Driver bedside shortage?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sibg0882, Jul 8, 2024.
  1. Jul 8, 2024 at 5:57 PM
    sibg0882
    sibg0882 [OP] New Member
    Shea
    2020 Toyota Tacoma
    I am getting my truck repaired due to a wreck. One of the parts getting replaced is the driver bedside. The body shop said there is a national shortage on those, is that correct?
  2. Jul 8, 2024 at 6:01 PM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    I don't know but it would not be unusual.
    Someone tried stealing my truck and ripped off the driver's side door handle in the process and getting that part took almost 3 months due to "nation wide back order".
    It eventually made its way to VA from California.
    So it wouldn't be unusual at all
  3. Jul 8, 2024 at 6:14 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I have read this several times, often taking months, upwards of 6 months. If drivable, maybe they can order parts and you keep you truck while you wait, or see if they can find salvage parts.
    It seems silly there’s such a backlog, but times are silly and only seem to worsen. Every day I’m more and more impressed with how bad things have become.
    GL
  4. Jul 8, 2024 at 6:29 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    The dealer should be able to see what’s in the pipeline (if any) and give you a guess. It’s not like it’s an obsolete item.
  5. Jul 8, 2024 at 6:30 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Long bed? Short bed? Step side bed?
  6. Jul 8, 2024 at 6:33 PM
    sibg0882
    Shea
    2020 Toyota Tacoma
    It’s a short bed
  7. Jul 8, 2024 at 6:58 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Sounds like the perfect time to order fiberglass widebody bed sides.... they will probably show up sooner.
    boston23 likes this.
  8. Jul 8, 2024 at 7:00 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Flatty.
  9. Jul 9, 2024 at 5:08 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i'll take some step side bedsides. thanks
    Malvolio and abou824 like this.
  10. Jul 9, 2024 at 5:10 PM
    not a charger
    not a charger Well-Known Member
    NE Ohio
    2023 silver Tacoma SR
    Parts delays have been around forever. This is nothing new. A few times during my career, I was involved in having a part pulled off the line in order to fix a vehicle that needed a part that was on intergalactic backorder. That's a near impossibility today.
  11. Jul 9, 2024 at 5:15 PM
    scocar
    scocar hypotenoper
    I blame it on the cell phone industry. And automatic transmissions.
    bubbaearle, Malvolio, abou824 and 2 others like this.
  12. Jul 9, 2024 at 5:21 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    You can probably find a used 2nd gen bed and make it fit.
    bubbaearle likes this.
  13. Jul 9, 2024 at 7:07 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    I ran into this with a grille replacement on my truck. My body shop uses OEM parts and the grilles come from Toyota with the outer shroud pre-painted body color. I've got a 2016 TRD OR that I added the Pro insert to. My shop was able to get the Pro insert without an issue but was coming up with a backorder reply when they went to find my grille. They originally wanted to do a CAPA part they painted and offered to do a black Toyota part they'd paint. I mentioned that Toyota changed the grille for the different years / trims and gave the shop all the different combos for trim / years in my color. From this my shop was able to find a grill that didn't have a backorder and got it for me.
    It might be worth a deep dive on your part to see if any other alternate part versions exist for your truck, maybe Toyota did something similar. It seems unlikely as the metal was unchanged year to year, but maybe they can find something.
  14. Jul 9, 2024 at 7:09 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    You do know the whole bedside was redesigned, right? Absolutely none of the body lines will line up in the slightest. If they wanted to go used, why wouldn't they go 3G?
    batacoma[QUOTED] and Chew like this.
  15. Jul 9, 2024 at 7:16 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Just get afternarket
  16. Jul 9, 2024 at 7:19 PM
    BOZOJUICE
    BOZOJUICE Well-Known Member
    2016 dclb offroad 4x4 MGMSOLD/2023 ICE CAP PRO
    Maybe try a Good Used, most likely available.
  17. Jul 10, 2024 at 4:27 AM
    batacoma
    batacoma Truck Wars
    I was making a joke. :) I know the body lines wont match up, and for anybody that wants to make a truck right isn't going use the wrong bed.
    I'm just wondering if it would fit with the different body lines. For anybody who has a 3g cab and 2g bed to work with.
  18. Jul 11, 2024 at 4:45 AM
    Fishingeek603
    Fishingeek603 Well-Known Member
    New Hamphire
    2023 TRD Sport, Super White Access Cab 4x4
    Fox 2.0 front with res adjustable rears jba ucas icon rxt leaf pack.
    yup im waiting until october for my passrnger bedside to come in over 400 on backorder for a 6 ft bed
  19. Jul 11, 2024 at 5:13 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Toyota is constantly having national shortages. I had to have the rear bumper and bed on my 2023 aligned and the tabs broke on my step pad when it was removed and it was on back order luckily the dealer found one.
    Good luck!
