driver side Fox 2.5 coilovers are..
Discussion in 'Suspension' started by bobby15, Feb 16, 2011.
  1. Feb 16, 2011 at 1:36 AM
    bobby15
    bobby15 [OP] Well-Known Member
    SoCal
    09 DC LB 4x4 magnetic grey tacoma
    Leaking ... i just notice today the hose to the reservoir has oil all over it .. the shocks have less than 5000 miles on them ... what could be the problem .. and would Fox company do something about it ?
  2. Feb 16, 2011 at 1:59 AM
    bobby15
    SoCal
    i plan on doing so ..you think they'd back their product even though the warrenty may be up ?
  3. Feb 16, 2011 at 10:14 AM
    bobby15
    SoCal
    Has anyone else experienced any leaks with their fox shocks ?
  4. Feb 16, 2011 at 10:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Any CO can leak. Its not that un common.
  5. Feb 16, 2011 at 12:32 PM
    bobby15
    SoCal
    Sorry I guess I was just trying to be more specific .. Any suggestions on what I should do or check on?
  6. Feb 16, 2011 at 12:34 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Take a couple of wrenches and make sure the fittings are tight.
    Also, if you're leaking oil you might also be leaking nitrogen. You should probably have the shocks repressurized.
  7. Feb 16, 2011 at 12:34 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Check if the fitting is tight. We had a set the leaked when they were shipped the fitting was loose
    EDIT: you beat me ^^^^
  8. Feb 16, 2011 at 12:36 PM
    mjp2
    NJ
  9. Feb 16, 2011 at 12:39 PM
    bobby15
    SoCal
    Thanks guys, I appreciate it !! I'll get to it once it stops raining out.
