Driver door will not stay open
Discussion in '1st Gen. Tacomas (1995-2004)' started by mpmoody, Jun 29, 2011.
  1. Jun 29, 2011 at 11:33 PM
    mpmoody
    mpmoody [OP] Active Member
    Goodyear, AZ
    2018 TRD Offroad
    I have a new to me 2004 Tacoma double cab, and the driver's side door refuses to stay open. The other three doors will remain open without any issue, but as soon as you take your hand off of this door it will shut itself.
    I just installed my lift kit from Toytec, so instead of the door shutting on my knees it will shut on my thighs, which doesn't hurt nearly as bad. :p
    Any solutions for this? Perhaps something simple I am overlooking?
  2. Jun 30, 2011 at 1:13 AM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    mine is the same way, I hate it!
  3. Jun 30, 2011 at 1:15 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    same here with my 2000. the passenger door will stay open but the driver door will not. I looked into it theres a black bar by the hinges that keeps it open. maybe replace the parts in it?
  4. Jun 30, 2011 at 4:51 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    That's it. replace it.
  5. Jun 30, 2011 at 7:53 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    i think i have that part laying around..
  6. Jun 30, 2011 at 8:06 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    X2 i did this on my truck when i bought it and it's good as new now. I think it was like 20 or 25 bucks at the dealer but that was a wile ago and i don't really remember what it cost.
  7. Dec 6, 2018 at 11:35 AM
    02MtnTaco
    02MtnTaco New Member
    Crested Butte, CO
    2002 Taco ext cab 3.4L stick
    4” lift, ARB bumper, fog lights
    What is the name of that part?
    Thanks
    Scott
  8. Dec 6, 2018 at 11:52 AM
    kgw
    kgw Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
    60-90 clams these daze...
  9. Dec 6, 2018 at 12:55 PM
    hubcapsc
    hubcapsc Un-Known Stranger
    Upstate South Carolina
    2002 6cyl 4x4 manual
    I've read some threads about this before... mine needs replaced too...
    Isn't a bunch of "taking the door apart" needed?
    -Mike
  10. Dec 6, 2018 at 1:06 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I think it's called a door catch. They're not easy to replace and they are expensive. I am still wondering if there's a ghetto way to fix this.
  11. Dec 6, 2018 at 1:08 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    take your doors off. then you wont have to worry about them staying open.
    ThunderOne[QUOTED] likes this.
  12. Dec 6, 2018 at 1:18 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Mine does it too, always did since new. I happen to like it that way as a lot of times I have my hands full and that door shuts itself:)
    ThunderOne likes this.
  13. Dec 7, 2018 at 5:31 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    02MtnTaco[QUOTED] likes this.
  14. Dec 7, 2018 at 7:16 PM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
  15. Dec 8, 2018 at 7:43 AM
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    Weld a bead on the existing catch and grind down till it holds the door open and still closes?
  16. Dec 8, 2018 at 9:26 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Like plastic weld? Maybe.
  17. Dec 8, 2018 at 10:11 AM
    lukester78
    Luke
    are they plastic? I was assuming they're steel
  18. Dec 8, 2018 at 10:29 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    I think they are plastic OTOH.
    Maybe you could drill a hole in it and put a rivet through it to make a new catch
  19. Dec 8, 2018 at 12:38 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    That piece broke long ago I guess I just got used to it .
    To the point I don`t notice
  20. Dec 9, 2018 at 11:28 AM
    jsabowabo
    jsabowabo Well-Known Member
    Evans, GA
    2004 Xtra Cab 4x4 TRD
    Stock
    Yes on OEM, no on aftermarket. Nobody makes the part. You have to scour junk yards or find a used one on ebay. I'm tempted to buy one for a Camry and see if I can make it work. Toyota rakes you over the coals on these things.
