Driveline Vibration with Lift - vote yes or no!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 96er, Jun 7, 2010.
Driveline vibrations after 2-3" lift?
Poll closed Jul 7, 2010.
  1. Yes I had driveline vibrations
    17 vote(s)
    34.0%
  2. No I did not have driveline vibrations
    16 vote(s)
    32.0%
  3. Stop being a pussy and just do it, its not going to cause any issues
    17 vote(s)
    34.0%
  1. Jun 7, 2010 at 6:06 PM
    96er
    96er [OP] Sport Rally'er
    MA
    '96 Tacoma XCab 4x4 SR5
    Ok so after reading Steve O's thread, its made me slightly re-consider my soon to be setup of OME 881's with the wheeler's 5 leaf pack. Maybe I should just do brand new shocks at all 4 corners with new rack and sway bar bushings. I'd love to have the 2" of lift, but not at the expense of stupid vibration. My main concern anyway is getting rid of the pitiful, soft, jarring ride I am currently experiencing - 194k miles and all original suspension. My sway bar bushings look like somebody put them in the microwave for 2 minutes then reinstalled them.
    So help me out on which direction I should go, is this a hit or miss thing? Or are the vibes more of an exception than the norm???
  2. Jun 7, 2010 at 6:51 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I plan on making some carrier bearing spacers to correct the vibes like tacomaman06 did. I will let you know how they work when I get around to it.
    The vibes I have now really aren't bad though and only start after 55 mph.
  3. Jun 7, 2010 at 10:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I had two different vibes post lift. One at +55 mph and the other between 20 and ~28 mph. Figured out right away that I was too high in the front and adjusted the COs down. This eliminated the +55 vibe. The slow speed vibe was harder to figure out. It turned out to be driveline. A half inch drop of the carrier bearing eliminated the vibe. :woot:
  4. Jun 8, 2010 at 6:32 AM
    96er
    MA
    Thanks for the replies guys...I'm going up 2" in the front and 1.5" in the rear, this is lower than most who do the 2.5-3.0" in front, so are my chances for vibration really minimal or is every truck different no matter what height over stock you go??
  5. Jun 8, 2010 at 6:56 AM
    rmarqu2
    rmarqu2 YES... i am a murse....
    Roger
    Baton Rouge
    09 Black 4x4
    FOX 2.5 coilovers, FOX 14" rears, AP expos, AP front plate bumper and skid, lightforce 240 blitz, warn m8000, 3/8 amsteel, BAMF sliders, cheap Chinese rock lights, ARB lockers all around
    I just find I have a little vibration in the steering column when wheeling and it's only when goin over really bumpy stuff.
  6. Jun 8, 2010 at 7:45 AM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    I put a 2.5 inch lift on and it sounds just like it did stock, no problems for me.
  7. Jun 8, 2010 at 9:48 AM
    Digiratus
    Roaming the PNW
    The RedHead
    There does seem to be some inconsistencies from truck to truck. Those numbers (2" front, 1.5" back) are merely estimates. YMMV.
    In general, you are less likely to have the vibrations I had.
  8. Jun 8, 2010 at 9:56 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Anytime you alter your driveline angles, there is a chance of vibration. 7 degrees differance is the absollute max a u-joint can manage. After that, it will wear and bind.
    Shims to adjust the rear axle back to under 7 degrees will fix that. You may have to shim the carrier as well.
    3" max lift on the front is recomended on the front cv joints, without modifications to the drive shafts.
  9. Jun 8, 2010 at 11:09 AM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    Steve o, I have the CB shims that I removed from my truck after I removed the DB kit. If you need 'em let me know? I removed 2 out of 3 (per side) after getting rid of blocks. Much smoother now
  10. Jun 8, 2010 at 1:34 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Well, I already have the materials laying around so I think it'll be easier to just make them. Thanks though.
  11. Jun 8, 2010 at 7:09 PM
    DblstuftTaco
    DblstuftTaco Well-Known Member
    Joe
    Ohio
    02 TRD SR5
    OME 3" Kit New frame
    I got the OME 3" kit from toytec also got the front differential drop. Lifted it a full 3" in the front. AAL added about 2.5 in the rear. No vibes. Ride's a little stiffer, not too bad tho. Just need an alignment, which I haven't gotten yet.
  12. Jun 9, 2010 at 11:31 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    Now: 12 T4R SR5 Then: 99 - 3.4L SR5 4WD
    Wheeler's/Alcan 5-pack leaf springs, Bilstein 5100's front and rear, OME 881's, de-badged, Jungle Fender Flares, Herculined bed, HomerTaco grille, Anzo headlights, clear corners, CVT Mt. Bachelor RTT, custom bed rack & CBI sliders
    Suck it up and do the upgrades.
  13. Jun 9, 2010 at 12:39 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I just got done making my spacers, I will test them maybe tonight.
  14. Jun 9, 2010 at 6:16 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    You want shims. Cheap and easy and eliminate the vibration if done right.
  15. Sep 10, 2010 at 9:34 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    nearly 3.5 inches of lift on mine, hopefully it will settle down once it gets broken in but to my surprise there arent any driveline vibes at all speeds. the angle looks a little severe but it functions perfectly
  16. Sep 11, 2010 at 7:50 AM
    malander
    max
    01 limited trd 4x4
    i take that back started noticing slight vibes at 53 mph hopefully a diff drop and carrier bearing drop will fix it up but ucas are still good to go
  17. Sep 11, 2010 at 8:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Take a close look at your CV boots. The high speed vibes might indicate the slightest touching of one of the ribs against another. If they touched, you will be able to feel it as a groove.
    I'm still riding on one that has a groove. :eek:
  18. Sep 12, 2010 at 10:35 AM
    malander
    max
    01 limited trd 4x4
    well hopefully i can figure out something to fix it thanks for tha advice
  19. Sep 13, 2010 at 1:36 PM
    RebelRider201
    RebelRider201 Well-Known Member
    J
    South, AL
    PreRunner
    5% tint, black emblem/grille/etc, 10k hids, Flowmaster super 44, Tuff Country 3", 1700w amp, Kicker L7 12.......and on
    Since the voting poll is closed, "Stop being a pussy and just do it, its not going to cause any issues" I've had a 3-4" lift with leveling kit on my Prerunner for 2+ years and have had no issues so far.
  20. Sep 13, 2010 at 3:25 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Easy for you to say, you don't have any front axles to worry about.
