Driver door problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Suggs12, Jan 17, 2017.
  1. Jan 17, 2017 at 11:53 AM
    Suggs12
    Suggs12 [OP] Well-Known Member
    Logan
    Johnson City, Tennessee
    2004 PreRunner
    3" Lift kit, Bilstein 5100 front and rear, 2881 EMU coils, 2" Deavers AAL, 18x9 KMC rockstar 1 wheels and 33" Nitto Terra Grapplers, Debadged, Grillcraft insert, clear corner and turn lights, 6k Leds, 30" Led light bar, 4 Pod fog lights.
    This might be an odd topic but I've noticed lately that my driver side door is off and won't close completely. I've checked everything and can't figure out what could be causing it to not shut all the way. It doesn't leak or anything but outside of the truck you can clearly see that it's not shutting all the way. I'm not sure if anyone could help or not but if anybody has had that same problem I'd love to find a fix. Like I said it's not bad but it bugs me to notice it not shut completely. Thanks ahead for any help.
  2. Jan 17, 2017 at 12:10 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    isn't the latch mechanism on the door adjustable? I'll have to check on mine
  3. Jan 17, 2017 at 2:35 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Instead of the latch mechanism, I loosened up the thing the mechanism latches onto that's on the inside of the door jamb where your truck's Vin# is located. It has a star pattern bolt head. You can move it side to side. Sometimes that comes loose or moves and you have to adjust it. Worked for me when my driver's side door wouldn't close all the way.
    DustStorm4x4 and wamego like this.
  4. Jan 17, 2017 at 8:12 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    ^ there ya go :D
  5. Jan 18, 2017 at 5:08 AM
    Suggs12
    Logan
    2004 PreRunner
    I tried this, maybe I didn't get it moved all the way over. I'll try this out again and see if that helps.
  6. Jan 18, 2017 at 10:21 AM
    Zork
    Zork Well-Known Member
    CA / KY
    04 PreRunner V6 D-Cab
    Alpine CDA-9885
    I had this same problem, and adjusting the strike plate fixed it.
    Sicyota04 likes this.
  7. Jan 18, 2017 at 10:53 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Strike plate!!! That's the name of the thing I adjusted.
  8. Jan 18, 2017 at 11:39 AM
    Suggs12
    Logan
    2004 PreRunner
    I'll try this later and see if it helps any. Thanks for the help!
  9. Jan 18, 2017 at 11:04 PM
    SavageTacoma91
    SavageTacoma91 Well-Known Member
    Daniel
    Meadow Vista, CA
    2008 Toyota Tacoma V6 4x4 Access Cab
    Did it work? I have the same issue on my driver door
  10. Jan 19, 2017 at 5:50 AM
    Suggs12
    Logan
    2004 PreRunner
    Last time I tried it didn't but I am going to this evening. I will let you know tomorrow if this worked.
