Driver side CCFL halo out
Discussion in 'Technical Chat' started by tacomonazul, Jul 10, 2013.
  1. Jul 10, 2013 at 8:22 PM
    tacomonazul
    tacomonazul [OP] Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    I noticed that one of the two halos on the driver side headlight is out, I disassembled it and checked all the wires and connectors, everything looked right. What could it be? Can it be changed? Here are some pictures:
    R
    L
  2. Jul 10, 2013 at 9:37 PM
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    They are not mean't to last, I have heard of several sets going out, If you really wanna check what it is, open them up and check the wiring inside but those headlights are not high quality lights.
  3. Jul 10, 2013 at 10:53 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    I have with them 1 year and 8 months now, you recommend to open the headlights and check the inside?
  4. Jul 10, 2013 at 10:56 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    ^^^this
    From what I've seen those halos and projectors aren't good...but just to double check take the light apart and check to see if power is running to it
  5. Jul 10, 2013 at 11:07 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    What activates them? If they're tied to your DRL, they are flashing with the turn signal and I'm surprised they lasted this long.
  6. Jul 10, 2013 at 11:20 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    Parking lights activate them
  7. Jul 10, 2013 at 11:28 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Should be good then.
    Curious because the first pic shows the halos, but no headlights or parking lights.
  8. Jul 10, 2013 at 11:44 PM
    RIDDICK3
    RIDDICK3 nuckin futs member
    Stefan
    Orem, Utah
    Icon, omd, lr uca, bed speakers, t-rex grill, 170 striker lights.
    the transformer went out I had the same thing happen to me its a little black box inside the housing. or it could be on the outside with some models.
  9. Jul 11, 2013 at 8:44 AM
    Kavik
    Kavik Kavik
    Texas, DFW
    If this is the case, you can probably replace it with one at The Retrofit Source.
