew Cab
    I have a 2013 TRD Sport Double Cab with 11 k on it and just developed noise and vibration on low speed deceleration. Headed to the dealer.
  15. Jun 1, 2015 at 1:02 PM
    Sgtfluffy16
    Corey
    PA
    my vibrations have gone away with the frame replacement and rear leaf spring recalll
