Driver’s side airbag and horn quit working at the same time
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Phil P, Nov 5, 2019.
  1. Nov 5, 2019 at 1:20 PM
    Phil P
    Phil P [OP] Active Member
    2010 Tacoma 4 door 4X4
    None
    Hi
    We have a 2009 Tacoma 4 door 4X4 with the V6 engine.
    We now have the red airbag display that indicates the driver’s airbag is not functional. At the same time the horn quit working.
    I have checked the fuses and the horn does work when the battery is reconnected and you have to stop it from beeping by using the door unlock button on the key fob.
    Anybody here have any idea what is wrong?
    Thanks in advance
    Phil P
  2. Nov 5, 2019 at 1:21 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Spiral cable inside the steering column (sometimes called the "clock spring"). They are known to go bad.
    ImMrCrash likes this.
  3. Nov 5, 2019 at 2:24 PM
    orezona
    orezona title unspecified
    satan's skillet
    2006 TRD OR DCSB OMGWTFBBQ TL;DR
    WARRANTY VOIDED
    Yeah, there's actually an active recall on it. You should be able to get a dealership to install it for free.
    There are also tutorials about how to do it yourself if you've got the tools and confidence.
    Not a very expensive part.
    Mine was in crappy shape the day I got my truck (3 years ago) because the cruise control never worked. The horn went in and out periodically so I knew it was messed up but didn't really do much.
    Wasn't until I planned a 3,000 mile road trip this last Spring that it dawned on me that having a fully functional airbag was probably a good idea but also needing cruise control for the really long stretches of highway. Took my truck to a local dealership and had it back in less than 2 hours. It's probably a 30 minute or less job but I had too much going on and it was getting too close to the trip and didn't want to mess anything up. Can't beat FREE99!
  4. Dec 1, 2019 at 4:03 AM
    Phil P
    None
    Hi
    With the holidays coming and some breakdowns on some of the larger equipment I haven’t ha time to get back here.
    Thanks for the information and I will have someone check with the dealer about the recall.
    Can anyone give me a part number for this part?
    I will post the results here.
    Phil P
  5. Dec 2, 2019 at 9:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There are two different part numbers one is for a truck with steering wheel controls and the other is for a truck without steering wheel controls.
    Best to go to the dealer parts counter and have them look it up by your VIN Number.
