Driveline vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Leog123, Oct 20, 2019.
  1. Oct 20, 2019 at 11:32 AM
    Leog123
    Leog123 [OP] Member
    Leo
    Moreno Valley
    2006 tacoma prerunner 2wd
    Hi ive researched all throughout the forum searching for a solution i have a vibration in my truck between 30-40 mph i have replaced all u-joints and carrier bearing. I also had a small leak a few drops from drveshaft output so i replaced the seal but it is still leaking the driveshaft also has some play from the front where the yoke and trans meet. Please help thanks
  2. Oct 20, 2019 at 11:35 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Lifted? Larger tires and wheels? Only at 30-40mph?
  3. Oct 20, 2019 at 11:46 AM
    Leog123
    Leog123 [OP] Member
    Leo
    Moreno Valley
    I have a 3” leveling kit and tires are 265/70r17 however i do t think this is the cause because i had this vibration before i put the tires and leveling kit in and yes only between 30-40 mph
  4. Oct 20, 2019 at 12:07 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Start with the cheapest and easiest.
    Balance/rotate tires.
    Alignment.
  5. Oct 20, 2019 at 12:17 PM
    Leog123
    Leog123 [OP] Member
    Leo
    Moreno Valley
    I forgot to mention i also did that already sorry the alignment and wheel balance was done after the leveling kit was installed
  6. Oct 20, 2019 at 12:19 PM
    Warhawk
    Warhawk Well-Known Member
    Hot Springs, Arkansas
    2019 TRD OR AC
    Quicksand 2019 TRD Off Road Access Cab
    Crawl under it and see if a balance weight has been knocked off the driveshaft.
  7. Oct 20, 2019 at 12:39 PM
    Leog123
    Leog123 [OP] Member
    Leo
    Moreno Valley
    I just checked and they are all still there the only place i feel play is in the front of the driveshaft where the yoke meets the transmission thats where i also feel the vibration
  8. Oct 21, 2019 at 4:30 PM
    Leog123
    Leog123 [OP] Member
    Leo
    Moreno Valley
    I also noticed it only vibrates when I lightly accelerate up
  9. Nov 15, 2019 at 12:06 PM
    Brenden J
    Brenden J Well-Known Member
    Brenden
    2016 Tacoma TRD sport
    I also have the same issue. But I'm lifted with slightly bigger tires. I had it after I lifted the truck but the vibes went away after I shimmed the carrier bearing. Now it seems to come back in the cold weather (sub 20 degrees) and only when I lightly accelerate.
  10. Nov 15, 2019 at 1:36 PM
    Leog123
    Leog123 [OP] Member
    Leo
    Moreno Valley
    Yeah i saw the carrier bearing spacers might try it i have a 3 inch leveling kit and larger tires. I just changed my transmission mount ill keep you updated if that fixes it
