Driver side 1" lower then passenger side
Discussion in 'Suspension' started by JeenyusSB, Apr 2, 2011.
  1. Apr 2, 2011 at 12:12 PM
    JeenyusSB
    JeenyusSB [OP] Well-Known Member
    I recently installed 5100's. While I was installing them I kind of noticed how the one side was lower withthe stock shocks. Now I clearly see almost a full inch difference in height. I have the shocks set at 2.5".
    Im thinking it has some thing to do with the whole suspension and not the new Bilstiens. If any one knows what i should be looking at to find what could be causing this it would be appreciated. I will post pics if it could be helpful. Also my driver side wheel is cambered a lot more then the passenger side. The ride is fine. I was possibly thinking a 1/4" spacer would solve this but i heard you should not use spacers with the billys.
  2. Apr 2, 2011 at 4:56 PM
    JeenyusSB
    Anybody? Can I use a 1/4" spacer with the 5100s?
  3. Apr 2, 2011 at 4:57 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    very common. it's called taco lean. It's due to your constant weight on the driver side, battery, gas tank, etc
    a lot of people run an additional spacer or crank their adjustables up a notch on the driver side,
  4. Apr 2, 2011 at 4:57 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Yes you can run the 1/4 spacer.
  5. Apr 2, 2011 at 4:59 PM
    tiresmokintacoma
    tiresmokintacoma Bean&Cheese Taco
    VIC
    Texas
    1794 4WD FUNDRA/05TACO DCOR/97 LX450/91 4R 4WD
    Stock ASF
    i have a 1/4 spacer on my 5100s. but both sides
  6. Apr 2, 2011 at 5:08 PM
    larry2375
    larry2375 Well-Known Member
    honolulu
    2010 mgm prerunner sport
    upper mx grillcraft, flowmaster super 44,bilstein 5100 @ 2.5,toytec 1/4" spacer driver side,nitto terra grappler 285/70/17,17x9 xd addicts, undercover tonneau cover, wet okoles, weathertech mats, toyota door sill protector, toyota bed mat, 30% tint, black toyota oem tube steps, 14" shorty antenna, trd skid plate, most important, viper 5902 with remote start and two dual shock sensors
    mine is set at 2.5" and 1/4" spacer on driver side. before installing the spacer, driver side was about 1/2"-3/4" lower. now it's about even.
  7. Apr 2, 2011 at 5:16 PM
    JeenyusSB
    Ok, thanks a lot guys. I just wanted to make sure it wasn't a bigger problem. Looks like ill be getting the spacer.
  8. Apr 2, 2011 at 9:25 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    yep its normal, hope the spacer works out well for ya :)
