Driveline vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jfoster92, Dec 20, 2016.
  1. Dec 20, 2016 at 6:43 PM
    jfoster92
    jfoster92 [OP] Well-Known Member
    Justin
    Farmerville, la
    08 Tacoma prerunner v6/manual
    Ok for starters I have an 08 prerunner with a V6 manual. I've been doing some research here and I'm I between a couple of options. In the last few days I've gotten a pretty bad vibration from the driveline when on the accelerator. My throw out bearing has been squeaking almost since I got the truck so I thought maybe it had finally went out. I've never experienced this before so I'm not confident in that diagnosis. I've also read about drive shaft weights falling off and the carrier bearing going bad. After putting the rear end on jack stands and running the truck in gear to 2000-2500rpm (my usual operating range) I didn't see any visual movement in the drive shaft. Maybe not having an actual load on the drivetrain hid the problem? Please help
  2. Dec 20, 2016 at 6:47 PM
    GSHEP4
    GSHEP4 Well-Known Member
    Lehighton, PA
    2014 spruce mica sport
    s/c,fluid film, bug shield, window vents, under hood lights, bed lights, tailgate reinforcement, and more.
    Check universal joint?
  3. Dec 20, 2016 at 8:29 PM
    jfoster92
    Justin
    Farmerville, la
    Universal joints are good and after some further investigation and a couple more experienced eyes I'm fairly certain it's the carrier bearing. I'll be checking for lost weights on the driveshaft when I pull it all out in the next day or so
  4. Dec 20, 2016 at 8:31 PM
    MattScatt28
    MattScatt28 2017 Seattle Mariners AL West Champs!
    Snoqualmie
    Man a prerunner Manual 2nd gen sounds rare!
    ChadsPride and jfoster92[OP] like this.
  5. Dec 21, 2016 at 3:43 AM
    jfoster92
    Justin
    Farmerville, la
    I'm not sure of the rarity of it but, I knew as soon as I saw it on the lot and drove it I had to have it. No cruise or power options but it suits me just fine. She's my baby
    ChadsPride likes this.
  6. Dec 21, 2016 at 4:01 AM
    Caltech90
    Caltech90 Well-Known Member
    '19 TRD OR T4R
    jfoster92[QUOTED][OP] likes this.
  7. Dec 21, 2016 at 4:34 AM
    jfoster92
    Justin
    Farmerville, la
    Caltech90 thanks for that. I've definately been needing it. My right foot likes to cruise around 65 but that's not always the speed limit
    Caltech90 likes this.
  8. Dec 21, 2016 at 6:07 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    I would replace ujoints while the shaft is out cheap insurance
  9. Dec 21, 2016 at 12:17 PM
    jfoster92
    Justin
    Farmerville, la
    Hadn't even crossed my mind but I'll definately be picking some up now. Thanks for the tip
  10. Dec 21, 2016 at 10:08 PM
    jfoster92
    Justin
    Farmerville, la
    Well it wasn't the center support bearing so I'll call that preventative maintenance lol. I've got to say I'm stumped now. Could the throwing bearing cause that kind of vibration? I know they're an issue on these trucks. Motor and transmission mounts look good and I didn't notice any missing weight spots on the driveshaft. Any help would be appreciated
  11. Dec 21, 2016 at 11:03 PM
    Sae68
    Sae68 Well-Known Member
    JimS
    Stockton, CA
    05 FJ 4x4 PreRunner
    My drive line vibration was from very worn out center u-joint .
  12. Dec 22, 2016 at 5:50 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I very highly doubt it's the throw out bearing. The throw out bearing is before the transmission so that force would have to make it all the way through the transmission which is damn near impossible. Plus, the transmission is directly coupled to the engine (IE: bolted SOLIDLY to it) so you'd have this type of vibration seemingly coming from the engine too. Your vibrations are behind the transmission for sure.
  13. Dec 22, 2016 at 6:33 AM
    jfoster92
    Justin
    Farmerville, la
    That was my line of thinking. I'm more of a parts changer than a mechanic though. All the u-joints seemed fine when I had them out of the truck last night and that's about as far as my diagnostic skills go. I'm going to take it to a shop and get another opinion before I just throw money at it.
  14. Dec 22, 2016 at 6:55 AM
    sbond007
    sbond007 Well-Known Member
    STEVE!
    PHX, AZ
    '12, OR, DCSB.
    NOS sticker + 100hp
    Please let me know what you find out. Same issues here. All u-joints and carrier bearing replaced, no luck.. Only happens for me between 15-25 mph. Not RPM dependent. Does it in 1st and 2nd, but only notice when I actually "get on it".
  15. Dec 22, 2016 at 6:59 AM
    jfoster92
    Justin
    Farmerville, la
    Will do buddy. Mine is more abound 45-70. I'm gonna take a long shot and take it by the tire shop since I've got a year warranty on anything that happens to them. Not really thinking I slung a weight but it's worth a shot.
  16. Dec 22, 2016 at 8:04 AM
    sbond007
    STEVE!
    PHX, AZ
    '12, OR, DCSB.
    NOS sticker + 100hp
    That does sound like a balance issue. Check for RIM damage on the inside. This can affect the weight. Also, look into Road Forced balance. Not an expert here, far from it. But just throwing out ideas to see what sticks.
  17. Dec 22, 2016 at 9:13 AM
    jfoster92
    Justin
    Farmerville, la
    That is an interesting theory. And an even more interesting read. I'll find out at the tire shop this afternoon.
  18. Dec 22, 2016 at 3:14 PM
    jfoster92
    Justin
    Farmerville, la
    Well fellas after all this time it was an out of balanced wheel. Thanks for all the input
  19. Dec 22, 2016 at 6:09 PM
    Dhannah
    Dhannah 2017 Tacoma OR DCSB
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    I am new to this to and Center U-Joint you mean the carrier bearing? I know its a dumb question.
  20. Dec 22, 2016 at 6:22 PM
    Dhannah
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    How hard was it to replace it? Did you or shop?
