driver side brake fluid leak at wheel
Discussion in 'Technical Chat' started by myrddin33, Mar 13, 2012.
  1. Mar 13, 2012 at 9:42 AM
    myrddin33
    myrddin33 [OP] Member
    Hello!
    I hate that my first post is a help request, but here goes.
    I have a 2009 Tacoma. I changed out the brake pads on my front breaks over the weekend. The passenger side went just fine but I've now got a brake fluid leak on the driver side.
    The actual brake pad change went fine but when I was cleaning up I found a small rubber washer on the ground that I hadn't noticed while changing either side. I found it on the driver side so it's pretty clear that's what's causing the leak but I'm not sure exactly where it goes. I've been searching the internet for a diagram but haven't found anything yet. I don't want to take the wheel off until I know exactly where the rubber washer goes.
    Can anyone point me in the right direction?
    TIA!
  2. Mar 13, 2012 at 9:46 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  3. Mar 13, 2012 at 9:48 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Did it look like one of these?
  4. Mar 13, 2012 at 9:49 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
  5. Mar 13, 2012 at 9:58 AM
    myrddin33
    @98tacoma27
    Thank you! that's exactly what I was looking for. The washers in the second row is what it looks like. From the diagram it looks like a piston seal but I'm not sure that's right.
    I did split the caliper apart while changing the pads.
    Thanks!!
  6. Mar 13, 2012 at 10:00 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Next time, there is no need to split the caliper unless you are actually changing those seals. It prevents moments like this. :p Plus you won't have to bleed them.
  7. Mar 13, 2012 at 10:03 AM
    myrddin33
    I know it's not the recommended way of doing things but it seemed simpler at the time :)
    I'm still not 100% about where the washer goes but at least I've got something to reference now.
    Thanks
  8. Mar 13, 2012 at 10:04 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You'll see where it goes when you split the caliper again. It will be plain as day.
  9. Mar 13, 2012 at 10:39 AM
    myrddin33
    Thanks for your help!
  10. Mar 14, 2012 at 9:27 AM
    myrddin33
    You were right, the second I pulled the caliper apart I saw where it was supposed to go.
    Thanks again!
  11. Mar 11, 2013 at 8:41 AM
    phatso
    phatso Well-Known Member
    Eastern Washington
    2017 Cement Pro
    Similar problem here...my brother was working on my truck...accidently split the caliper...quickly tightened it and eventually bled the brakes...a couple of weeks later I realized the problem and found a rubber o-ring that fit real tight and so far no leak
    Toyota parts department said it looks like an o-ring on their computer but wasn't sure and the only way to purchase it is as part of a $40 repair kit...Oreilly's sells a similar repair kit for $7...I'm just wondering if the o-ring I bought is similar to the stock part
    My question: Was the original part a copper washer or a rubber o-ring?
  12. Mar 11, 2013 at 8:43 AM
    FoundOffRoadDead
    FoundOffRoadDead whiptastic handling
    Shamus
    Walnut
    Ford
    Copper. all of them are.
    Ford gmc almost all truck's are copper.
    Hope that help's you.
    There's 2 of them. btw (they also might still be on there just look for uneven surface.
  13. Mar 11, 2013 at 9:13 AM
    phatso
    Eastern Washington
    2017 Cement Pro
    Thanks, we took it apart and didn't find anything...I guess I'll buy the repair kit
  14. Mar 11, 2013 at 10:12 AM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    Alright yeah sorry can't pin point it. Good luck.
  15. Mar 12, 2013 at 12:41 PM
    speedjunkie13
    speedjunkie13 Well-Known Member
    a work in progress
    sorry, but this is not accurate for the tacoma. I just rebuilt my calipers using that kit a week ago. it is a square cut "o-ring" that goes between the 2 halves, and there is only 1 per caliper. You could probably get away with just using a normal o-ring of the proper diameter though.
    OP, next time just take the pins out and slide the pads out the top.
  16. Mar 12, 2013 at 2:55 PM
    phatso
    Eastern Washington
    2017 Cement Pro
    Thank you for your post. We found a normal o-ring that fits snug tight and I'm on day 3 with no leak. I'll keep an eye on it though and I'll probably buy the $7 repair kit from O'Reilly's and throw it in the glove box just in case. Thanks again.
