Driver side body lean
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bumrush, Feb 11, 2016.
  1. Feb 12, 2016 at 2:36 PM
    2016spicytaco
    2016spicytaco Spicy Kitty
    Al
    Denver, Colorado
    Turd Gen for Life
    like others stated taco lean ...did you check tire pressure may be you have a slow leak?
  2. Feb 12, 2016 at 2:47 PM
    bzzr2
    bzzr2 Well-Known Member
    damn toyota. just another carry over from the original 2nd gen to this 2.5 gen like the driveline vibes that the discount engineers haven't resolved.. it's not just after installing aftermarket suspension that this happens, this happens with stock shit too. mine did it, then it became more noticeable when i went full OME suspension, even with the trim packer in the coil over on the driver side. anyway to the OP, good luck with toyota, likely the final answer will be 'it is a characteristic of the vehicle' reply common to all of their short comings.. if everybody here convinces you to order some new aftermarket leaf springs, probably OME, when ordering insist without compromise that you get one '+' and one '-' spring, '+' on the driver side and '-' on the passenger side during install. the + - is tolerance and variation in ride height the springs will give, they should all be sold this way imo.
    my 2014 F150 4x4 with a 2.5 inch lift loaded up seemed to have consistent lean also on the gas tank side. and my 2015 jk has passenger side lean also, which is again the gas tank side.
    because_wumbo-truck likes this.
  3. Feb 12, 2016 at 4:36 PM
    Bumrush
    Bumrush [OP] Well-Known Member
    Brian
    Middle TN
    16 TRD OR SB quicksand
    I only had 5100 to level the front. When I took it in to dealer there was a bone stock truck there with the same issue. I have factory springs.
  4. Feb 12, 2016 at 4:53 PM
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    This is not the usual Taco lean. That only happens with aftermarket springs, this is something else folks...
    I have factory springs with 5100s up front and it sits perfectly level. With the amount of lean in your picture it leads me to believe your 5100s are at different settings. Before going to the dealership, make sure the setting are equally the same on both sides and the spring is seated correctly up top.
  5. Feb 12, 2016 at 4:57 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  6. Feb 12, 2016 at 5:02 PM
    Dean724
    Upland, CA
    This is not normal and nor did he say the lean was present prior to the shocks being put on. If Taco lean was that prevalent on 2016 stock trucks don't you think there would've been a a ton of posts about it by now. Someone screwed up the installation on his 5100s.
  7. Feb 12, 2016 at 5:07 PM
    T4RFTMFW
    Second gens had the same issues.
    But I'll sit and watch and wait for Toyota.
  8. Feb 12, 2016 at 5:07 PM
    Bumrush
    Brian
    Middle TN
    The lean measures exactly the same on the right side front and rear. And like I stated prior a brand new bone stock truck had the same lean measurements as mine. Therefore I'm confident that the 5100 are at the right setting.
  9. Feb 12, 2016 at 5:49 PM
    Dean724
    Upland, CA
    Did you have the lean before installing the 5100s? Did you drive your truck off the lot with this lean when it was brand new?
    It's very difficult for us to help diagnose your issue when we only have snippets of information to go on.
    Was the lean there prior to install. Did you have the dealer install your 5100s or did you? What setting are they at? What was the measurement prior to install? If the stock truck has the exact measurements as you with your 5100s then that tells me you have 5100s that weren't installed correctly, but you're confident they are at the right setting? How are you confident when a stock truck has the same exact setting as you!?
  10. Feb 12, 2016 at 5:57 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    yep, that lean has been around for 10 years now. perfectly normal lol
  11. Feb 12, 2016 at 6:04 PM
    Dean724
    Upland, CA
    You do realize the stock coils on the 2016 are different to make up for the lean? I thought the lean on 2nd gens was only present with aftermarket coils. Can someone confirm this or were all 2nd gen owners driving off the lot with a gangsta lean in stock form?
  12. Feb 12, 2016 at 6:12 PM
    Bumrush
    Brian
    Middle TN
    The lean was present before the 5100. And if a stock truck has the same lean then why would one assume the 5100 are not set correctly? That would tell me that the problem was from the factory. A brand new stock truck has the same lean.
  13. Feb 12, 2016 at 6:14 PM
    theredofshaw
    mine looked normal off the lot. however, after a couple years it settled ever so slightly. the tsb for the leaf pack a few years ago kinda fixed it (not so noticeable anymore).
  14. Feb 12, 2016 at 6:15 PM
    Dean724
    Upland, CA
    I'm over it. Good luck with your truck.
  15. Feb 12, 2016 at 6:19 PM
    #35
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Looks like it's quite a bit more than half an inch to me. Also the truck is brand new. Truck leans usually don't take effect right away
  16. Feb 12, 2016 at 6:26 PM
    #36
    trd518
    trd518 Well-Known Member
    2016 DCSB
    My 2001 had a lean but not even half that bad. I would take it and have it looked at. That's a brand new one.
  17. Feb 12, 2016 at 6:32 PM
    #37
    T4RFTMFW
    Okay.
    OP said half to 3/4 inch difference so I assume at some point it's been measured and not just looked at on a screen and issues an armchair measurement.
    1/2-3/4" lean is practically a feature. This includes stock suspensions. It's more obvious with aftermarket, but it exists on new trucks exactly how OP describes. Which is why he saw the same lean on a brand new truck at the dealer.
  18. Feb 12, 2016 at 6:36 PM
    #38
    because_wumbo-truck
    Jon
    Houston, Texas
    Damn, if that's the case new Toyotas suck more than previously thought. First gens take like a decade to develop a lean haha
    Pportera likes this.
  19. Feb 12, 2016 at 6:40 PM
    #39
    Dean724
    Upland, CA
    If only our turd gens came with a kickstand, life would be complete. :D
    Pportera and T4RFTMFW like this.
  20. Feb 12, 2016 at 7:39 PM
    #40
    WIDGIN9
    WIDGIN9 Well-Known Member
    Earth, I think.
    2016 MGM 4x4 Limited, 2001 Black 4x4 SR5 Doublecab
    NRA Life Member Sticker, Body Armor 4x4 Step Rail, Leer Trilogy Bed Cover
    Stop letting your FAT girlfriend drive your Taco and the problem will disappear.
    Dean724 likes this.
