Driver Seat Squeak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jayandersen5, Apr 22, 2019.
  1. Apr 22, 2019 at 8:34 AM
    jayandersen5
    jayandersen5 [OP] Well-Known Member
    Jay
    South Carolina
    2017 TRD Pro
    OTT Tuned Yukon 5.29s 35x12.50r17 Yokohama MTs RRW RR7-H Wheels Dobinsons MRRs RRW hybrid front bumper ATH rear swing out high clearance bumper Alucab Explorer Canopy iKamper skycamp 2.0 Diode Dynamics SS3 (x4) and SSC2 SOS Sliders RCI trans and t-case skids Smittybilt X20 Gen3 10k winch Prinsu Cabrack Expedition Essentials 3TPAM Caliraised 40" light bar Total Chaos spindle/cam tab gussets and bed stiffeners Switch Pro SP9100 Power Tray
    I've only got 30k miles on my 2017 taco and the driver seat is already squeaking like crazy (right side of drive seat closest to center console). I have the cloth interior so it's not the leather rubbing up against the center console - definitely sounds like the inner hardware of the seat... Has anyone else experienced this? Is this normal for a taco with just 30k miles?
  2. Apr 22, 2019 at 8:38 AM
    Madtown
    Madtown Well-Known Member
    Eric
    Madison,WI
    Former 3G Tacoma owner
    Mine does it as well. Only does it when I move in it. Mostly the back rest were the lumbar support is & the bolster on the right side seat bottom cushion. Cheaply made seats. Might pull it apart & apply felt tape to the affected area's. BTW I also have cloth seats.
  3. Apr 22, 2019 at 8:58 AM
    jayandersen5
    Jay
    South Carolina
    2017 TRD Pro
    Mine is on the bolster on the right side bottom cushion as well. It started a few months ago but wasn't bad, now it basically overpowers the radio.
  4. Apr 23, 2019 at 10:19 AM
    Rocinante75
    Rocinante75 Well-Known Member
    2018 TRD Pro Cavalry Blue
    RokBlokz Mud Flaps, TufSkinz tailgate lettering, OV Tuned (1.05!!!)
    My '18 Pro (leather) squeaks, and it's definitely internal. Mostly when getting initially sitting on it. I'm going to mention it to the dealer on my next visit.
  5. Jan 18, 2021 at 9:36 AM
    liquidskin
    liquidskin Well-Known Member
    2020 SR5 4X4 DCSB
    2020 started squeaking on tight right turns. Can’t replicate unless I’m in the seat and turning. Anyone come across this?
  6. Jan 18, 2021 at 11:32 AM
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    Interesting..if just one or two has this problem...might seem unusual..
    When the problem happens often or more common...this can be serious..
    Design flaws..or ?
    Hope solutions will be found!
    In the old days ..if it squeaks add oil...
    Many years ago a guy use to spray diesel oil under his whole undercarriage..(shoreline salt water. Fishing) not sure if it helps?
    Aloha
  7. Apr 14, 2021 at 3:06 AM
    shadowler
    shadowler Active Member
    Sherm
    NorCal
    2020 CEMENT TRDOR DCLB
    My 2020 with leather definitely has this... I am just tolerating it by turning up the volume.
  8. Apr 14, 2021 at 3:55 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    No squeaks here. I do leak methane once in a while. The seat seems to handle.:fingerscrossed:
    Hayballer, Mastiffsrule and Mark77 like this.
  9. Apr 14, 2021 at 7:48 AM
    Furball
    Furball Well-Known Member
    Minnesota
    2017 TRD Off Road
    2017 here. My driver seat has squeaked and popped in the lower back area when turning and going over bumps since the day i picked it up. I just deal with it
  10. Nov 8, 2021 at 10:31 AM
    TVphotog97
    TVphotog97 Well-Known Member
    Codie
    Upstate South Carolina
    2019 White Tacoma SR5
    My driver seat has recently started doing this more and more. Pretty much anytime I get in and out, or even move the slightest while driving. 2019 with 40K on it
  11. Nov 10, 2021 at 10:14 AM
    cajl1993
    cajl1993 Well-Known Member
    Christian
    2019 tacoma 4x4 trd sport
    My driver seat doesn't squeak but my passenger seat rattled at high speed
  12. Nov 10, 2021 at 10:20 AM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    make sure the bolts that hold the seat down are tight. mine made all sorts of noise after i installed my seat jackers from the nuts backing off. didn't use loctite...
  13. Mar 8, 2022 at 5:37 PM
    Old&fat
    Old&fat Well-Known Member
    21 TRD offroad
    So my driver's seat is squeeking like crazy now. I can just push down on the seat with my hand and it does it, feel like I'm driving a hoopty on the bumpy new orleans streets. Anyone had success fixing this... or getting the dealer to fix/replace? I've had the truck for 8 months and it's got 20k miles.
  14. Mar 8, 2022 at 5:40 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Don’t want to be that guy, but maybe driver weight disclosure may help identify a possible contributor? And don’t worry, if this is the case my ‘21 will be squeaking soon.
    Montana_Actual likes this.
  15. Mar 8, 2022 at 5:57 PM
    Old&fat
    21 TRD offroad
    Haha, if I couldn't easily make it squeek with just my hand and no one sitting in it I'd agree. I'm #240, maybe you need to be under 200 to drive a tacoma nowadays.
    Ryan188 and Mastiffsrule[QUOTED] like this.
  16. Mar 8, 2022 at 5:58 PM
    Mastiffsrule
    Scott
    I better trade in then. :thumbsup:
  17. Mar 8, 2022 at 6:00 PM
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    Mine did it, I lowered the seat a half inch (power seat) and it stopped
  18. Mar 8, 2022 at 6:09 PM
    Old&fat
    21 TRD offroad
    Yes, if I raise my seat all the way up it's much better, but then the rear view mirror is directly in my face and I can't see the passenger side of the hood without looking under the mirror. All the way down is most comfy for me, but also most squeeky.
  19. Mar 8, 2022 at 6:11 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    There is a nylon bushing where back bolts to base of seat. That bushing wears and cracks.
    Hooper89 likes this.
  20. Jul 23, 2022 at 3:46 PM
    baraban
    baraban Active Member
    Ig
    2019 TRD OffRoad
    Do you have a picture?
