Driver Rear Door Locks Not Working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tmuhler, Jan 4, 2019.
  1. Jan 4, 2019 at 3:19 PM
    tmuhler
    tmuhler [OP] Member
    Travis
    2008 TRD Sport
    My driver rear door locks are not working with the electric door locks. I have done some research, but I was not able to find a door lock actuator for the driver rear door. I’m not sure if there is one. Has anyone else had this problem, and do you know how to fix it?
  2. Jan 4, 2019 at 6:29 PM
    JFick
    JFick Sawzall Enthusiast
    Los Angeles
    ‘19 TRDOR 6MT, ‘11 BMW M3 DCT
    Softopper 255/85r16 Yokohama MTs Camburg UCAs King extended travel coilovers King extended travel rear shocks Firestone airbags OME medium duty leafs
    I was actually going to take my driver front door apart this weekend to fix it. I had been having intermittent issues with it for a year or so and for the past 6 months or so it has been manual-only. Check out this thread:
    https://www.tacomaworld.com/threads/bad-door-lock-actuators.198658/
    To save yourself some scrolling, for all things actuator go here:
    https://www.rav4world.com/forums/96...r-fix-your-door-locks-free.html#/topics/82750
    If you don’t want to spend $200+ on a new actuator that will probably go bad eventually anyway, then rebuild it! Hope this helps.
  3. Jan 5, 2019 at 11:00 AM
    JFick
    Los Angeles
    I actually did it today, took me a good two hours - reassembly was quite difficult without removing the door handle. It was easier than I expected to clean the brushes on the locking motor.
    tmuhler[OP] likes this.
  4. Jan 7, 2019 at 7:59 AM
    tmuhler
    tmuhler [OP] Member
    Travis
    2008 TRD Sport
    I found this video, which seems like an easy enough repair. I found the motor for $11. I plan to do try this repair this weekend.
    https://youtu.be/FZCeeUWMTcY
    I will report back if it is successful or not.
  5. Jan 7, 2019 at 8:02 AM
    JFick
    Los Angeles
    Honestly once you get inside the actuator it’s an extra 10 minutes to pull apart the DC motor and clean the little brushes with a q-tip! Worked really well, and it was free!
  6. Jan 9, 2019 at 9:38 AM
    tmuhler
    tmuhler [OP] Member
    Travis
    2008 TRD Sport
    I completed the repair, and the lock works fine. I ordered these motors:
    Surplus Deal USA 4 Pack - 20mm D Flat Shaft Central Door Lock Actuator Motor FC-280PC-22125, Long D Spindle, Power Locking Repair Engine https://www.amazon.com/dp/B01LXS38R9/ref=cm_sw_r_cp_api_i_8cJnCbMV47AM3
    I ran into one snag, and that was reassembly of the locking mechanism. I will say to be very careful when taking the actuator apart so the internal components don’t come loose.
    I will say that I was happy to save $350 and not buy a new actuator.
    Crom and JFick like this.
  7. Jan 9, 2019 at 9:49 AM
    JFick
    Los Angeles
    Yeah I ran into a similar issue, the lock switch and door latch overlapped their travel and it was jammed so I had to take it apart again and move their components away from each other, but other than that I just released the plastic case slowly so I could tell which way it was all oriented. Yeah I’m definitely glad to have saved that money too!
    tmuhler[QUOTED][OP] likes this.
  8. Jan 9, 2019 at 1:08 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yup if you dig that far into the actuator motor.... may as well just replace the motor itself... they are stupid cheap.
    Replaced my passenger rear door awhile back... my driver rear is starting to be intermittent in its ability to fully unlock here n there in the cold.... so it will get replaced as soon as it goes full tits up.
  9. Jan 9, 2019 at 1:45 PM
    JFick
    Los Angeles
    Legitimately it only took me an extra 5 minutes to disassemble the motor, clean off the brushes and reinstall, but idk if the factory ones are worse than the replacement ones or what. Seeing as the OEM one in my driver door only lasted 3 years until kicking the bucket I would definitely try the replacement motors if I had them on-hand lol.
    nd4spdbh[QUOTED] and tmuhler[OP] like this.
  10. Jan 9, 2019 at 3:24 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    2010 here and same problem
  11. Jan 9, 2019 at 3:44 PM
    HapaMatt
    HapaMatt Well-Known Member
    Make sure that the door lock actuator works as intended BEFORE shutting the door. I recently replaced all four motors, forgot to double check before closing one of the doors, and ended up with a three door taco. Thankfully, I didn't put the interior panel back on before closing the door, making it fairly easy to open from the inside. Phew.
    In case anyone needs it - actuator units for a 2011 tacoma w/ keyless entry:
    69030-AC080 pass front, 69040-04030 driver front, 69050-04020 pass rear, 69060-04020 driver rear
    dolbytone likes this.
  12. Jun 15, 2019 at 12:25 PM
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    I just pulled mine apart. I was extremely careful but when I went to test the latch nothing happened.
    These are the parts in question. I really don’t have confidence in taking another one apart at this time for obvious reasons. I also leave for Alaska Monday night and I can’t even get a new part.
    Any help would be great
  13. Jun 27, 2019 at 11:46 AM
    tmuhler
    tmuhler [OP] Member
    Travis
    2008 TRD Sport
    I am not sure, mine came apart and went back together flawlessly. I have to do both passenger side doors soon. Sorry I couldn’t help, perhaps a parts diagram?
