Driver Side Power Window Sticking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elk340, Apr 3, 2012.
  1. Apr 3, 2012 at 8:47 PM
    elk340
    elk340 [OP] Well-Known Member
    Justin
    Ouray, CO
    '11 Tacoma TRD Off-Road AC
    Toytec ULK; OME Dakar leaf packs; Light Racing UCAs; OME carrier bearing drop; Toytec 3 degree axle shims; sway bar delete; Toytec extended rear brake lines; ARE CX topper; BAMF rear differential skid; BAMF LCA skids; BAMF sliders; Budbuilt IFS, mid, transmission, and gas tank skids; HomerTaco mesh; River Rat 69 satoshi grille; Toyota Land Cruiser radiator grille emblem; tinted windows; Toyota all-weather floor mats; Toyota bedmat; I-Pod interface; block heater; ATO hi-lift bed rail mounts; HL-605 Hi-Lift; RotoPax 4-gallon gas can and bed rail mounts; mattgecko sliding window security bar; Sockmonkey decals.
    Hey guys,
    After a thorough search, I found out how to fix my driver side window to keep it from "catching" or "jumping" as it is being rolled up; however, I need a better fix.
    If I spray the window track with WD-40, it will fix the issue...for a day or two and then it comes right back. Does anyone have a more permanent or longer lasting solution?
    Thanks!
  2. Apr 3, 2012 at 8:50 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I wonder if any bolts are loose
  3. Apr 3, 2012 at 8:50 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Will the warranty cover it?
  4. Apr 3, 2012 at 8:59 PM
    BAMFTACO
    Juan
    Kings bruh
    It should never hurts to try
  5. Apr 3, 2012 at 9:01 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    You need to use a lubricant that is more permanent than WD-40. WD-40 dries up like water within a couple of hours. Use white lithium grease or silicone spray. I use it on window regulators all the time at work. :)
  6. Apr 3, 2012 at 9:02 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Silicone spray is awesome. But as it's so new, I'd still have the dealer take a look.
  7. Apr 4, 2012 at 5:11 PM
    elk340
    Justin
    Ouray, CO
    Thanks for the insight guys. I took it to the dealer once and they said that the track just needs to be lubed, lubed it, and it worked. Their lube only lasted a couple of days. They said that they get a lot of complaints about the same issues in the '11 model year. I will try the silicone spray one of you mentioned and if that doesn't at least last a week, I will take it back to the dealership and tell them to figure out what the problem is instead of applying bandaids to fix the real issue. It doesn't happen on the passenger side, which is wierd.
    Justin
  8. Apr 5, 2012 at 3:05 PM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    Have them replace the window track and regulator under warranty
