Driveline Vibrations under 30mph?
Discussion in 'Suspension' started by Colorado_Taco17, Aug 30, 2018.
  1. Aug 30, 2018 at 7:58 PM
    Colorado_Taco17
    Colorado_Taco17 [OP] Well-Known Member
    Jake
    Denver, CO
    2017 Tacoma TRD Off-Road
    CBI bumper/skids, BAMF sliders, Bilstein 5100s & 5160s
    Hi all,
    I am having vibrations between 15-25 mph after installing my lift and was wondering if you guys might be able to help me fix the issue. I just installed bilstein 5100s in the front and dakar leaf packs with extended bilsteins in the rear. I also installed the ECGS bushing and carrier bearing spacer so that should not be the issue.
    I have heard people use shims to help with the pinion angle which I believe is supposed to help with some vibration. Is there anything else I should try in addition to shims? Also what degree would you guys recommend? Thanks in advance.
  2. Aug 30, 2018 at 8:11 PM
    tcjacado
    tcjacado Well-Known Member
    1 degree for every inch of lift is recommended.
  3. Aug 31, 2018 at 8:05 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    Colorado_Taco17[OP] likes this.
  4. Aug 31, 2018 at 10:14 PM
    Colorado_Taco17
    Jake
    Denver, CO
