Driver side brake light doesn't work
Discussion in 'Lighting' started by GA_TACO4x4, Dec 18, 2011.
  1. Dec 18, 2011 at 1:30 PM
    GA_TACO4x4
    GA_TACO4x4 [OP] Well-Known Member
    here 'n there
    07 DCSB 4x4
    marathon superhide max-4 seat covers, weathertechs, maglite mod, 20% tint, 2" leveling kit, leaf spring tsb.
    bulb looks fine. cant find any blown fuses. and the bulb works when the running/headlights are on. just doesnt light up when u apply brakes. any suggestions?
  2. Dec 18, 2011 at 1:53 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    replace the bulb
  3. Dec 18, 2011 at 1:57 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Or swap it out with the one on the other side. Just for testing purposes.
    No sense in going crazy troubleshooting just yet.
    Beyond that, get a meter or test light and check for power.
  4. Dec 18, 2011 at 2:57 PM
    GA_TACO4x4
    here 'n there
    07 DCSB 4x4
    Bulb doesn't look blown none of the fitament (?) was broken but I did swap in a new one and it works fine. Guess I was just over complicating the situation :rolleyes:
  5. Dec 18, 2011 at 2:59 PM
    2000GTacoma
    Snow Hill NC
    no big deal thats tw for ya
  6. Mar 12, 2012 at 9:50 AM
    kharv3st
    kharv3st Member
    I'm having the same issue, did a new bulb resolve?
    A little google research suggests that the bulbs may have two filiments, and only the one is burnt out - explaining why the tail light still lights up but doesn't get brighter.
  7. Mar 12, 2012 at 4:09 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    :cheers:
  8. Mar 12, 2012 at 4:50 PM
    GA_TACO4x4
    here 'n there
    07 DCSB 4x4
    yep new bulb fixed it. no problems since
  9. Apr 11, 2012 at 12:09 PM
    kharv3st
    kharv3st Member
    Sure enough, new bulb fixed it here as well
  10. Apr 11, 2012 at 12:15 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    this is happening on my car, guess i need a new bulb! tw for the win again:)
