Driver Seat Side Squib Replacment/Troubleshooting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by moweryaviation, Dec 23, 2018.
  1. Dec 23, 2018 at 8:27 AM
    moweryaviation
    moweryaviation [OP] Life begins, where the pavement ends!
    Dixon, California
    2011 Tacoma, 4x4, manual, access cab
    3" (or so) lift, Dakar leafs & 886 up front.OME Sport shocks, Pro-Crap struts up front, SPC UCA's, Brute Force Fab front and rear, super winch 9500, KM2 255/85, Holly Brakes, SS Brake lines, DOT 4 Fluid, Custom bed system, independent bed LEDs, black head lights, Mag Grey grill, DIY 50$ roof tie down system, On Board Air, DIY spare tire swing arm, DIY painted rims, Energy bushings, camp lights, independant power system, BAMF Bolt on Sliders, DIY IFS Skid, DIY Roof Rack, Bad ass additude, one old smart dog, one young dumb dog, and one hot Burnett!
    I have a 2011 Tacoma AC 4x4. I removed the seats and washed them (soap, water, shop vac) reinstalled seats and now I have a B1820 code. "Short in Side Squib RH" Not sure how to troubleshoot, besides visual for corrosion. Any help on troubleshooting or squib replacment would be great.
  2. Dec 23, 2018 at 8:33 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The squib is the (weird name for the) igniter inside the airbag unit. Other than checking the electrical connector there's not much you can do. That airbag unit is pretty sealed up and you cant really repair them
  3. Dec 23, 2018 at 8:39 AM
    moweryaviation
    Dixon, California
    What about a continuity check? I have worked wiht squibs on fire suppression systems on aircraft in the past, but those were a little different. Explosive just the same.
  4. Dec 23, 2018 at 8:43 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    By all means check continuity.. but I dont know what a correct reading should be. If the code says something is shorted in the circuit, picture a "hot" wire rubbing against something it shouldn't be touching.
    Are you sure you didn't snag some wiring under the seat with the vacuum?
  5. Dec 23, 2018 at 11:22 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    STOP: You never want to check the continuity of a squib device. A squib contains explosives and the electrical current from a DMM can set it off.
    https://en.wikipedia.org/wiki/Squib_(explosive)
    I'm pretty sure he meant to check the continuity of the circuit disconnected from the squib.
    b_r_o likes this.
  6. Dec 23, 2018 at 11:30 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Oh boy, wouldn't that suck...
  7. Dec 23, 2018 at 11:35 AM
    moweryaviation
    Dixon, California
    I really dont want to check continunity through the squib due to the meeter sending voltage through, and seeing what comes back. Squibs on aircraft can pop with static electricity.
  8. Dec 23, 2018 at 11:37 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Thank you. I'd be willing to bet the current from a DMM will detonate a squib.
  9. Dec 23, 2018 at 11:54 AM
    moweryaviation
    Dixon, California
    LOL, If I cleaned my truck than Yes, that would be a possibility!!!
    b_r_o[QUOTED] likes this.
  10. Dec 23, 2018 at 11:59 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Jimmy 's right, the dmm could set off the igniter. Just check continuity through the harness to the last connector before the unit. If the continuity checks out then the unit is bad
  11. Dec 23, 2018 at 12:06 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    #1 Was the key on while the seats were out of the truck? Clear the code and see if it returns.
    #2 To check for an open or short in an airbag circuit, disconnect the airbag computer (called the center airbag sensor), disconnect whatever airbag there is a problem with (L/H seat), using a small wire jump the two wires at the airbag connector that you just disconnected. THE ONE LEADING BACK TO THE COMPUTER, NOT THE AIRBAG ITSELF. Then, with a multi-meter check for a open circuit, there will be a short because of the jumper you placed in the connector. Remove the jumper and check for an open/short again. Also check both wires for a short to ground. You can disconnect the battery but I never did.
    Picture below is an example and not to be used for your truck. You will need a wiring diagram for your vehicle.
    I've only seen airbag computers go bad because of an accident or they got wet.
    Jimmyh likes this.
  12. Dec 23, 2018 at 12:26 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
  13. Dec 23, 2018 at 12:41 PM
    moweryaviation
    Dixon, California
    I troubleshot it down to the squib its self in the seat. Does anyone know how to remove the factory seat cover to expose the squib? After that I will be looking for a P/N to order it, if I can even get it that is.
  14. Dec 23, 2018 at 12:46 PM
    moweryaviation
    Dixon, California
    Dude! thanks for the info!
    #1 No, the seat was removed and installed wiht no power on the truck.
    #2 The scaner told me it was a short, where I did not know until I unhooked the squib under the seat, cleared histoy codes, and did another scan. The "Short " code went away, and a diffrent code came up as an open, which is what I expected. To me that points the finger at the squib that I disconnected, now how to get that bastard out of the seat......
  15. Dec 23, 2018 at 12:53 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    That's the easy part. Remove the seat, remove the upholstery for the seat back and remove the squib (airbag). You don't need to remove the entire seatback material, just enough to get to the bolts. Should be two 8mm or 10mm bolts.
  16. Dec 23, 2018 at 12:55 PM
    moweryaviation
    Dixon, California
    Cool, I was just wrestling wiht it and found a long black plastic clip, for the cover that was not wanting to come off. thanks for the info.
