Driver Side Front Wheel Boot Leaky?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Collins, Aug 26, 2019.
  1. Aug 26, 2019 at 11:48 AM
    Collins
    Collins [OP] Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    Hi Folks,
    Noticed this while doing the Front Diff and Transmission Oil change this weekend.
    Looks like grease coming from Driver side front boot.
    Is the boot clip bad or something up with the boot?
    I can see no other leaks from the boot, just where the axle shaft enters?
    You can see that the Passenger side is like new.
    Any worries here? I will wipe it off and see if more oozes out but thought
    i would ask the experts here.
    Thanks in Advance.
    Paul
  2. Aug 26, 2019 at 3:57 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Your clamp is gone, clean ooze and replace clamp, worm style clamp will be fine.
  3. Aug 26, 2019 at 3:58 PM
    eon_blue
    Azusa, CA
    yeah luckily it just looks like the clamp is bad, the boot looks fine.
  4. Aug 26, 2019 at 5:09 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    I would also add a little more grease, before you add the new clamp
  5. Aug 26, 2019 at 5:17 PM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
  6. Aug 27, 2019 at 4:52 AM
    Collins
    North Carolina
    Thanks Gents...
    Somebody school me on how to use the Grease Needle?...
    Remove clamp, slide the tip of needle between boot and axle, apply grease and re-clamp?
    I don't see a zerk in there anywhere...is there some other fitting i'm not seeing to apply
    the grease?
    Thanks again, i really appreciate the help.
    llamasmurf likes this.
  7. Aug 27, 2019 at 5:05 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Yes that is exactly how you do it with the needle
    :thumbsup:
    REDdawn6 likes this.
  8. Aug 27, 2019 at 10:57 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    You got fortunate that the boot isn't torn.
  9. Aug 27, 2019 at 11:20 AM
    Collins
    North Carolina
    Thanks for the follow-up guys.
    Yes i am fortunate, glad i took a closer look under there, i don't wheel at all, and only some light 4x4 on some farm roads around...
    so i think maybe the clamp never was tight enough?... just never noticed it until i was under it doing the diffs.
    I'm going to wipe it off and see if i can tighten the clamp some and if not get the new clamp and re-grease the thing
    and keep an eye on it...
    btw, what is good for cleaning that gunk off?...like a goo gone thing, or a stronger de-greaser?
  10. Aug 27, 2019 at 11:27 AM
    eon_blue
    Azusa, CA
    Wipe as much of it off with some rags as you can, then let the rest soak in degreaser. Should come off easily with a hose and more rags after that.
