Driver side scratching noise after new wheel bearings
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trents Tocoma, Dec 28, 2023.
  1. Dec 28, 2023 at 3:18 PM
    Trents Tocoma
    Trents Tocoma [OP] Well-Known Member
    Trent
    2002 Toyota Tacoma extended cab
    Hello I’ve just had new wheel bearings put on the truck and the passenger side is fine but the driver side is making a scratching noise like metal on metal anyone know what it may be
  2. Dec 28, 2023 at 3:48 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    Could be a lot of things but to do bearings the dust shield has to come off.
    Maybe they bent it (dust shield) and it's hitting the rotor.
    tcBob, koditten and StihlToyota like this.
  3. Dec 28, 2023 at 3:49 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Front or rear?
  4. Dec 28, 2023 at 3:49 PM
    tacofish
    N NJ
    14 ext cab 4x4
    you should add problem description in title.
    more people with knowledge might check it out.
    Trents Tocoma[OP] likes this.
  5. Dec 28, 2023 at 3:50 PM
    Trents Tocoma
    Trent
    Front driver side
  6. Dec 28, 2023 at 3:52 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Jack that corner up and spin that wheel by hand.
    Report back what you find.
  7. Dec 28, 2023 at 3:53 PM
    Trents Tocoma
    Trent
    Ok sounds good
    koditten likes this.
  8. Dec 29, 2023 at 6:48 AM
    Trents Tocoma
    Trent
    It was dust shield cover mechanic said it’ll burn off while I run it
    tacofish likes this.
  9. Dec 29, 2023 at 6:53 AM
    koditten
    Kirk
    Central Michigan
    I don't know if I'd use that mechanic in the future. Seems kind of lazy.
    That is an easy fix. Why doesn't he try to keep you happy by making the noise go away?
    It's not hurting anything the way it is, but I don't think it's gonna "burn" away.
    ControlCar, wilcam47 and 0xDEADBEEF like this.
  10. Dec 29, 2023 at 7:02 AM
    Trents Tocoma
    Trent
    Yea I don’t think it will either I’ll give it a week or so and if it’s not gone I’ll take it back again
  11. Dec 29, 2023 at 7:27 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    "Burn off" lol
    Crawl under there and gently bend the dirt shield away from the rotor, see if that helps. Hopefully he didn't leave a caliper bolt loose or something
    tacofish, HondaGM, Wulf and 2 others like this.
  12. Dec 29, 2023 at 7:39 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Lazy mechanic. ANY decent shop would take the 5 minutes needed to zip off the wheel, bend the dust cover back properly, and then replace the wheel and torque to spec. THAT is how you keep a happy customer.
  13. Dec 29, 2023 at 7:41 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    OP how much did you pay for this wheel bearing job?
    HondaGM likes this.
  14. Dec 29, 2023 at 7:44 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Bend it back not let burn...wtf. you need a new mechanic
    HondaGM and koditten like this.
  15. Dec 29, 2023 at 7:53 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    Burn off? more like Grind Down.
    the heck?
  16. Dec 29, 2023 at 7:59 AM
    02hilux
    Planet: EARTH
    Paid with a 12 pack type mechanic? Those are usually backyard mechanic's advice, issue will self resolve.
    HondaGM likes this.
  17. Dec 29, 2023 at 8:13 AM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    I’ve had this happen. They are usually pretty easy to bend away from the brake disk.
    HondaGM likes this.
  18. Dec 29, 2023 at 9:09 AM
    Trents Tocoma
    Trent
    Yea grind down is the better word to use he said burn off
    HondaGM likes this.
  19. Dec 29, 2023 at 10:04 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    This thread has gotten very entertaining!
    wilcam47 and HondaGM like this.
  20. Dec 29, 2023 at 10:06 AM
    wilcam47
    Will
    Bourbon state
    Thats better:rolleyes::rolleyes::rolleyes::rolleyes:
