Driver overhead molle rack for glasses, radio etc. Original design
Discussion in 'Automotive Group Buys' started by Yo_Hec, Dec 6, 2019.
  1. Dec 6, 2019 at 11:14 AM
    Yo_Hec
    Yo_Hec [OP] Well-Known Member
    Hector
    Fort Myers
    17 TRDPRO , 05 Honda Element
    Peddle commander and various molle racks.
    Edit:
    The last three pix show the final product, tou can see the smaller removable molle panel which you can replace and add the command center switchplate. A custom switch plate will be sold separately in the near future per your specs , ill engrave the letters and designs you want. The plate is time consuming to make especially when you are doing different custom ones:
    https://youtu.be/N_xAsW8YQ5w
    I designed this over the weekend and finally had my buddy install this on his 3rd gen being that he has a light color headliner which shows the panel better. Need to do some minor changes and add a TRDpro logo then make one for my truck. This is a permanent install , you need to penetrate the head liner and add nuts to the back. Spacers put the panel 1/2" away from the liner to provide clearance to weave your molle bags. It can hold about 2-3lbs. The liner is plastic so it supports well. Perfect for holding your sunglasses too.
    Im offering it for $95 shipped as a group buy, it comes with all the hardware and spacers. You can place different colored paper behind the letters
    Its a 20 - 30 min install.
    You can easily mount a ram mount ball on it.
  2. Dec 6, 2019 at 11:33 AM
    robblacktpre03
    robblacktpre03 03 Tacoma Restore time
    Rob
    San Francisco, CA
    03 black pre runner
    k&n air filter, throttle body spacer, all pro UCA, 07 gun metal TRD FJ rims, blacked out interior trim
    Would this work on a first gen
    erice and BeLance89 like this.
  3. Dec 6, 2019 at 11:42 AM
    Yo_Hec
    Hector
    Fort Myers
    Dont know just made this.
  4. Dec 6, 2019 at 12:11 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Oh that’s cool. For the non sunroof people.
    Yo_Hec[OP] likes this.
  5. Dec 6, 2019 at 1:36 PM
    Astra
    Astra Well-Known Member
    Aaron
    St. Louis
    2007 Tacoma AC TRD Off-Road - Speedway Blue
    Interested if it will work with 2nd gen .
  6. Dec 6, 2019 at 1:41 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Looks like something @boogie3478 would be interest in. I would be interested if it would fit 2nd gen.
    Yo_Hec[OP] and boogie3478 like this.
  7. Dec 6, 2019 at 1:44 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    It does look pretty sweet!
  8. Dec 6, 2019 at 1:47 PM
    Yo_Hec
    Hector
    Fort Myers
    Working on second gen this week
    nudavinci64, MasonSTL and Astra like this.
  9. Dec 6, 2019 at 1:55 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Think it could hold a CB?
  10. Dec 6, 2019 at 2:09 PM
    MasonSTL
    MasonSTL Well-Known Member
    Green Bay, WI
    06 TRDOR AC MT
    Subd
  11. Dec 6, 2019 at 2:12 PM
    Barrette86
    Barrette86 Well-Known Member
    Edward
    Maine
    2015 Tacoma
    None so far
    In for 2nd gen
  12. Dec 6, 2019 at 4:27 PM
    calebc
    calebc Well-Known Member
    Is this a coated aluminum/steel panel or is it a plastic?
  13. Dec 7, 2019 at 12:22 PM
    Yo_Hec
    Hector
    Fort Myers
    I can do all 3 materials however ABS is best for this spot due to the creature.
  14. Dec 7, 2019 at 12:24 PM
    Yo_Hec
    Hector
    Fort Myers
    Changed it up some
    Travace, KanakaRebel, Toynado and 2 others like this.
  15. Dec 7, 2019 at 6:23 PM
    Sn4rlax
    Sn4rlax Well-Known Member
    2016 Red Taco 4x4 V6
    Does this require you to pull the headliner down to do? Or can you actually reach the bolts and such without pulling the headliner down?
  16. Dec 7, 2019 at 6:30 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    im not pooping on the dudes product because it looks like it’s designed for lightweight items but there’s no way I’d mount a CB to this thing without having some sort of reinforcement on the back of the headliner. I know the FJ guys used to epoxy blocks of wood to the roof and mount a CB thru headliner to that. But mounting to straight headliner? No way. It’s also a terrible spot for a CB. You’d have to crane your neck to see the display and in a wreck it’s asking for a boo boo.
  17. Dec 8, 2019 at 8:58 AM
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    Is the group buy on? I'm interested.
  18. Dec 8, 2019 at 9:01 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Agree with this. Headliner is just fancy cardboard, and it’s super expensive. Overload it with weight and it’s going to fail.
  19. Dec 8, 2019 at 3:40 PM
    Yo_Hec
    Hector
    Fort Myers
    No, you feed your hand through the map and dome light
    Toynado likes this.
  20. Dec 8, 2019 at 3:44 PM
    Yo_Hec
    Hector
    Fort Myers
    It can easily hold a hand held radio etc. I wouldnt mount a cobra ltd on it though.
    This headliner is actually pretty strong becaise its layered foam and plastic. Holds its.shape well. If you want.to hold something heavier you can use magnets and a threaded rod but thays not what im shooting for.
    You can also mount different switches on the front too.
