Driver Side CV axle excessive play?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by myn75, Sep 12, 2022.
  1. Sep 12, 2022 at 11:26 AM
    myn75
    myn75 [OP] Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    Firing up the ol' analysis-paralysis machine with a suspiciously loose CV. Video here:
    the in and out play doesn't concern me as much but its the vertical movement that does. I do plan on a 2 inch lift or 1.5 even so im wondering if i should just get the ECGS plain bearing done now. Unless of course this amount of play is normal then ill just leave it be.
  2. Sep 12, 2022 at 11:31 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    I'm not sure if that amount of play will be an issue after a lift, but I do know that installing the bushing will tighten it up significantly. When installing front shocks/springs you will be 1/3rd of the way there anyway, why not go further and just pull the axle and install the bushing at that time?
    bulalo likes this.
  3. Sep 12, 2022 at 11:33 AM
    myn75
    Nor Cal
    Yeah i was thinking the same but its alot of work lol. almost everytime i work of one of my cars it starts out as a couple hours which then turns into 8 hours of blood, sweat, and cussing.
  4. Sep 12, 2022 at 11:36 AM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Good point.
    :facepalm:
  5. Sep 12, 2022 at 4:39 PM
    myn75
    Nor Cal
    bump, do yall think i need the ecgs. im gonna start shaking my friends trucks CV's..
  6. Sep 12, 2022 at 4:40 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Tacomas and 4Runners all have that amount of play from the factory. Seems weird, but isn’t a problem unless you put in a lot of lift.
    I have 1.5” of lift with no ECGS and no problems.
    myn75[OP] likes this.
  7. Sep 12, 2022 at 4:41 PM
    Bishop84
    Bishop84 Well-Known Member
    Every tacoma does this. Search it on here.
    The bushing fixes it, but is not necessary unless lifted.
    myn75[OP] and TnShooter like this.
  8. Sep 12, 2022 at 4:45 PM
    eon_blue
    Azusa, CA
    That looks completely normal, there's always a little play. The videos Ive seen where a new needle bearing or ECGS bushing was needed, the movement was much worse
    myn75[OP] and Big tall dave like this.
  9. Sep 12, 2022 at 5:12 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    That looks good to me. Looks completely normal.
    Here is mine before I did the bushing.
    https://youtu.be/4MMt-AB0fvE
    After the bushing, there is still some play. Maybe 1/2 as much or less. You’ll never get all the play out of it. You don’t want to either. Gear oil is thick, it needs room to flow between the bushing and CV.
    I guess if you are planning on lifting the truck, you might as well do it. The closer you get to, or surpass, 2”. The more likely you’ll need it later. It’s just part of lifting these IFS trucks.
  10. Sep 12, 2022 at 5:21 PM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Thats normal. I have that with mine and i have the new bearing in there too.
  11. Sep 12, 2022 at 6:17 PM
    myn75
    Nor Cal
    Man that was alot of wobble, was yours lifted at the time of filming?
    TnShooter[QUOTED] likes this.
  12. Sep 12, 2022 at 6:41 PM
    TnShooter
    Deogee
    STOCK
    No lift. Stock with 130k
    myn75[QUOTED][OP] likes this.
  13. Sep 14, 2022 at 4:59 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Same.
